Old 10-04-2002, 12:52 AM   #1
DiMensionX
Member#: 23517
Wink UTEC, 19 DynaPak Runs, Maps, Data, and other tidbit's
Ok folks here is the fun stuff. Today I went to Knowledge Performance here in Atlanta and made 19 DynaPak runs. We worked through the tuning and getting used to the UTEC's interface.
In the next set of replies I will post each run, I logged all of them using the standard "L" logging function in the UTEC. I also logged with the Delta Dash, I'm not going to post it in todays thread (Unless requested) as I don't think it's needed and it's hard to read anyway. I'll have the actual Dyno graphs scanned and will reply with them tomorrow.
Also, at the bottom I will post the UTEC included map we started with, then I will post the final UTEC map. I am NOT responsible for someone using my maps in thier car and blowing it up!
Engine Mods:
TXS UTEC v2.2
TXS Full Turbo back exhaust with the cat eliminator (no cats)
M2 Up-Pipe
Pony Express MIL Eliminator (Ditch's the CAT CEL)
STI Injectors
255 Liter Fuel Pump
Airbox Mod
IHI VF-34 Turbo
Stock BOV
TXS Top Mount Intercooler
On to the good stuff
Shawn
EDIT - Ok, it will take a few but I'll post the DD logs too. Be back shortly...
DiMensionX is offline   Reply With Quote
Old 10-04-2002, 01:07 AM   #2
mlambert
Member#: 13831
hurry up
before/after numbers
more faster!
mlambert is offline   Reply With Quote
Old 10-04-2002, 02:42 AM   #3
rayder
Member#: 14535
02 Impreza WRX
hey.. you and i have a very simular setup. Only thing really different would be I am running the Blitz FMIC and the RFL.
Hmmm.... i think i would REALLY like to try your map when you are done. I am sure I will have to compensate for the intercooler. But might be a nice base to play with! Cool beans!
rayder is offline   Reply With Quote
Old 10-04-2002, 02:50 AM   #4
DiMensionX
Member#: 23517
Code:
Dyno Run 1
RPM  TPS  MAP  MLP  MOD   AFR KNOCK
      %   psi       IGN       COUNT
2461 094  +2.9  20 ECU.  13.1 00000
2418 095  +2.5  20 ECU.  12.7 00000
2562 094  +3.1  20 ECU.  12.8 00000
2696 095  +2.9  20 ECU.  13.1 00000
2839 094  +3.3  20 ECU.  12.9 00000
2947 094  +4.1  30 ECU.  13.1 00000
3075 094  +4.3  30 ECU.  12.7 00000
3195 094  +5.7  30 ECU.  12.1 00000
3303 094  +5.1  30 ECU.  12.0 00000
3436 094  +6.4  40 ECU.  rich 00000
3542 094  +9.0  50 ECU.  rich 00000
3695 094  +9.6  50 ECU.  rich 00000
3783 094 +12.1  70 +15.0 rich 00000
3885 094 +13.3  70 +15.0 rich 00000
3977 094 +13.3  70 +15.0 rich 00000
4110 094 +14.7  80 +17.0 rich 00000
4219 094 +13.1  70 +17.0 rich 00000
4340 094 +12.7  70 +19.0 rich 00000
4456 094 +14.1  80 +21.0 rich 00000
4629 094 +14.9  80 +21.0 rich 00000
4681 092 +14.5  80 +21.0 rich 00000
4810 094 +14.5  80 +23.0 rich 00000
4859 092 +13.5  70 +23.0 rich 00000
4990 093 +16.1  90 +23.0 rich 00000
5200 092 +13.1  70 +23.0 rich 00000
5274 091 +14.7  80 +23.0 rich 00000
5299 092 +14.9  80 +23.0 rich 00000
5437 092 +12.9  70 +23.0 rich 00000
5574 092 +14.3  80 +23.0 rich 00000
5688 092 +15.1  80 +23.0 rich 00000
5847 092 +12.3  70 +24.0 rich 00000
5910 092 +10.8  60 ECU.  rich 00000
6082 093 +17.0  90 +25.0 rich 00000
6172 092 +15.9  90 +25.0 rich 00000
6373 092 +11.5  60 ECU.  rich 00000
6361 091 +13.3  70 +25.0 rich 00000
6397 092 +12.9  70 +25.0 rich 00000
6653 091 +11.5  60 ECU.  rich 00000
6613 092 +13.3  70 +25.0 rich 00000
6761 082 +15.1  80 +25.0 rich 00000
6587 000  -4.9  00 ECU.  rich 00000
5963 000 -11.2  00 ECU.  18.0 00000
5411 000 -11.6  00 ECU.  24.2 00000
4975 000 -11.8  00 ECU.  24.2 00000
4578 000 -11.0  00 ECU.  24.2 00000
4145 000 -11.6  00 ECU.  24.5 00000
3766 000 -11.2  00 ECU.  24.2 00000
3475 000 -11.2  00 ECU.  24.2 00000
3112 000 -10.4  00 ECU.  24.5 00000
2808 000 -11.2  00 ECU.  24.2 00000
2521 000 -11.2  00 ECU.  24.5 00000
2243 000 -11.6  00 ECU.  24.2 00000
1973 000 -11.4  00 ECU.  24.2 00000
1823 000 -11.6  00 ECU.  24.2 00000
1621 000 -12.4  00 ECU.  15.6 00000
1381 000 -12.4  00 ECU.  14.0 00000
1152 000 -12.2  00 ECU.  15.4 00000
Old 10-04-2002, 02:52 AM   #5
DiMensionX
Member#: 23517
Code:
Dyno Run 2
      %   psi       IGN       COUNT
2491 030  +0.0  00 ECU.  14.1 00000
2485 040  +0.6  00 ECU.  13.6 00000
2454 060  +1.3  10 ECU.  15.1 00000
2478 089  +1.5  10 ECU.  12.4 00000
