Old 08-19-2013, 05:31 PM   #1
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG,FMIC, Big turbo
Default Will a ACT clutch disk bolt to a SPEC stage 2+ pressure plate?
I need a new clutch disk and my friend has a ACT HDSS disk that I can have, however, I need to bolt it to my SPEC pressure plate. Does anyone know if this will work? Thank you
emsmap is offline   Reply With Quote
Old 08-19-2013, 09:25 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Yes and no.
No, it doesn't bolt to anything. It slides onto the splines and that's it.
Yes, it'll work under the SPEC plate. I'm currently daily driving a similar setup.
Jay
Old 08-19-2013, 11:55 PM   #3
emsmap
Member#: 159334
02 WRX, 99RS, 96L
HMMM so are you saying if I get the ACT disk and use it with my SPEC plate, it will work fine? Interesting haha
Old 08-20-2013, 12:11 AM   #4
WhatTurboLag?
Member#: 243992
2006 WRX TR
It will hold more or less power (more likely less assuming its a lighter pressure plate) than getting the matching pressure plate
WhatTurboLag? is offline   Reply With Quote
Old 08-20-2013, 06:41 PM   #5
emsmap
Member#: 159334
02 WRX, 99RS, 96L
Thank you all
Old 08-23-2013, 08:02 PM   #6
VTrider36
Member#: 208656
2004 WRX Premium 4dr
WR Blue
not recommended.
Almost any tuner or performance shop will advise against mixing pressure plate and clutch brands.
VTrider36 is offline   Reply With Quote
