Old 08-20-2013, 01:25 PM   #1
joshuajayg
Member#: 323310
2002 WRX Wagon
Default Failing MAF? Logs
I am having issues. My knock corrections are going crazy and the A/F learning corrections are showing that I'm really lean in the 10-49 g/s range. Failing MAF? Failing O2?
2002 Impreza WRX
16G turbo
Large APS TMIC
Cobb DP and catted exhaust
High flow injectors, flow matched
Manual boost control
Perrin Turbo inlet
TGV deletes
High tension head bolts
Pro tuned years ago
Any ideas?
Cruse log two days ago:
https://docs.google.com/file/d/0B3-Y...it?usp=sharing
Learning View this morning:
Joshua
joshuajayg is offline   Reply With Quote
Old 08-21-2013, 08:43 AM   #2
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
I'll bump this for Joshua and add some more information.
He boost leak tested found and eliminated a large leak (replaced torn turbo inlet). He also found and eliminated a leak at one of his TGV deletes.
The car also has a clutch on it's way out and some noise and vibration from that may be triggering his knock sensor as well???? Everytime he goes w.o.t. his IAM drops like a rock. Detonation or noise I can't tell without a wideband. I suggested that he get a wideband but he has limited funds to work with right now.
Anybody want to take a stab at this?
nmlittlebigman is offline   Reply With Quote
Old 08-21-2013, 11:09 AM   #3
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
If it isnt the MAF, its the O2. But then again, he shouldnt have issues in WOT if it were the O2. I am going to guess its MAF related. Need updated learning view / logs from after fixing the leaks!
endrswrd is offline   Reply With Quote
Old 08-21-2013, 11:25 AM   #4
shunworm
Member#: 332783
2003 WRX
I had a kinda same issue. But if it was tuned before you found the leak then now the fuel is way off
shunworm is offline   Reply With Quote
Old 08-21-2013, 11:32 AM   #5
jthatch12
Member#: 321715
03 Big 16G WRX
Bypass the MAF by disconnecting it... See how the car runs due to force open loop, this will help determine a faulty MAF
jthatch12 is offline   Reply With Quote
Old 08-21-2013, 11:41 AM   #6
joshuajayg
Member#: 323310
2002 WRX Wagon
All the leaks are fixed. The turbo inlet and TGV are already fixed. I don't know if they were leaking when it was tuned, I really doubt they were. A lot of my IAM and A/F issues were happening before I found the leaks, that's actually why I went looking for leaks.
When I swapped the MAF with another one I had different fuel in the car so that didn't really tell me anything. I had accidentally filled up on 87 but added octane booster to save me from detonation. My A/F corrections were within 2% across the board before I swapped the MAF and they stayed there after I swapped it for a five minute drive.
My clutch has something goofy happening and I heard a rattle once under load but I haven't been able to reproduce it.
Joshua
Old 08-21-2013, 12:18 PM   #7
joshuajayg
Member#: 323310
2002 WRX Wagon
Fixed my list of mods. 16G, not 14G and TGV deletes.
Old 08-21-2013, 01:06 PM   #8
shunworm
Member#: 332783
2003 WRX
Then no clue... but sure it sucks when you don't know what to fix though
Mine was still knocking and running lean when it was leaking. Then i fixed it, tuned it, and gapped the plugs and then fixed everything. But might not be the same as yours though. Good luck.
Old 08-21-2013, 08:21 PM   #9
joshuajayg
Member#: 323310
2002 WRX Wagon
I will be pulling my tranny tonight since my clutch is acting up still. I'll post what I find.
Old 08-22-2013, 06:03 PM   #10
shunworm
Member#: 332783
2003 WRX
How did it go? Was it flywheel that was causing the vibe
Old 08-22-2013, 06:45 PM   #11
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Don't think he got it done yet. He emailed me earlier on his way back from California. He said he would most likely pull it this Sunday. He also said that he purchased an A.E.M. wideband from one of the NASIOC vendors to be shipped.
Hopefully we will help him get it sorted out and post up on here.
Old 08-23-2013, 12:29 AM   #12
joshuajayg
Member#: 323310
2002 WRX Wagon
Yeah, sadly didn't get it done. My cousin in Phoenix wasn't up to it and I wasted too much time to do it myself. It is the vegetable delivery time of week so hopefully Sunday I will have the transmission out.
Yep, AEM is ordered and on its way. I will install that while the transmission is out. I'll update when something promising happens.
I am home though! 700 miles to Cali, about 900 coming back through Phoenix. Got some sailing time in and experienced some good coffee.
Joshua
Old 08-24-2013, 06:23 PM   #13
joshuajayg
Member#: 323310
2002 WRX Wagon
Alright, I'm somewhere between confused and annoyed. Here's a learning view I pulled today and a log as well... I've done nothing to the car but drive it.
Log:
Joshua
Old 08-24-2013, 06:25 PM   #14
joshuajayg
Member#: 323310
2002 WRX Wagon
Just realized not everyone likes .csv files. Here's an .xls for viewing in google docs.