2461 091  +1.9  10 ECU.  13.5 00000
2454 092  +2.1  10 ECU.  13.3 00000
2480 094  +2.1  20 ECU.  13.5 00000
2463 094  +2.1  20 ECU.  13.3 00000
2426 095  +1.9  20 ECU.  13.1 00000
2467 095  +2.5  20 ECU.  13.1 00000
2450 094  +2.3  20 ECU.  13.0 00000
2445 095  +2.5  20 ECU.  13.1 00000
2458 095  +2.5  20 ECU.  13.0 00000
2445 094  +2.3  20 ECU.  13.0 00000
2452 094  +2.5  20 ECU.  13.2 00000
2454 095  +2.1  20 ECU.  13.3 00000
2456 094  +2.3  20 ECU.  13.3 00000
2427 094  +2.7  20 ECU.  13.1 00000
2452 095  +2.1  20 ECU.  13.1 00000
2581 094  +2.5  20 ECU.  13.3 00000
2723 095  +2.7  20 ECU.  12.9 00000
2836 094  +2.5  20 ECU.  13.3 00000
2986 095  +3.3  20 ECU.  12.7 00000
3109 095  +3.3  20 ECU.  12.5 00000
3220 094  +3.9  30 ECU.  12.4 00000
3330 094  +4.9  30 ECU.  rich 00000
3443 094  +5.5  30 ECU.  12.2 00000
3588 094  +6.4  40 ECU.  rich 00000
3671 094  +8.2  50 ECU.  rich 00000
3831 093  +8.2  50 ECU.  rich 00000
3880 094 +10.8  60 ECU.  rich 00000
4065 094  +9.6  50 ECU.  rich 00000
4105 094 +11.5  60 ECU.  rich 00000
4192 094 +13.3  70 +17.0 rich 00000
4306 094 +13.7  70 +19.0 rich 00000
4486 093 +14.1  80 +21.0 rich 00000
4649 094 +11.9  70 +21.0 rich 00000
4701 093 +14.9  80 +23.0 rich 00000
4768 093 +14.5  80 +23.0 rich 00000
4923 092 +14.7  80 +23.0 rich 00000
5058 092 +13.3  70 +23.0 rich 00000
5112 092 +13.9  80 +23.0 12.2 00000
5274 093 +14.5  80 +23.0 rich 00000
5393 093 +13.1  70 +23.0 rich 00000
5518 094 +14.5  80 +23.0 rich 00000
5611 094 +14.3  80 +23.0 rich 00000
5668 093 +14.1  80 +23.0 rich 00000
5868 093 +14.9  80 +24.0 rich 00000
6006 092 +13.5  70 +24.0 rich 00000
6060 092 +11.0  60 ECU.  rich 00000
6127 092 +12.3  70 +25.0 rich 00000
6242 093 +11.9  70 +25.0 rich 00000
6349 092 +12.5  70 +25.0 rich 00000
6485 094 +13.7  70 +25.0 rich 00000
6653 094 +11.0  60 ECU.  rich 00000
6666 092 +14.3  80 +25.0 rich 00000
6653 093 +15.1  80 +25.0 rich 00000
6523 000 +10.6  00 ECU.  rich 00000
6242 000 -10.8  00 ECU.  12.6 00000
5630 000 -11.2  00 ECU.  23.7 00000
Old 10-04-2002, 02:54 AM   #6
DiMensionX
Member#: 23517
Code:
Dyno Run 3
      %   psi       IGN       COUNT
2472 099  +1.3  10 ECU.  13.1 00000
2467 100  +1.7  10 ECU.  13.0 00000
2452 099  +1.7  10 ECU.  12.8 00000
2450 100  +2.1  20 ECU.  12.9 00000
2482 100  +2.1  20 ECU.  12.9 00000
2463 100  +2.1  20 ECU.  13.1 00000
2438 100  +2.1  20 ECU.  13.1 00000
2469 100  +2.3  20 ECU.  13.3 00000
2452 100  +2.1  20 ECU.  13.3 00000
2433 100  +2.3  20 ECU.  13.2 00000
2485 100  +2.3  20 ECU.  13.3 00000
2470 100  +2.3  20 ECU.  13.2 00000
2413 100  +2.5  20 ECU.  13.1 00000
2461 100  +2.3  20 ECU.  12.9 00000
2443 100  +2.3  20 ECU.  12.9 00000
2442 100  +2.5  20 ECU.  12.8 00000
2454 100  +2.5  20 ECU.  12.9 00000
2452 100  +2.7  20 ECU.  13.0 00000
2465 100  +2.1  20 ECU.  13.2 00000
2624 101  +2.5  20 ECU.  13.4 00000
2750 100  +2.9  20 ECU.  12.9 00000
2901 100  +2.9  20 ECU.  13.1 00000
3033 101  +2.9  20 ECU.  12.8 00000
3138 100  +3.9  30 ECU.  12.5 00000
3217 100  +4.7  30 ECU.  12.1 00000
3340 100  +4.3  30 ECU.  rich 00000
3479 100  +5.9  40 ECU.  rich 00000
3607 100  +7.6  40 ECU.  rich 00000
3728 100  +6.4  40 ECU.  rich 00000
3818 100  +9.8  60 ECU.  rich 00000
3954 100  +8.8  50 ECU.  rich 00000
4095 100 +10.4  60 ECU.  rich 00000
4151 100 +11.9  70 +17.0 rich 00000
4273 100 +13.1  70 +19.0 rich 00000
4385 099 +13.9  80 +19.0 rich 00000
4522 099 +13.7  70 +21.0 rich 00000
4604 099 +13.1  70 +21.0 rich 00000
4734 098 +12.9  70 +23.0 rich 00000
4880 099 +13.5  70 +23.0 rich 00000
4901 100 +13.7  70 +23.0 rich 00000
5081 099 +12.7  70 +23.0 rich 00000
5184 100 +13.1  70 +23.0 rich 00000
5274 099 +15.9  90 +23.0 rich 00000
5385 099 +15.3  80 +23.0 rich 00000
5500 099 +11.7  60 ECU.  rich 00000
5555 099 +11.3  60 ECU.  rich 00000
5757 099 +14.9  80 +23.0 rich 00000
5807 098 +14.7  80 +24.0 rich 00000
6027 099 +11.7  60 ECU.  rich 00000
6071 099 +12.9  70 +25.0 rich 00000
6161 099 +14.9  80 +25.0 rich 00000
6277 098 +14.9  80 +25.0 rich 00000
6422 098 +15.7  80 +25.0 rich 00000
6447 098 +14.7  80 +25.0 rich 00000
6561 098 +12.9  70 +25.0 rich 00000
6788 099 +14.5  80 +25.0 rich 00000
6872 090 +12.9  70 +25.0 rich 00000
6761 000  -5.9  00 ECU.  rich 00000
