Old 09-09-2013, 06:58 PM   #26
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
sub'd for update's. In for dyno results and possible pricing.
KartRacer3 is offline   Reply With Quote
Old 09-09-2013, 08:22 PM   #27
RalliSport Racing
Member#: 367216
Well you have good timing because I just updated my website. Dyno results will have to wait a few months. I wouldn't expect any huge gains from these alone, but they are a must for anyone wanting to take full advantage of supporting mods such as cams, head work, etc.
RalliSport Racing is offline   Reply With Quote
Old 09-09-2013, 08:27 PM   #28
gc822
Member#: 81217
Verry nice work
gc822 is offline   Reply With Quote
Old 09-09-2013, 09:26 PM   #29
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Just checked it out. These will definitely be on my list for christmas
Old 09-10-2013, 08:11 AM   #30
Distant.Calling
Member#: 230167
2006 2.5i
CGM
I'm not that versed in engine work, but would such supporting mods increase the compression ratio?
Distant.Calling is offline   Reply With Quote
Old 09-13-2013, 09:13 AM   #31
AMCjavelin74
Member#: 368199
2004 Impreza 2.5 5sp
Red
To increase static compression, you can mill the cylinder heads and/or run thinner head gaskets. I'd go against using a domed piston since it's not very efficient for flame travel to have a combustion chamber shaped like an orange peel. I think that ideally a slight dish in the piston is preferred as it offers more "working" surface area for the combustion pressures to push against.
Bolt-on parts, such as intakes and exhaust, reduce pumping losses. You're not really making any more power, just freeing up power that was spent pumping air through a restrictive factory (designed to be cheap to make and easy to install during manufacture and quiet too) intake or exhaust system.
As for turbos, an engine running at 14.7psi or 1 bar basically doubles the displacement of the engine with the intake side of the engine operating under double atmospheric pressure. A 2 liter turbo engine at 14.7psi makes approximately the same power as a similar technology 4 liter naturally aspirated engine. I say "similar technology" since a fairly modern Subaru turbo engine will make more power than, say, a 4L (or 242 cubic inches) Jeep engine with roots tracing to 1964.
AMCjavelin74 is offline   Reply With Quote
Old 09-14-2013, 09:03 AM   #32
Distant.Calling
Member#: 230167
2006 2.5i
CGM
Very interesting. Thanks for the response!
Old 10-28-2013, 11:12 AM   #33
arthuruscg
Member#: 228844
2008 Outback 2.5i
Wow, does it hang down lower then stock? I am also thinking about a skid plate.
arthuruscg is offline   Reply With Quote
Old 12-21-2013, 12:57 AM   #34
RalliSport Racing
Member#: 367216
Default Just in time for Christmas
I reacquired these from the original purchaser (who sold his Subie) about a month ago, so they have only about three months of use on them. They have the OEM grade high flow cat and I just had them ceramic coated in Cerma Krome. They are beautiful, in stock and ready to ship!
In the mean time before they sell, if anyone with a 06-11 2.5i near St. Paul MN would like to help me dyno test them, I and the community would be grateful.
Old 12-21-2013, 01:27 PM   #35
Back Road Runner
Member#: 60082
2004 Forester STI
It'd be fun to test if I had a car that it could bolt to. I've dyno ran my old Forester a couple times and have done a ton of road logging as I modded it. Unfortunately it's using a very long, old TWE header that doesn't bolt up to the stock location.
Old 12-22-2013, 08:47 PM   #36
MillercLean
Member#: 376621
Those look great! Very jealous of those water cut flanges.
MillercLean is offline   Reply With Quote
Old 05-01-2014, 09:25 PM   #37
MercuryGodOfInfinity
Member#: 362799
2008 Impreza OBS
Obsidian Black
Wow I stopped looking for headers for my 08 OBS last year at the beginning of the summer. Now I am stoked to find this RalliSport Racing information. It's awesome that you would dedicated your time to designing, fabricating, testing and selling these. I am most definitely interested in buying one of these options very soon.
Is there any new information since the end of last year?
MercuryGodOfInfinity is offline   Reply With Quote
Old 05-03-2014, 06:34 AM   #38
James2.5i
Member#: 305063
2016 VDUBBB
If only there was another thread with thousands of replies, some of which were as recent as the past few days.......
James2.5i is offline   Reply With Quote
Old 05-03-2014, 11:20 AM   #39
clee2318
Member#: 265538
2004 wrx sti
I reacquired these from the original purchaser (who sold his Subie) about a month ago, so they have only about three months of use on them. They have the OEM grade high flow cat and I just had them ceramic coated in Cerma Krome. They are beautiful, in stock and ready to ship! In the mean time before they sell, if anyone with a 06-11 2.5i near St. Paul MN would like to help me dyno test them, I and the community would be grateful.
i have a 07 2.5i and im from stp mn, if u want to dyno test them lmk.
clee2318 is offline   Reply With Quote
Old 05-03-2014, 01:22 PM   #40
RalliSport Racing
Member#: 367216
As for the EL version, the one in this thread was the only one I've ever sold, sadly. After I bought it back from the original customer and had it ceramic coated, I sat on it for a while and then ended up selling it for a loss just to get rid of it. The reality is that there just doesn't seem to be a market for a well made (but expensive) direct bolt on EL header.
Old 05-05-2014, 10:55 AM   #41
Member#: 362799
2008 Impreza OBS
Obsidian Black
That's a bummer that you had to take a loss on that. I would love to buy one of the EL headers, it just helps to see some real application info like before and after results, or comparison to your UEL setups.
If only your comment actually helped me, or was even relevant to the EL headers I was interested in which apparently there was only one header ever sold.. If you are referring to a thread that is about the one EL header that RalliSport Racing ever sold then I would be surprised yet interested to know which thread it is.
Old 05-06-2014, 09:49 PM   #42
Distant.Calling
Member#: 230167
2006 2.5i
CGM
Would there be a CEL with the model without the cat? I wish someone would help out RSR with the dyno. Wonder if there's a huge difference between the EL and UEL model in terms of power.
