Old 08-24-2013, 06:54 PM   #1
blk6s
Member#: 200057
2013 Impreza 2.0i
RalliSported RomRaided
Default RalliSport EL 4-1 2.5i header
Quick peek at a custom build I just completed for a very patient customer.
1 5/8" primaries
4-1 merge collector
EL to the valves (+/- 1")
OEM grade high flow cat
And yes, I will be offering these for sale (along with their UEL 4-1 counterpart).
blk6s is offline   Reply With Quote
Old 08-25-2013, 01:52 AM   #2
subi400
Member#: 216984
1996 Impreza outback
Green
That looks sweet....
The boxer rumble might be lost using this header but the power and response will be worth it!
I like the fact you are using a 3 bolt flange right after the cat to create a tighter seal. What brand of 3-bolt flange? Is that a 2.25" collector?
~Josh
subi400 is offline   Reply With Quote
Old 08-25-2013, 07:48 AM   #3
GrundleJuice
Member#: 165749
That header makes my pants tighter. How much time went into that collector?
Old 08-25-2013, 01:54 PM   #4
iommichild
Member#: 194990
2008 OBS
Steel Silver/Spark Silver
I'm so f'n stoked to get this baby installed...!
iommichild is offline   Reply With Quote
Old 08-25-2013, 04:52 PM   #5
Ivan MR
Member#: 333752
Wow those are good looking!!! How much are they and how do I place a order for a set of those headers??
Ivan MR is offline   Reply With Quote
Old 08-25-2013, 05:02 PM   #6
Fender137
Member#: 340626
2004 Impreza Wrx STi
World Rally Blue
What material was used to make the header?
Fender137 is offline   Reply With Quote
Old 08-26-2013, 11:01 AM   #7
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Looks very nice!
Kevin Thomas is offline   Reply With Quote
Old 08-26-2013, 03:52 PM   #8
blk6s
Member#: 200057
2013 Impreza 2.0i
~Josh
The flanges I have water jet cut to my specs. Correct: 2.25" collector (I should have included that in the description).
My gf just happened to look over when I was reading this and noticed the tighter pants comment and asked "do guys actually talk like that about car stuff??" My answer was "yes, yes they do."
My time into the collector was the time it took me to order it from my supplier. I normally go with a formed collector and fab up an internal merge bullet, but in this case I decided to go with a premade collector. The extra cost was outweighed by the time savings and quality of the product.
Tracking info sent, thanks!
pm'ed you back. I'll update my website sometime in the near future.
I work exclusively with 304ss (the cat is from Magnaflow and is 409ss).
Originally Posted by Kevin Thomas View Post
Looks very nice!
Well thank you!
Old 08-26-2013, 06:26 PM   #9
GrundleJuice
Member#: 165749
I know burns makes a very nice merge collector but it's Texa$.
Old 08-26-2013, 11:20 PM   #10
GEE-OTTO
Member#: 201277
2009 Legacy GT
As always nice work man!
GEE-OTTO is offline   Reply With Quote
Old 08-27-2013, 03:35 PM   #11
Back Road Runner
Member#: 60082
2004 Forester STI
Purdy.
I like it. Primary and secondary sizing is good. From what I've figured long ago, the primaries could be longer for the stock cams, why TWE's header is as twisty as it is, but shorter primaries like yours may fit better with anyone running sport cams and a little higher torque band.
Old 08-27-2013, 08:16 PM   #12
blk6s
Member#: 200057
2013 Impreza 2.0i
I believe the merge collectors are made in house by my supplier, but I do know their formed collectors are sourced from Cone Engineering. I've used literally hundreds of formed collectors from Cone with no problems, although it is a bit of a PITA to order from them directly.
Thanks. You've watched me come a long way from making cat pipes on the side, just for fun.
Originally Posted by Back Road Runner View Post
Purdy.
Larger primaries raise peak torque, while lengthening the primaries raises the curve before peak torque is made (at the expense of having it roll off quicker after peak torque).
The "twisty" header that TWE makes is for the pre-06 2.5i (I believe that some have fitted them on the 06+ 2.5i but with some minor interference).
The reason the primaries on my EL header are relatively short is simple: there just isn't enough room to make them longer and still retain the factory mounting location for the cat pipe. Case in point: TWE actually makes a 06+ 2.5i specific EL header and it looks extremely similar to mine
This is no coincidence, as there is really only one logical setup that works.
Old 08-28-2013, 06:04 AM   #13
Back Road Runner
Member#: 60082
2004 Forester STI
That's right, diameter places the pivot point, length tilts the curve.
Old 08-29-2013, 08:03 AM   #14
Distant.Calling
Member#: 230167
2006 2.5i
CGM
Hopefully we can see dyno figures. Just curious what the power difference is between this EL and UEL.
Distant.Calling is offline   Reply With Quote
Old 08-30-2013, 11:28 AM   #15
tiger2011
Member#: 222392
2009 2.5i
Captain Slow
Looks beautiful. Very much do want.
Would love to see the dyno charts on these too!
tiger2011 is offline   Reply With Quote
Old 08-31-2013, 03:16 PM   #16
iommichild
Member#: 194990
2008 OBS
Initial butt-dyno says - theres def more grunt in the 2800 - up range...When flooring the throttle, it feels less "weeeeeee" and more "woooooooo" if that makes sense? Like the difference between a yelp and a bellow. (weird way to describe, I know..)
My hope is to get it tuned at FTW here within the next month. I'll definitely post results.
Thanks again Mike - beautiful product, fits perfectly and is veerrrry nice!
Old 08-31-2013, 06:20 PM   #17
Distant.Calling
Member#: 230167
2006 2.5i
CGM
So CEL's so far?
Old 08-31-2013, 06:30 PM   #18
kevwill
Member#: 228389
pearl white
i want these, keep me updated on price and dyno results. When do you plan to start production, groupe buys,?????
kevwill is offline   Reply With Quote
Old 09-01-2013, 12:26 AM   #19
iommichild
Member#: 194990
2008 OBS
No CELs at all. Haven't experienced a 'cold start' yet though since its still muggy and hot here in the Willamette Valley.
Old 09-02-2013, 10:55 AM   #20
RalliSport Racing
Member#: 367216
I doubt I'll have time to dyno test a new set until this winter.
I'll try to update my website when I have the chance. I'm thinking about offering them with a metallic substrate cat for maximum flow, or with a OEM grade cat for those worried about throwing a cel.
RalliSport Racing is offline   Reply With Quote
Old 09-02-2013, 04:27 PM   #21
tiger2011
Member#: 222392
2009 2.5i
Captain Slow
Would you consider offering these with a cat delete option?
Old 09-02-2013, 04:39 PM   #22
RalliSport Racing
Member#: 367216
Sure thing
Old 09-06-2013, 08:31 AM   #24
N/A_Scoobs
Member#: 255985
2008 Impreza N/A
dark grey metallic
Whats the horse power gains for this EL version please
N/A_Scoobs is offline   Reply With Quote
Old 09-06-2013, 09:04 PM   #25
RalliSport Racing
Member#: 367216
Glad you like it. Now the bottle neck in your exhaust is the factory cat pipe, which pinches down to 2" right after the header. You might want to address that if you haven't already. I make HFC pipes, but haven't had time to update my website yet. If you do need one, email me and I'll hook you up with a discount.
I won't know until I dyno test them against the factory header, which won't be until winter.