6207 000 -11.4  00 ECU.  21.4 00000
Old 10-04-2002, 02:56 AM   #7
DiMensionX
Member#: 23517
Code:
Dyno Run 4
      %   psi       IGN       COUNT
2463 096  +1.9  20 ECU.  12.8 00000
2470 096  +1.9  20 ECU.  12.8 00000
2447 096  +1.7  10 ECU.  12.7 00000
2454 098  +2.1  20 ECU.  12.7 00000
2485 098  +2.1  20 ECU.  12.8 00000
2460 098  +2.3  20 ECU.  12.9 00000
2452 099  +2.1  20 ECU.  12.9 00000
2463 099  +2.5  20 ECU.  13.1 00000
2454 098  +2.1  20 ECU.  13.1 00000
2429 100  +2.5  20 ECU.  13.3 00000
2470 100  +2.5  20 ECU.  13.1 00000
2456 099  +2.3  20 ECU.  13.3 00000
2460 100  +2.1  20 ECU.  12.9 00000
2467 100  +2.9  20 ECU.  12.7 00000
2447 100  +2.5  20 ECU.  12.6 00000
2470 100  +2.7  20 ECU.  12.7 00000
2628 100  +2.5  20 ECU.  12.9 00000
2757 100  +2.7  20 ECU.  13.2 00000
2916 100  +2.5  20 ECU.  13.0 00000
3013 100  +2.7  20 ECU.  12.5 00000
3174 100  +3.1  20 ECU.  12.4 00000
3274 100  +4.5  30 ECU.  12.5 00000
3377 100  +5.9  40 ECU.  rich 00000
3486 100  +6.6  40 ECU.  rich 00000
3646 100  +8.0  50 ECU.  rich 00000
3753 100  +8.6  50 ECU.  rich 00000
3844 100 +11.0  60 ECU.  rich 00000
3963 100 +10.4  60 ECU.  rich 00000
4115 100 +11.7  60 ECU.  rich 00000
4301 100 +11.7  60 ECU.  rich 00000
4273 099 +13.1  70 +19.0 rich 00000
4486 099 +13.1  70 +19.0 rich 00000
4566 100 +14.3  80 +21.0 rich 00000
4708 100 +12.9  70 +21.0 rich 00000
4768 100 +15.1  80 +23.0 rich 00000
4873 100 +12.9  70 +23.0 rich 00000
4997 100 +15.9  90 +23.0 rich 00000
5073 100 +13.3  70 +23.0 rich 00000
5257 098 +14.5  80 +23.0 rich 00000
5299 100 +12.7  70 +23.0 rich 00000
5376 098 +12.9  70 +23.0 rich 00000
5491 099 +12.3  70 +23.0 rich 00000
5678 100 +12.5  70 +23.0 rich 00000
5757 099 +12.7  70 +24.0 rich 00000
5777 100 +12.1  70 +16.0 rich 00000
5941 099 +13.9  80 +16.0 rich 00000
6093 099 +15.3  80 +25.0 rich 00000
6301 099 +15.7  80 +25.0 rich 00000
6325 098 +12.3  70 +25.0 rich 00000
6510 100 +11.7  60 ECU.  rich 00015
6242 099 +15.3  80  +9.0 rich 00000
6613 099 +15.1  80  +9.0 rich 00000
6788 096 +13.1  70 +25.0 rich 00000
6872 000  -5.3  00 ECU.  12.9 00000
6207 000 -10.8  00 ECU.  lean 00000
5630 000 -10.6  00 ECU.  24.2 00000
Old 10-04-2002, 02:58 AM   #8
DiMensionX
Member#: 23517
Code:
Dyno Run 5
      %   psi       IGN       COUNT
2461 096  +1.9  20 ECU.  13.0 00000
2472 098  +1.7  10 ECU.  12.9 00000
2463 099  +1.9  20 ECU.  12.9 00000
2465 100  +2.1  20 ECU.  13.3 00000
2449 101  +2.3  20 ECU.  13.4 00000
2445 100  +2.5  20 ECU.  13.3 00000
2461 101  +2.1  20 ECU.  13.3 00000
2463 101  +2.3  20 ECU.  13.3 00000
2461 100  +2.5  20 ECU.  13.3 00000
2445 101  +1.9  20 ECU.  12.9 00000
2449 101  +2.7  20 ECU.  12.8 00000
2443 100  +2.7  20 ECU.  12.9 00000
2461 101  +2.7  20 ECU.  12.9 00000
2450 101  +2.9  20 ECU.  12.9 00000
2449 100  +2.5  20 ECU.  12.9 00000
2434 101  +2.7  20 ECU.  12.9 00000
2463 101  +2.5  20 ECU.  13.2 00000
2606 101  +2.3  20 ECU.  13.3 00000
2741 101  +2.7  20 ECU.  12.8 00000
2891 101  +3.1  20 ECU.  13.1 00000
2981 100  +3.3  20 ECU.  12.7 00000
3132 101  +4.1  30 ECU.  12.4 00000
3242 101  +3.7  20 ECU.  12.4 00000
3343 101  +5.1  30 ECU.  rich 00000
3494 101  +6.4  40 ECU.  rich 00000
3591 101  +7.0  40 ECU.  rich 00000
3716 101  +7.8  40 ECU.  rich 00000
3818 101 +10.4  60 ECU.  rich 00000
3944 100 +10.6  60 ECU.  rich 00000
3940 100 +11.9  70  +7.0 rich 00000
4084 100 +12.7  70  +9.0 rich 00000
4290 100 +12.3  70 +11.0 rich 00000
4498 100 +12.7  70 +21.0 rich 00000
4559 100 +12.5  70 +21.0 rich 00000
4642 100 +13.1  70 +21.0 rich 00000
4789 100 +14.9  80 +21.0 rich 00000
4873 100 +14.7  80 +23.0 rich 00000
4960 099 +14.7  80 +23.0 rich 00000
5096 101 +13.5  70 +23.0 rich 00000
5175 101 +15.5  80 +23.0 rich 00000
5257 099 +13.3  70 +23.0 rich 00000
5464 100 +16.8  90 +23.0 rich 00000
5500 100 +12.1  70 +23.0 rich 00000
5611 100 +13.7  70 +23.0 rich 00000
5797 100 +11.7  60 ECU.  rich 00000
5837 101 +12.1  70 +24.0 rich 00000
5910 100 +12.1  70 +24.0 rich 00000
6093 099 +11.5  60 ECU.  rich 00000
6138 099 +14.1  80 +25.0 rich 00000
6242 100 +11.9  70 +25.0 rich 00000
6422 100 +16.4  90 +25.0 rich 00000
6410 100 +15.1  80 +25.0 rich 00000
6626 100 +11.9  70 +25.0 rich 00000
6653 100 +13.3  70 +25.0 rich 00000
