Old 08-26-2013, 12:07 PM   #1
lumpy
Member#: 28410
2012 Impreza Sport
Default Has anyone changed their own CVT fluid yet?
Just wondering if anyone has done this on their own yet?
As far as I have read, the Subaru fluid is only available in barrels and I am afraid of voiding the powertrain warranty or asking for problems by using Redline or something else. Some vendor needs to start breaking this down into quarts like Fred Beans and others did with Xtra-S.
Anyone yet? Too early?
lumpy is offline   Reply With Quote
Old 08-26-2013, 01:30 PM   #2
79letour
Member#: 302570
2013 XV
DGM!
I think if you take a few jugs most dealers will sell you some. I know someone has changed it but cant recall who.
79letour is offline   Reply With Quote
Old 08-26-2013, 01:55 PM   #3
fistv
Member#: 350063
2013 Impreza sport
I don't think the cvt has a drain plug, I just remember the svc manager mentioning it when I said I do my own oil and his comment was 'well with the new cvt's nobody will be making the mistake of draining the transmission instead of the oil because the cvt does not have a drain plug'. I don't know for sure and I have not been under far enough to look for one, I have only gotten back as far as the oil pan drain yesterday when I did my oil. I also got the impression the CVT is not serviceable in the vehicle, don't know, just starting to learn these subi's or at least mine.
fistv is offline   Reply With Quote
Old 08-26-2013, 02:13 PM   #4
79letour
Member#: 302570
2013 XV
DGM!
Theyre not something most would attempt to service themselves. But a few hardy souls have done it.
Probably sucked the fluid out through the top.
Old 08-26-2013, 02:23 PM   #5
Zeeper
Member#: 299286
2015 WRX CVT
Bogus info from the service manager,
Nickottowaontario was already on the forum -- attempted an oil change and accidentally drained the CVT fluid...unless he/she pulled it out via the dipstick tube for the CVT (is there one?) there is a plug, probably using a torx bit, located near the oil drain plug.
http://forums.nasioc.com/forums/show...ight=cvt+fluid
Zeeper is offline   Reply With Quote
Old 08-26-2013, 03:10 PM   #6
79letour
Member#: 302570
2013 XV
DGM!
There ya go^
I knew someone on here had done this.
Old 08-27-2013, 06:39 PM   #7
IveBeenRued
Member#: 305466
2012 Sport Limited
I was just underneath mine the other day and I can confirm that there is a drain plug. If you find the front differential plug labeled "DIFF OIL" then just look behind that and you will see a black oil pan, that is the CVT Fluid Pan. The drain plug is on the back of that pan and the fill plug is on the side of the pan. If you just do a drain and fill you will not be able to get out all the old fluid but as the old saying goes, "The only solution to pollution is dilution."
You do not have to use the Subaru fluid if you do not want too. As long as a CVTF is meets or exceeds the Subaru standards then you will be fine. Valvoline, Redline, and Eneos all have CVTFs that meet or exceed the Subaru standards.
Valvoline CVT Fluid, $10/Quart
http://www.valvoline.com/pdf/cvt_fluid.pdf
Eneos CVT Fluid, $12/Quart
http://www.eneos.us/product/7
Redline Non-slip CVT Fluid, $14/Quart
http://www.redlineoil.com/product.aspx?product=30804
IveBeenRued is offline   Reply With Quote
Old 08-27-2013, 09:32 PM   #8
79letour
Member#: 302570
2013 XV
DGM!
Eneos is supposed to be really good stuff...
Old 09-09-2013, 12:31 AM   #9
stevehnm
Member#: 329526
2013 Impreza Spt cvt
If you Google Eneos Subaru CVT you will find that Eneos is not compatible with Subaru's "E CVT/i-CVT Fluid" - which I presume is the new chain drive "Lineartronic" CVT. It's good for metal belt CVT's, but chain drive CVT's are a different animal.
stevehnm is offline   Reply With Quote
Old 10-07-2013, 05:18 PM   #10
bmboll
Member#: 370340
My friend has a '13 Impreza that he just accidently drained the CVT fluid. He is wondering how to fill it back up? Where do you fill it from?
bmboll is offline   Reply With Quote
Old 10-07-2013, 05:58 PM   #11
bmboll
Member#: 370340
I have located the answer. A tow truck is on its way
Old 10-08-2013, 12:18 AM   #12
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
PUP 5W30 92,050 miles
Wow, another one of these $300 accidents.
CLL_OBP is offline   Reply With Quote
Old 10-09-2013, 06:52 AM   #13
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
From what I have read on this forum, the fill procedure involves filling, warming up, shifting the transmission through all the gears, (P,R,D,M), and back. Then with the engine still running, put the car on a lift and recheck the fluid level, topping it off if needed. This is through an opening under the car. IIRC, there is no dip stick.
