Welcome to the North American Subaru Impreza Owners Club Friday July 11, 2014
Old 10-03-2002, 07:51 PM   #1
wolfman
Member#: 13625
2002 wrx
Default Do you really need new links for sway bars?
Can I use the stock links if I install a rear sway bar? I know they suggest new ones, but I heared they make allot of noise?
wolfman is offline   Reply With Quote
Old 10-03-2002, 07:57 PM   #2
eric m.
Member#: 14872
06 legacy GT black
accessport stage II.
they make absolutely no noise. and no you don't need them. they just increase the effectiveness of the sway bar. if you want a less efficient sway bar, then don't get end links. no big deal.
eric m. is offline   Reply With Quote
Old 10-04-2002, 01:11 AM   #3
hotrod
Member#: 14141
2002 Impreza WRX
e85forum.net
Default what's your objective
Actually a case could be made that you should get the new links, before you upgrade the sway bar. They are stiffer and will make the stock sway bar act as though it is bigger. If that is still not enough change in roll rate for your needs then go to the heavier sway bar.
Larry
hotrod is offline   Reply With Quote
Old 10-04-2002, 01:12 AM   #4
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
yep, and have you seen the new Perrin links? AWESOME
Matt
mattjk is offline   Reply With Quote
Old 10-04-2002, 02:18 AM   #5
mlambert
Member#: 13831
completely wrong forum
btw I havnt even seen the perrin links yet and I see the guy every weekend
mlambert is offline   Reply With Quote
Old 10-04-2002, 02:20 AM   #6
mlambert
Member#: 13831
ok really, still wrong forum..
Old 10-09-2002, 01:58 AM   #7
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
Wow, I want a pair.
Matt
end links for sway bars Manutd06 Brakes, Steering & Suspension 8 12-31-2008 02:47 PM
Hotckis End-Links for sway bars UndertoW101 Private 'Wanted' Classifieds 2 12-20-2005 12:03 PM
Do You Really Need Premium Gas? awu72 General Community 62 11-15-2005 01:18 PM
Do you really need winter tires in NY? Hyper Tri-State Area Forum 10 03-01-2005 05:10 PM
How do you un-flip a flipped rear sway bar? drdome99 Brakes, Steering & Suspension 4 09-19-2004 12:47 PM