6680 100 +13.7  70 +25.0 rich 00000
6706 000 +11.3  00 ECU.  rich 00000
6207 000 -10.0  00 ECU.  14.4 00000
Old 10-04-2002, 03:01 AM   #9
DiMensionX
Member#: 23517
Code:
Dyno Run 6
      %   psi       IGN       COUNT
2456 094  +1.7  10 ECU.  rich 00000
2456 095  +1.7  10 ECU.  rich 00000
2454 096  +1.7  10 ECU.  rich 00000
2449 098  +2.1  20 ECU.  rich 00000
2450 098  +2.1  20 ECU.  rich 00000
2454 099  +1.9  20 ECU.  rich 00000
2431 101  +2.3  20 ECU.  rich 00000
2469 100  +2.1  20 ECU.  rich 00000
2461 101  +1.9  20 ECU.  rich 00000
2454 101  +2.7  20 ECU.  rich 00000
2449 101  +2.3  20 ECU.  rich 00000
2447 101  +2.1  20 ECU.  rich 00000
2447 101  +2.3  20 ECU.  rich 00000
2485 101  +2.3  20 ECU.  rich 00000
2456 101  +2.3  20 ECU.  rich 00000
2436 102  +2.1  20 ECU.  rich 00000
2470 101  +2.7  20 ECU.  rich 00000
2668 101  +2.1  20 ECU.  rich 00000
2766 101  +2.5  20 ECU.  rich 00000
2929 101  +2.7  20 ECU.  rich 00000
3003 101  +3.1  20 ECU.  rich 00000
3135 101  +3.7  20 ECU.  rich 00000
3252 101  +4.1  30 ECU.  rich 00000
3360 101  +5.1  30 ECU.  rich 00000
3479 100  +4.7  30 ECU.  rich 00000
3591 101  +7.2  40 ECU.  rich 00000
3728 100  +8.4  50 ECU.  rich 00000
3840 100 +10.0  60 ECU.  rich 00000
3949 100 +11.3  60 ECU.  rich 00000
4040 099 +12.5  70 +17.0 rich 00000
4156 100 +12.1  70 +17.0 rich 00000
4273 099 +11.9  70 +19.0 rich 00000
4385 100 +12.3  70 +19.0 rich 00000
4578 100 +14.1  80 +21.0 rich 00000
4708 100 +14.3  80 +21.0 rich 00000
4734 101 +11.9  70 +23.0 rich 00000
4830 099 +15.3  80 +23.0 rich 00000
4938 100 +15.7  80 +23.0 rich 00000
5027 100 +16.1  90 +23.0 rich 00000
5167 099 +11.0  60 ECU.  rich 00000
5316 101 +16.4  90 +23.0 12.2 00000
5402 100 +16.8  90 +23.0 12.5 00000
5707 100 +14.9  80 +23.0 12.4 00000
5649 100 +15.3  80 +23.0 rich 00000
5777 098 +16.1  90 +24.0 rich 00000
5817 100 +14.5  80 +25.0 rich 00000
5963 100 +14.9  80 +24.0 rich 00000
6138 100 +13.3  70 +25.0 rich 00000
6195 100 +15.9  90 +25.0 rich 00000
6230 099 +12.3  70 +25.0 rich 00000
6435 098 +15.3  80 +25.0 rich 00000
6600 099 +11.5  60 ECU.  rich 00000
6706 100 +12.1  70 +25.0 rich 00000
6747 100 +11.3  60 ECU.  rich 00000
6706 100 +12.7  70 +25.0 rich 00000
6775 000  +0.8  00 ECU.  rich 00000
Old 10-04-2002, 03:03 AM   #10
DiMensionX
Member#: 23517
Code:
Dyno Run 7
      %   psi       IGN       COUNT
2478 097  +2.1  20 ECU.  rich 00000
2465 097  +1.9  20 ECU.  rich 00000
2436 098  +1.9  20 ECU.  rich 00000
2465 099  +2.3  20 ECU.  rich 00000
2476 099  +2.1  20 ECU.  rich 00000
2424 100  +1.9  20 ECU.  rich 00000
2461 100  +2.5  20 ECU.  rich 00000
2463 100  +2.5  20 ECU.  rich 00000
2443 100  +2.5  20 ECU.  rich 00000
2449 100  +2.5  20 ECU.  rich 00000
2465 100  +2.9  20 ECU.  rich 00000
2465 101  +2.3  20 ECU.  rich 00000
2456 100  +2.3  20 ECU.  rich 00000
2442 100  +2.9  20 ECU.  rich 00000
2616 100  +2.3  20 ECU.  rich 00000
2759 101  +2.9  20 ECU.  rich 00000
2844 100  +3.1  20 ECU.  rich 00000
3005 101  +3.1  20 ECU.  rich 00000
3103 100  +4.5  30 ECU.  rich 00000
3233 101  +4.5  30 ECU.  rich 00000
3370 100  +5.3  30 ECU.  rich 00000
3450 100  +5.9  40 ECU.  rich 00000
3607 100  +7.4  40 ECU.  rich 00000
3728 100  +9.6  50 ECU.  rich 00000
3766 100  +8.0  50 ECU.  rich 00000
3903 100 +10.4  60 ECU.  rich 00000
4016 098 +11.5  60 ECU.  rich 00000
4110 099 +13.3  70 +17.0 rich 00000
4257 100 +12.9  70 +17.0 rich 00000
4462 100 +13.1  70 +19.0 rich 00000
4616 100 +11.5  60 ECU.  rich 00000
4675 099 +14.5  80 +21.0 rich 00000
4694 100 +14.9  80 +23.0 rich 00000
4803 100 +15.5  80 +23.0 rich 00000
4887 099 +15.1  80 +23.0 rich 00000
5050 100 +15.9  90 +23.0 rich 00000
5184 100 +15.1  80 +23.0 rich 00000
5241 100 +16.8  90 +23.0 rich 00000
5385 100 +15.5  80 +23.0 rich 00000
5678 099 +16.4  90 +23.0 rich 00000
5717 099 +13.9  80 +23.0 rich 00000
5837 099 +14.7  80 +24.0 rich 00000
6016 099 +14.9  80 +24.0 rich 00000
6138 098 +14.7  80 +25.0 rich 00000
6161 099 +14.3  80 +25.0 rich 00000
6325 100 +10.6  60 ECU.  rich 00000
6510 100 +12.9  70 +25.0 rich 00000
6734 099 +13.3  70 +25.0 rich 00000
6693 100 +14.7  80 +25.0 rich 00000
6802 100 +14.5  80 +25.0 rich 00000
6523 000  -3.4  00 ECU.  rich 00000
Old 10-04-2002, 03:05 AM   #11
DiMensionX