As an aside, someone on the board had the dealer change the fluid, as well as replace the metal mesh filter inside the transmission. At about 10,000 miles, there was evidently lots of metal bits that had been trapped by the filter. (Initial break in wear stuff. Don't get too excited.) Anyway, Subaru has the first service way out in miles, but I too like the idea of getting any initial debris from break in out of there. Personally, I think that is better for the long run. I plan on having this done to mine either soon or in the Spring.
John
Guzzi 1 is offline   Reply With Quote
Old 10-09-2013, 08:18 AM   #14
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
That was me. At first the service tech said I should get a new filter ($79) but when I saw it was metal, I said no way! I honestly don't see a need to ever replace an all metal filter. A good splash around and rinse in the part washer had it looking like new again.
Old 05-23-2014, 07:45 AM   #15
IveBeenRued
Member#: 305466
2012 Sport Limited
AMSOIL recently released their CVT fluid which meets the Subaru Lineartronic® CVTF (P/N K0425Y0710) requirements. It is going for $9.95/quart shipped with the preferred customer discount or $14.48/quart shipped without the discount.
http://www.amsoil.com/shop/by-produc...?code=CVTQT-EA
Old 05-26-2014, 05:08 PM   #16
LukeandRobbugeye
Member#: 391887
yes on a manual 2001 bugeye and was not that hard just takes a wile to refill
LukeandRobbugeye is offline   Reply With Quote
Old 05-26-2014, 09:13 PM   #17
John451
Member#: 321966
2012 Impreza + XV 14
Black Pearl + White XV
Can anyone confirm this ?
Mine just had a major 48 month Service, I asked if the CVT fluid was done the Subaru Service manager advised they did the diffs but never change out the CVT fluid in the new Imprezas as the oil is considered a lifetime oil ?
John451 is offline   Reply With Quote
Old 05-27-2014, 12:48 AM   #18
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
Nonsense. Engine oil, gear oil and transmission fluid deteriorate over time and loose their ability to lubricate, cool and clean. Even if you don't use your car for towing, I would change it anyway. If you plan on keeping your car for the long haul like I am, insurance is cheap and repairs are not.
The car is only 2 years old car so is the "48 month service" really a 60,000+ service?
Old 05-27-2014, 01:52 AM   #19
John451
Member#: 321966
The 48 month service is only 30,000 miles, how many miles before the CVT oil should be changed do you know what Subaru recommends ?
Old 05-27-2014, 02:51 AM   #20
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
Alright, the U.S models 30 months is 30,000 miles but I reached that after 19 months.
The service manual only tells you to inspect the CVT fluid every 30K under schedule 1 and to replace every 24,855 miles under schedule 2 if you repeatedly tow a trailer. 24,855?!?!
I had my CVT fluid changed at 10,000 miles because of the metal shavings that came out of the differentials. I assumed the transmission would have some too and it did, a lot.
Old 05-27-2014, 06:49 AM   #21
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
I thought the manual said towing was verboten? ?
hemophilic is offline   Reply With Quote
Old 05-27-2014, 09:01 AM   #22
John451
Member#: 321966
Mine has genuine Subaru accessory tow bar but I removed it early as it hung too low under the rear bumper bar making steepish driveways a most interesting game of not scraping.
Old 05-27-2014, 10:12 AM   #23
PoManzAWD
Member#: 388208
2014 XV Crosstrek
Metal shavings? Out of the CVT?? YIKES.
Was the pan dropped to determine this or was it just the 'paste' blob that forms on a typical drain plug magnet?
I've done a lot of ATF changes, both pan drops and drain plug drain/fills. You might see a metallic speckle on a magnet or filter, but I've never seen all out shavings on a trans that hasn't grenaded.
PoManzAWD is offline   Reply With Quote
Old 05-27-2014, 11:07 AM   #24
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
Originally Posted by PoManzAWD View Post
Metal shavings? Out of the CVT?? YIKES. Was the pan dropped to determine this or was it just the 'paste' blob that forms on a typical drain plug magnet? I've done a lot of ATF changes, both pan drops and drain plug drain/fills. You might see a metallic speckle on a magnet or filter, but I've never seen all out shavings on a trans that hasn't grenaded.
Yes, shavings not graphite looking goop stuck on a magnet. I wish I had taken a picture of it. They were in the metal screen and the pan was dropped.
Old 05-27-2014, 12:26 PM   #25
PoManzAWD
Member#: 388208
2014 XV Crosstrek
Cool pic non the less! That's the first I've seen of the newer Subaru CVT with the pan dropped. Looks like an Electrolux vacuum cleaner motor all up in there.