Joshua
Old 08-24-2013, 06:47 PM   #15
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Your fuel trims are way better than they used to be although you are still slightly lean in "C" range. I am hoping all of that FLKC is noise from your failing clutch. Are you replacing the clutch tomorrow?
Also it's been a while since your car has kept IAM at 16.
Old 08-24-2013, 06:55 PM   #16
joshuajayg
Member#: 323310
2002 WRX Wagon
Yeah, pretty good it is still at 16. I'm about to go for a drive up on the dirt road above my house. I will keep an eye on things. May not end up taking the clutch out. Been thinking about the exact circumstances when the clutch becomes "hard" and slips. Seems to be when it warms up around the master/slave cylinder area. May be a clogged compensator port in the master cylinder. Taking that route first tomorrow.
Joshua
Old 08-25-2013, 05:59 PM   #17
joshuajayg
Member#: 323310
2002 WRX Wagon
Removed and cleaned both the master and slave cylinders for the clutch. They were dirty for sure. Also turns out I have a master cylinder for a NA car. Oh well, no big deal there.
Checked my PCV valve, it is fine. Found a light spray of oil on my turbo-intercooler hose. Still trying to figure out where that came from. Since I was there I decided to take the tranny out. When I removed the exhaust I found that my cat was coming apart.
I was also missing the two nuts that attach the transmission to the cross member. I will be replacing those. The clutch is fine. The rivet depth is .45mm with the service limit being .30mm. There is localized glazing on the pressure plate and flywheel. I am going to get them checked for warp and will probably get the flywheel turned tomorrow.
So... looks like a mix of rattly cat, missing transmission mount nuts, and a dirty hydraulic clutch system accompanied by a likely failing MAF and the two inlet leaks I had found (inlet tube and TGV delete). I'll be finding a used MAF tomorrow as well. My AEM UEGO is at the post office waiting for me so I will install that while I have my downpipe removed.
Joshua
Old 08-25-2013, 06:58 PM   #18
nmlittlebigman
Member#: 321409
2003 Big Effing Van
^^^ Been busy today! The light coating of oil in your intercooler hose is blowby and normal.
Old 08-25-2013, 07:17 PM   #19
joshuajayg
Member#: 323310
2002 WRX Wagon
This oil was on the outside, Brent. Seemed to be fairly consistent too... Not coming from any specific spot.
Old 08-25-2013, 08:32 PM   #20
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Well you did have that huge rip in your turbo inlet. The pcv is plumbed in there where oil vapor can enter you intake tract and collect. Since your bypass hose is plumbed in there too you can see boost there on throttle lift and... voila...oil spray out into the engine bay. All mere conjecture dear Watson and a wild a$$ guess.
Old 08-25-2013, 09:01 PM   #21
joshuajayg
Member#: 323310
2002 WRX Wagon
No, because I cleaned that entire area really well before reassembling everything. It was clean when it went back together. I'm going to look some more but it may just be an anomaly.
Joshua
Old 08-25-2013, 10:48 PM   #22
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Joshua
Maybe pcv has a hairline crack or not seated properly?
Old 08-25-2013, 11:04 PM   #23
joshuajayg
Member#: 323310
2002 WRX Wagon
Might be a lightly leaking hose. I pulled all the lines, the PCV valve (which is actually in the throttle body) and the T which is on the block. The old lines are on there snugish but not exactly tight. It might just be the old, expanded rubber hoses not sealing as good as they should when the BPV opens and pressurizes the turbo inlet slightly. No cracks or split hoses though. I'm going to check the intercooler and intercooler pipe again in the morning just to make sure they are kosher. Then the flywheel work, AEM install, and sticking everything back on the car. MAF will be here Wednesday.
Joshua
Old 08-29-2013, 11:21 PM   #24
joshuajayg
Member#: 323310
2002 WRX Wagon
Everything is back together.
Got a (supposedly) good MAF sensor installed.
Turned the flywheel.
Clutch disc was still good.
Buffed pressure plate.
Cleaned chunky nastyness out of catalytic converter.
Replaced a few missing nuts/bolt.
Went for a drive, logged a lot and nothing tragic happened! A/F learning was all snazzy with the largest number being <2. Logged a third gear pull with no knock, no IAM drop, nothing.
Then I cruised on the interstate for a while and knock started showing up again. I'm sitting at 15 IAM, lots of FLKC, and A/F learning is high (12 at idle). I am pretty sure I don't have a vacuum leak. I suspect more of my catalytic converter came apart. I can hear a little noise when I release my clutch and things shimmy a little. Tomorrow my AEM UEGO comes in so hopefully I can get installed quick like. I may also go fill up on E85 soon and reflash. We will figure out if I am getting any legitimate knock.
LV at the end of today. The -4 cell has had the most FLKC the entire drive today.
Joshua
Old 08-29-2013, 11:49 PM   #25
joshuajayg
Member#: 323310
2002 WRX Wagon
Just checked my cat... no particulates. Next step is to troubleshoot my AFR.