Member#: 23517
Code:
Dyno Run 8
      %   psi       IGN       COUNT
2470 096  +1.7  10 ECU.  rich 00000
2458 096  +1.7  10 ECU.  rich 00000
2442 097  +2.1  20 ECU.  rich 00000
2474 098  +2.1  20 ECU.  rich 00000
2463 098  +2.1  20 ECU.  rich 00000
2465 098  +2.7  20 ECU.  rich 00000
2470 099  +2.5  20 ECU.  rich 00000
2454 099  +2.3  20 ECU.  rich 00000
2427 098  +2.5  20 ECU.  rich 00000
2450 100  +2.1  20 ECU.  rich 00000
2458 098  +2.3  20 ECU.  rich 00000
2449 099  +2.3  20 ECU.  rich 00000
2465 100  +2.5  20 ECU.  rich 00000
2458 099  +2.5  20 ECU.  rich 00000
2454 099  +2.7  20 ECU.  rich 00000
2434 100  +2.5  20 ECU.  rich 00000
2469 100  +2.7  20 ECU.  rich 00000
2452 099  +2.5  20 ECU.  rich 00000
2424 100  +2.3  20 ECU.  rich 00000
2493 099  +2.7  20 ECU.  rich 00000
2660 100  +2.3  20 ECU.  rich 00000
2791 099  +2.9  20 ECU.  rich 00000
2893 100  +3.1  20 ECU.  rich 00000
3027 100  +3.5  20 ECU.  rich 00000
3165 099  +4.5  30 ECU.  rich 00000
3280 100  +4.9  30 ECU.  rich 00000
3415 099  +5.5  30 ECU.  rich 00000
3483 099  +7.6  40 ECU.  rich 00000
3623 099  +8.0  50 ECU.  rich 00000
3736 099  +8.8  50 ECU.  rich 00000
3853 099 +12.1  70 +15.0 rich 00000
4016 098 +14.1  80 +17.0 rich 00000
4110 098 +14.3  80 +17.0 rich 00000
4182 098 +14.9  80 +17.0 rich 00000
4312 098 +18.2 100 +19.0 rich 00000
4492 099 +15.9  90 +21.0 rich 00000
4535 099 +18.4 100 +21.0 rich 00000
4668 099 +18.0 100 +21.0 rich 00000
4775 099 +20.4 100 +23.0 rich 00000
4923 098 +15.5  80 +23.0 rich 00000
4923 098 +17.0  90 +23.0 rich 00000
5089 098 +14.1  80 +23.0 rich 00000
5184 099 +17.6  90 +23.0 rich 00000
5324 099 +18.2 100 +23.0 rich 00000
5428 098 +15.7  80 +23.0 rich 00000
5500 098 +16.4  90 +23.0 rich 00000
5707 098 +16.6  90 +23.0 rich 00000
5777 098 +14.1  80 +24.0 rich 00000
5931 098 +15.1  80 +24.0 rich 00000
6016 098 +13.9  80 +24.0 rich 00000
6105 098 +18.6 100 +25.0 rich 00000
6207 098 +14.3  80 +25.0 rich 00000
6277 098 +17.0  90 +25.0 rich 00000
6373 097 +16.1  90 +25.0 rich 00000
6574 098 +12.7  70 +25.0 rich 00000
6666 098 +14.7  80 +25.0 rich 00000
6680 098 +15.1  80 +25.0 rich 00000
6844 098 +17.0  90 +25.0 rich 00000
6887 000  -5.3  00 ECU.  rich 00000
Old 10-04-2002, 03:07 AM   #12
DiMensionX
Member#: 23517
Code:
Dyno Run 9
      %   psi       IGN       COUNT
2470 098  +2.9  20 ECU.  rich 00000
2469 098  +2.9  20 ECU.  rich 00000
2456 098  +2.7  20 ECU.  rich 00000
2449 099  +2.7  20 ECU.  rich 00000
2478 100  +2.9  20 ECU.  rich 00000
2458 099  +2.7  20 ECU.  rich 00000
2426 100  +2.7  20 ECU.  rich 00000
2454 100  +3.1  20 ECU.  rich 00000
2443 099  +2.7  20 ECU.  rich 00000
2436 100  +3.1  20 ECU.  rich 00000
2465 100  +3.1  20 ECU.  rich 00000
2460 100  +3.1  20 ECU.  rich 00000
2469 100  +3.5  20 ECU.  rich 00000
2447 101  +2.7  20 ECU.  rich 00000
2452 100  +3.1  20 ECU.  rich 00000
2525 100  +3.1  20 ECU.  rich 00000
2688 101  +3.3  20 ECU.  rich 00000
2796 100  +3.3  20 ECU.  rich 00000
2952 100  +3.7  20 ECU.  rich 00000
3069 100  +4.3  30 ECU.  rich 00000
3183 101  +4.9  30 ECU.  rich 00000
3306 100  +5.7  30 ECU.  rich 00000
3415 101  +7.0  40 ECU.  rich 00000
3542 100  +7.8  40 ECU.  rich 00000
3667 101  +9.6  50 ECU.  rich 00000
3741 100 +11.9  70 +15.0 rich 00000
3903 100 +14.1  80 +15.0 rich 00000
3963 100 +14.7  80 +15.0 rich 00000
4100 100 +17.6  90 +17.0 rich 00000
4192 100 +18.6 100 +17.0 rich 00000
4351 100 +18.6 100 +19.0 rich 00000
4432 100 +17.4  90 +19.0 rich 00000
4616 100 +19.2 100 +21.0 rich 00000
4721 100 +18.0 100 +21.0 rich 00000
4775 099 +17.8 100 +23.0 rich 00000
4844 100 +19.0 100 +23.0 rich 00000
4923 099 +19.0 100 +23.0 rich 00000
5167 100 +18.0 100 +23.0 rich 00000
5216 099 +20.4 100 +23.0 rich 00000
5350 100 +16.4  90 +23.0 rich 00000
5437 099 +19.2 100 +23.0 rich 00000
5537 100 +19.4 100 +23.0 rich 00000
5630 100 +15.5  80 +23.0 rich 00000
6150 100 +14.3  80 +23.0 rich 00000
5889 099 +18.0 100 +24.0 rich 00000
6038 100 +16.1  90 +25.0 rich 00000
6195 099 +16.8  90 +25.0 rich 00000
6325 100 +17.6  90 +25.0 rich 00000
6325 099 +16.6  90 +25.0 rich 00000
6373 099 +16.4  90 +25.0 rich 00000
6626 099 +15.1  80 +25.0 rich 00000
6640 099 +17.4  90 +25.0 rich 00000
6693 099 +14.9  80 +25.0 rich 00000
