Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 08-24-2013, 10:46 PM   #1
parhamm1
Member#: 303664
2011 WRX sedan
Default 2013 sti seats swapped into base 2011 wrx.... Airbag light, seatbelt beep... AHHH
I just swapped some 2013 Sti seats into my 2011 base wrx and I'm the getting airbag light, seatbelt lights (even when seatbelts are in) and seatbelt alarm beeping.... Everything was plug and play.... At least I thought. Any input folks?
parhamm1 is offline   Reply With Quote
Old 08-25-2013, 02:43 AM   #2
BoostMasterZero
Member#: 337634
2013 WRX Sedan
308/339 -Tuned by Agile
No idea man, you must have not connected the proper connectors in the slot or the connection is loose. I swapped over 2011 STi alcantera/leather seats in my 2013 base WRX and it was just plug and play, no lights or anything.
Check the grey connector as I had a hard time unplugging it as well as plugging it in all the way.
BoostMasterZero is offline   Reply With Quote
Old 08-25-2013, 08:56 AM   #3
parhamm1
Member#: 303664
2011 WRX sedan
Yeah I'm going to recheck the plugs. I mean they all seemed very easy to remove and plug back in... Ill report back.
Old 08-25-2013, 11:38 AM   #4
parhamm1
Member#: 303664
2011 WRX sedan
Just checked all of the plugs and everything is plugged in securely.... Still have the lights. Tried an ECU reset on the AP too with no luck.... I don't get it.
Old 08-25-2013, 11:54 AM   #5
Tomnompom
scammer
Member#: 343232
2012 WRX 5DR
You could always put a resistor for the air bags and turn the beeping noise off. http://www.clubwrx.net/forums/cockpi...sable-diy.html
Tomnompom is offline   Reply With Quote
Old 08-25-2013, 12:50 PM   #6
parhamm1
Member#: 303664
2011 WRX sedan
Ahh found the issue! The guy I bought them from shoved one of the airbag plugs way up in the seat cushion area for some reason... Pulled her out, plugged it in and we're all good. Sorry for the useless thread folks!
