Old 08-21-2013, 06:47 AM   #1
marcone
Member#: 362208
Default ecu flash not reading
Hi I am struggling to connect ecuflash to vehicle.I have got everything installed and when I goto read ecu it gives me drop down menu for subaru then I click to read and it starts then puts up error message.Which is here what am I doing wrong.I dn't think I need jumpe cable just green connectors together,can someone help please,
Marc
[09:52:56.296] EcuFlash Version 1.44.3721
[09:52:56.296] OS Version Windows XP
[09:52:56.296] Qt Version 4.8.0
[09:52:56.312] 63 memory models read.
[09:52:56.312] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash
[09:52:57.468] 1835 ROM metadata models scanned.
[09:52:57.468] checksum module "subarudbw" loaded.
[09:52:57.468] checksum module "mitsucan" loaded.
[09:52:57.468] checksum module "mitsuh8" loaded.
[09:52:57.468] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[09:52:57.468] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[09:52:57.468] flashing tool "wrx02" loaded.
[09:52:57.468] flashing tool "wrx04" loaded.
[09:52:57.468] flashing tool "sti04" loaded.
[09:52:57.484] flashing tool "sti05" loaded.
[09:52:57.484] flashing tool "mitsukernel" loaded.
[09:52:57.484] flashing tool "mitsukernelocp" loaded.
[09:52:57.484] flashing tool "mitsubootloader" loaded.
[09:52:57.484] flashing tool "shbootmode" loaded.
[09:52:57.656] flashing tool "shaudmode" loaded.
[09:52:57.656] flashing tool "subarucan" loaded.
[09:52:57.656] flashing tool "subarucand" loaded.
[09:52:57.656] flashing tool "mitsucan" loaded.
[09:52:57.812] Using interface OpenPort 1.3 Universal TX2HfDun23eea4c54ed26d0e9fa870916041c01a7cf89825
[09:52:57.828] interface close
[09:52:58.140] Using interface OpenPort 1.3 Universal TX2HfDun23eea4c54ed26d0e9fa870916041c01a7cf89825
[09:52:58.156] interface close
[09:52:58.234] Using interface OpenPort 1.3 Universal TX2HfDun23eea4c54ed26d0e9fa870916041c01a7cf89825
[09:52:58.234] interface close
[09:54:21.468] using metadata XML ID read_wrxnonusdm from file C:/Program Files/OpenECU/EcuFlash/backup002/rommetadata/read templates/read_wrxnonusdm.xml
[09:54:21.562] Using interface OpenPort 1.3 Universal TX2HfDun23eea4c54ed26d0e9fa870916041c01a7cf89825
[09:54:30.375] denso02_bootloader_cmd_start
[09:54:31.593] denso02_bootloader_cmd_start
[09:54:32.812] denso02_bootloader_cmd_start
[09:54:34.031] denso02_bootloader_cmd_start
[09:54:35.250] denso02_bootloader_cmd_start
[09:54:35.671] kernel get version
[09:54:36.000] interface close
marcone is offline   Reply With Quote
Old 08-21-2013, 10:46 AM   #2
insaneimpreza
Member#: 83291
1998 RSTi
IAG Stg4 Extreme S366SXE
What year and model car is it?
insaneimpreza is offline   Reply With Quote
Old 08-21-2013, 12:08 PM   #3
JonnyV2889
Member#: 197384
2006 WRX Ltd
Can you pull a learning view?
JonnyV2889 is offline   Reply With Quote
Old 08-22-2013, 12:49 AM   #4
el dude
Member#: 85197
2002 Impreza WRX
I know for 02-03's you need the jumper and test connectors hooked up. My issuse with ecuflash is timing. I turn the key and hit ok ASAP otherwise it won't connect.
el dude is offline   Reply With Quote
Old 08-22-2013, 03:09 AM   #5
marcone
Member#: 362208
hi its 2002 bugeye,I didn't think you needed jumper leads just the green connectors if so where are the jumper connectors?
How do I pull a learning view from,I find this software really hard to use does it get easier?
It sys look at log how do I look at the log also?
Old 08-22-2013, 08:58 AM   #6
marcone
Member#: 362208
yippee done it was looking for 2 pin connector but had 4 pin connector.Read straight away now where to go next.