6844 000 +16.1  00 ECU.  rich 00000
6349 000 -11.0  00 ECU.  13.8 00000
Old 10-04-2002, 03:13 AM   #13
DiMensionX
Member#: 23517
Code:
Dyno Run 10
      %   psi       IGN       COUNT
2489 098  +2.1  20 ECU.  12.2 00000
2487 099  +2.5  20 ECU.  rich 00000
2450 100  +2.3  20 ECU.  rich 00000
2450 100  +2.7  20 ECU.  rich 00000
2445 100  +2.5  20 ECU.  rich 00000
2433 101  +2.7  20 ECU.  rich 00000
2463 100  +2.7  20 ECU.  rich 00000
2467 100  +2.5  20 ECU.  rich 00000
2467 101  +2.7  20 ECU.  rich 00000
2482 101  +3.3  20 ECU.  rich 00000
2443 100  +2.9  20 ECU.  rich 00000
2434 100  +2.9  20 ECU.  rich 00000
2463 100  +2.9  20 ECU.  rich 00000
2450 100  +2.9  20 ECU.  rich 00000
2447 101  +2.9  20 ECU.  rich 00000
2568 100  +2.9  20 ECU.  rich 00000
2710 101  +2.9  20 ECU.  rich 00000
2846 100  +3.3  20 ECU.  rich 00000
2978 100  +4.1  30 ECU.  rich 00000
3060 101  +4.1  30 ECU.  rich 00000
3223 101  +5.3  30 ECU.  rich 00000
3316 100  +5.5  30 ECU.  rich 00000
3439 101  +6.8  40 ECU.  rich 00000
3538 101  +6.6  40 ECU.  rich 00000
3695 100  +9.6  50 ECU.  rich 00000
3796 100 +10.0  60 ECU.  rich 00000
3885 100 +12.5  70 +15.0 rich 00000
4006 100 +14.9  80 +17.0 rich 00000
4140 100 +18.6 100 +17.0 rich 00000
4192 100 +16.6  90 +19.0 rich 00000
4462 100 +16.6  90 +19.0 rich 00000
4426 099 +18.8 100 +21.0 13.2 00000
4438 100 +18.2 100 +13.0 13.5 00000
4610 100 +17.6  90 +13.0 13.4 00000
4887 100 +17.2  90 +15.0 12.2 00000
4990 100 +19.4 100 +23.0 rich 00000
5005 100 +17.2  90 +23.0 rich 00000
5144 100 +13.9  80 +23.0 rich 00000
5232 099 +15.1  80 +23.0 rich 00024
5341 099 +16.6  90 +15.0 rich 00000
5455 100 +15.1  80 +15.0 rich 00000
5546 100 +18.2 100 +21.0 rich 00000
5668 099 +15.5  80 +23.0 rich 00000
5868 099 +14.5  80 +24.0 rich 00000
5952 099 +16.8  90 +25.0 rich 00000
6049 100 +14.1  80 +25.0 rich 00000
6138 099 +16.6  90 +25.0 rich 00000
6361 099 +13.1  70 +25.0 rich 00000
6410 099 +13.5  70 +25.0 rich 00000
6373 099 +15.9  90 +25.0 rich 00000
6680 099 +15.1  80 +17.0 rich 00000
6747 100 +14.1  80 +17.0 rich 00000
6626 100 +15.1  80 +17.0 rich 00000
6706 000  -3.6  00 ECU.  rich 00000
Old 10-04-2002, 03:15 AM   #14
DiMensionX
Member#: 23517
Code:
Dyno Run 11
      %   psi       IGN       COUNT
2445 098  +2.7  20 ECU.  rich 00000
2438 098  +2.7  20 ECU.  rich 00000
2445 098  +2.3  20 ECU.  rich 00000
2450 099  +2.5  20 ECU.  rich 00000
2482 099  +2.5  20 ECU.  rich 00000
2461 099  +2.5  20 ECU.  rich 00000
2465 100  +2.7  20 ECU.  rich 00000
2445 099  +2.7  20 ECU.  rich 00000
2440 100  +2.7  20 ECU.  rich 00000
2472 100  +2.9  20 ECU.  rich 00000
2467 101  +3.5  20 ECU.  rich 00000
2474 101  +3.3  20 ECU.  rich 00000
2433 100  +2.9  20 ECU.  12.5 00000
2443 101  +2.7  20 ECU.  rich 00000
2461 100  +2.9  20 ECU.  rich 00000
2630 100  +2.7  20 ECU.  rich 00000
2752 100  +3.1  20 ECU.  rich 00000
2908 101  +3.5  20 ECU.  rich 00000
3049 101  +3.5  20 ECU.  rich 00000
3138 101  +4.7  30 ECU.  rich 00000
3271 101  +5.3  30 ECU.  rich 00000
3353 101  +5.9  40 ECU.  rich 00000
3472 101  +7.2  40 ECU.  rich 00000
3607 101  +8.8  50 ECU.  rich 00000
3716 100 +10.6  60 ECU.  rich 00000
3849 100 +11.5  60 ECU.  rich 00000
3935 100 +13.9  80 +15.0 rich 00000
4105 100 +16.1  90 +17.0 rich 00000
4135 100 +15.9  90 +17.0 rich 00000
4295 100 +18.2 100 +19.0 rich 00000
4340 100 +16.8  90 +19.0 rich 00000
4559 100 +17.4  90 +13.0 13.1 00000
4642 100 +19.8 100 +13.0 rich 00000
4714 100 +19.2 100 +15.0 rich 00000
4803 100 +19.6 100 +15.0 rich 00000
4990 100 +20.2 100 +23.0 rich 00000
5081 099 +19.6 100 +23.0 rich 00000
5136 100 +15.1  80 +23.0 rich 00000
5307 100 +19.4 100 +23.0 rich 00000
5509 100 +20.0 100 +23.0 rich 00000
5482 100 +17.4  90 +23.0 rich 00000
5574 099 +16.6  90 +23.0 rich 00000
5727 098 +18.2 100 +23.0 rich 00000
5858 100 +17.2  90 +25.0 rich 00000
5995 100 +14.9  80 +25.0 rich 00000
6127 099 +19.0 100 +25.0 rich 00000
6116 100 +13.9  80 +17.0 rich 00000
6230 099 +18.4 100 +17.0 rich 00000
6385 100 +17.2  90 +25.0 rich 00000
6548 100 +15.3  80 +25.0 rich 00000
6600 098 +18.4 100 +25.0 rich 00000
6720 100 +14.9  80 +17.0 rich 00000
7002 008 +14.3  00 ECU.  rich 00000
6548 000  -7.7  00 ECU.  12.8 00000
Old 10-04-2002, 03:17 AM   #15
DiMensionX
