Mid Atlantic Impreza Club
Old 10-03-2002, 06:37 PM   #1
SubyNewbie
Member#: 9529
2011 Forester 2.5X
Dark Grey
Question Question about getting an oil cooler
I'm thinking about installing one on my car. The JDM motor I have likes to run hot, and once it's at running temps, my oil pressure at idle is less than desired (about 15 psi). I'm wondering if an oil cooler would help keep the viscosity up, and wondering if it would damage anything, as someone suggested on another forum. As some other people on here probably know, JDM swaps can become very costly very quickly, and I'm concerned about doing every little thing I can to increase the longevity of the motor. So would installing one of these be a good or bad idea ? I don't do much racing right now, but plan to in the future.
SubyNewbie is offline   Reply With Quote
Old 10-03-2002, 09:39 PM   #2
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
I'd definitely get one that allows the oil to properly warm up before it actually starts working. That way, you don't run the risk of running oil that is too cold. If you go to Summit Racing I'm sure you can find something in the Oil System section. I was just in there looking around, but I'm not sure exactly what you're looking for. Personally, I'd get one that regulates when the cooler actually works so you're not messing up the internals of your engine.
AJ
AJ711 is offline   Reply With Quote
Old 10-04-2002, 09:17 AM   #3
SubyNewbie
Member#: 9529
2011 Forester 2.5X
Dark Grey
Thanks midnx03, i'm thinking i'm probably gonna end up getting one, i just can't think of how i'd plumb it in, so that it's an alternate route when oil temp is up.
Old 10-04-2002, 09:20 AM   #4
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
How is the water temp?
Personally I would start with upgrading the radiator. Are you on the stock 240 radiator or do you use the Sylvia radiator?
elgorey is offline   Reply With Quote
Old 10-04-2002, 10:17 AM   #5
SubyNewbie
Member#: 9529
2011 Forester 2.5X
Dark Grey
water temp doesn't seem to be bad, I monitor it at the radiator, put probe where drain plug used to be. At that point it stays just under 100 degrees. Maybe I should look into getting a lower temp thermostat ?
Old 10-04-2002, 01:00 PM   #6
Adrift
Member#: 15528
2006 Aspen White
20G'd STi - Long Gone :^(
most manufacturers of oil coolers offer sandwich adapters with thermostats, so oil isn't passed through the cooler when it is cold.
http://www.racerpartswholesale.com/mocal.htm
if you look at the page above, the second item down is what you need, or you can add the first item to a basic oil cooler kit.
Adrift is offline   Reply With Quote
Quick Question about fitting an Oil Temp. Sensor nxwrxfx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-11-2006 12:41 PM
Question about getting an STI REXchampman Tri-State Area Forum 3 12-19-2003 08:52 PM
Where does one get an oil cooler and dual filter system? Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-16-2002 12:03 PM
Should I get an oil cooler for my 1997 L with the 2.2 liter motor? dsc Normally Aspirated Powertrain 2 04-05-2002 12:37 PM
Hey guys, I am thinking about an Oil Cooler Boom New England Impreza Club Forum -- NESIC 19 09-29-2001 05:19 PM