Member#: 23517
Code:
Dyno Run 12
      %   psi       IGN       COUNT
2495 027  -0.8  00 ECU.  14.8 00000
2523 031  +0.6  00 ECU.  14.1 00000
2495 054  +1.1  00 ECU.  12.9 00000
2460 086  +1.7  10 ECU.  15.5 00000
2467 095  +2.1  20 ECU.  rich 00000
2478 098  +2.1  20 ECU.  rich 00000
2458 098  +2.5  20 ECU.  rich 00000
2450 100  +2.5  20 ECU.  rich 00000
2476 101  +2.7  20 ECU.  rich 00000
2454 100  +2.7  20 ECU.  rich 00000
2463 100  +3.3  20 ECU.  rich 00000
2460 101  +2.9  20 ECU.  rich 00000
2449 101  +2.5  20 ECU.  rich 00000
2426 101  +2.9  20 ECU.  rich 00000
2442 101  +2.9  20 ECU.  rich 00000
2458 101  +3.1  20 ECU.  rich 00000
2454 101  +3.1  20 ECU.  rich 00000
2529 101  +3.1  20 ECU.  rich 00000
2701 101  +2.9  20 ECU.  rich 00000
2824 101  +3.3  20 ECU.  rich 00000
2949 101  +3.3  20 ECU.  rich 00000
3066 101  +4.1  30 ECU.  rich 00000
3202 102  +4.3  30 ECU.  rich 00000
3313 101  +5.7  30 ECU.  rich 00000
3422 102  +6.8  40 ECU.  rich 00000
3553 101  +5.9  40 ECU.  rich 00000
3683 101  +9.6  50 ECU.  rich 00000
3741 101 +12.1  70 +15.0 rich 00000
3875 101 +14.1  80 +15.0 rich 00000
4011 101 +13.3  70 +17.0 rich 00000
4100 101 +18.0 100 +17.0 rich 00000
4208 100 +15.9  90 +17.0 rich 00000
4345 102 +17.6  90 +19.0 rich 00000
4385 101 +19.2 100 +19.0 14.6 00000
4694 101 +17.0  90 +19.0 16.0 00016
4708 101 +18.6 100 +13.0 rich 00000
4755 100 +15.7  80 +15.0 rich 00000
4816 100 +17.0  90 +15.0 rich 00000
5050 100 +19.4 100 +23.0 rich 00000
5175 101 +17.0  90 +23.0 rich 00000
5192 100 +17.2  90 +23.0 rich 00000
5333 100 +19.2 100 +23.0 rich 00000
5518 100 +17.6  90 +23.0 rich 00000
5527 100 +18.2 100 +23.0 rich 00000
5659 100 +14.3  80 +23.0 rich 00000
5837 100 +14.9  80 +24.0 rich 00000
5973 101 +18.8 100 +25.0 rich 00000
6105 100 +15.1  80 +25.0 rich 00000
6116 100 +16.6  90 +17.0 rich 00000
6230 101 +17.0  90 +17.0 rich 00000
6373 100 +13.9  80 +25.0 rich 00000
6447 101 +16.4  90 +25.0 rich 00000
6693 100 +17.0  90 +25.0 rich 00000
6720 100 +13.3  70 +25.0 rich 00000
6640 100 +14.5  80 +25.0 rich 00000
7215 000 +14.5  00 ECU.  rich 00000
6720 000  -9.4  00 ECU.  21.4 00000
Old 10-04-2002, 03:20 AM   #16
DiMensionX
Member#: 23517
Code:
Dyno Run 13
      %   psi       IGN       COUNT
2449 099  +2.5  20 ECU.  rich 00000
2418 100  +2.5  20 ECU.  rich 00000
2456 100  +2.9  20 ECU.  rich 00000
2445 100  +2.7  20 ECU.  rich 00000
2449 100  +2.7  20 ECU.  rich 00000
2460 100  +2.7  20 ECU.  rich 00000
2458 100  +3.3  20 ECU.  rich 00000
2445 101  +2.7  20 ECU.  rich 00000
2449 100  +3.1  20 ECU.  rich 00000
2445 101  +2.9  20 ECU.  rich 00000
2458 100  +3.1  20 ECU.  rich 00000
2438 101  +3.3  20 ECU.  rich 00000
2458 100  +2.9  20 ECU.  rich 00000
2594 101  +2.9  20 ECU.  rich 00000
2707 100  +2.5  20 ECU.  rich 00000
2853 101  +3.7  20 ECU.  rich 00000
2929 100  +3.3  20 ECU.  rich 00000
3069 101  +3.1  20 ECU.  rich 00000
3220 101  +5.3  30 ECU.  rich 00000
3316 100  +5.7  30 ECU.  rich 00000
3443 101  +7.6  40 ECU.  rich 00000
3591 101  +8.4  50 ECU.  rich 00000
3687 101  +7.6  40 ECU.  rich 00000
3770 100 +11.5  60 ECU.  rich 00000
4011 100 +15.3  80 +17.0 rich 00000
4161 100 +17.4  90 +17.0 rich 00000
4278 100 +16.1  90 +17.0 rich 00000
4357 100 +17.4  90 +19.0 rich 00000
4486 101 +17.6  90 +11.0 12.5 00000
4559 100 +21.5 100 +13.0 rich 00000
4714 100 +20.6 100 +13.0 rich 00000
4755 100 +19.2 100 +15.0 rich 00000
4859 100 +18.0 100 +15.0 rich 00000
4997 099 +18.6 100 +15.0 rich 00000
5128 100 +16.4  90 +15.0 rich 00000
5299 100 +18.2 100 +15.0 rich 00000
5420 100 +15.9  90 +15.0 rich 00000
5537 100 +13.5  70 +15.0 rich 00000
5592 100 +18.8 100 +23.0 rich 00000
5698 100 +18.6 100 +23.0 rich 00000
5837 098 +15.7  80 +24.0 rich 00000
5973 100 +17.6  90 +25.0 rich 00000
6071 100 +14.9  80 +21.0 rich 00002
6218 100 +17.8 100 +17.0 rich 00000
6301 099 +17.8 100 +17.0 rich 00000
6497 100 +17.0  90 +25.0 rich 00000
6397 100 +15.5  80 +25.0 rich 00000
6510 100 +15.3  80 +17.0 rich 00000
6720 099 +17.4  90 +17.0 rich 00000
6680 100 +15.7  80 +25.0 rich 00000
7168 000 +12.9  00 ECU.  rich 00000
Old 10-04-2002, 03:21 AM   #17
DiMensionX
Member#: 23517
Code:
Dyno Run 14
      %   psi       IGN       COUNT
2469 099  +2.5  20 ECU.  rich 00000
2467 100  +3.3  20 ECU.  rich 00000
2449 100  +3.3  20 ECU.  rich 00000
2440 100  +3.1  20 ECU.  rich 00000
2456 100  +3.1  20 ECU.  rich 00000
2460 100  +3.3  20 ECU.  rich 00000
2447 100  +3.1  20 ECU.  rich 00000
2443 100  +3.5  20 ECU.  rich 00000
2513 101  +3.3  20 ECU.  rich 00000
2675 101  +3.5  20 ECU.  rich 00000
2815 101  +3.3  20 ECU.  rich 00000
2901 101  +4.1  30 ECU.  rich 00000
3052 100  +4.7  30 ECU.  rich 00000
3159 101  +5.9  40 ECU.  rich 00000
3280 100  +6.2  40 ECU.  rich 00000
3443 101  +7.8  40 ECU.  rich 00000
3512 100  +8.0  50 ECU.  rich 00000
3658 101 +10.2  60 ECU.  rich 00000
3770 100 +12.9  70 +15.0 rich 00000
3885 100 +14.5  80 +15.0 rich 00000
4001 100 +15.5  80 +15.0 rich 00000
4084 100 +16.1  90 +17.0 rich 00000
4187 100 +18.6 100 +17.0 rich 00000
4312 100 +15.7  80 +19.0 rich 00000
4468 100 +18.4 100 +19.0 rich 00000
4578 100 +19.0 100 +13.0 rich 00000
4636 100 +21.0 100 +13.0 rich 00000
4796 100 +20.2 100 +15.0 rich 00000
4930 100 +19.2 100 +15.0 rich 00000
4967 100 +16.8  90 +15.0 rich 00000
5081 099 +16.8  90 +15.0 rich 00000
5184 100 +18.0 100 +15.0 rich 00000
5402 099 +16.8  90 +23.0 rich 00000
5402 100 +16.1  90 +15.0 rich 00000
5482 100 +19.8 100 +15.0 rich 00000
5630 100 +14.9  80 +19.0 rich 00000
5847 098 +20.2 100 +24.0 rich 00000
6016 100 +17.2  90 +24.0 rich 00000
6060 100 +13.1  70 +25.0 rich 00000
6150 100 +17.4  90 +17.0 rich 00000
6301 100 +18.2 100 +17.0 rich 00000
6373 100 +14.3  80 +17.0 rich 00000
6485 100 +14.7  80 +25.0 rich 00000
6600 100 +14.1  80 +17.0 rich 00000
6693 100 +13.1  70 +17.0 rich 00000
6640 098 +14.7  80 +19.0 rich 00000
7246 008 +15.1  00 ECU.  rich 00000
6872 000  -8.5  00 ECU.  15.4 00000
Old 10-04-2002, 03:23 AM   #18
DiMensionX
Member#: 23517
Code:
Dyno Run 15
      %   psi       IGN       COUNT
2454 096  +2.3  20 ECU.  rich 00000
2442 098  +2.3  20 ECU.  rich 00000
2447 097  +2.1  20 ECU.  rich 00000
2440 098  +2.5  20 ECU.  rich 00000
2454 098  +2.7  20 ECU.  rich 00000
2445 098  +2.5  20 ECU.  rich 00000
2436 098  +2.7  20 ECU.  rich 00000
2445 099  +2.9  20 ECU.  rich 00000
2463 098  +2.9  20 ECU.  rich 00000
2467 099  +2.7  20 ECU.  rich 00000
2596 099  +3.1  20 ECU.  rich 00000
2738 099  +2.9  20 ECU.  rich 00000
2866 100  +3.3  20 ECU.  rich 00000
3000 099  +3.3  20 ECU.  rich 00000
3112 099  +4.1  30 ECU.  rich 00000
3236 099  +5.3  30 ECU.  rich 00000
3370 099  +6.2  40 ECU.  rich 00000
3472 099  +7.6  40 ECU.  rich 00000
3603 100  +8.6  50 ECU.  rich 00000
3720 099  +9.6  50 ECU.  rich 00000
3787 099 +11.5  60 ECU.  rich 00000
3912 098 +12.7  70 +15.0 rich 00000
4040 099 +15.1  80 +17.0 rich 00000
4192 098 +18.2 100 +17.0 rich 00000
4306 098 +16.6  90 +17.0 rich 00000
4391 098 +18.8 100 +19.0 rich 00000
4547 099 +18.4 100 +21.0 rich 00000
4510 098 +15.9  90 +13.0 rich 00000
4662 098 +19.4 100 +13.0 rich 00000
4823 099 +18.6 100 +15.0 rich 00000
4894 098 +17.4  90 +21.0 rich 00000
5096 098 +17.2  90 +23.0 rich 00000
5136 099 +18.8 100 +15.0 rich 00000
5257 099 +19.2 100 +15.0 rich 00000
5464 098 +14.9  80 +15.0 rich 00000
5583 098 +17.2  90 +23.0 rich 00000
5698 099 +19.2 100 +23.0 rich 00000
5737 098 +14.7  80 +24.0 rich 00000
5787 099 +15.3  80 +24.0 rich 00000
5858 099 +18.2 100 +16.0 rich 00000
6105 098 +18.4 100 +17.0 rich 00000
6161 099 +13.9  80 +17.0 rich 00000
6253 098 +14.5  80 +25.0 rich 00000
6361 098 +16.1  90 +17.0 rich 00000
6548 099 +17.0  90 +17.0 rich 00000
6775 099 +16.4  90 +17.0 rich 00000
6734 098 +16.4  90 +25.0 rich 00000
6720 099 +13.7  70 +17.0 rich 00000
6830 021 +13.7  00 ECU.  rich 00000
6485 000  -8.7  00 ECU.  13.0 00000
Old 10-04-2002, 03:26 AM   #19
DiMensionX
Member#: 23517
Code:
Dyno Run 16
      %   psi       IGN       COUNT
2461 098  +2.1  20 ECU.  rich 00000
2431 098  +2.3  20 ECU.  rich 00000
2460 099  +2.1  20 ECU.  rich 00000
2461 098  +2.3  20 ECU.  rich 00000
2450 098  +2.7  20 ECU.  rich 00000
2438 098  +2.5  20 ECU.  rich 00000
2447 099  +2.3  20 ECU.  rich 00000
2483 099  +2.3  20 ECU.  rich 00000
2447 098  +2.3  20 ECU.  rich 00000
2415 099  +2.3  20 ECU.  rich 00000
2460 100  +2.5  20 ECU.  rich 00000
2447 098  +2.5  20 ECU.  rich 00000
2442 098  +2.5  20 ECU.  rich 00000
2529 099  +2.5  20 ECU.  rich 00000
2668 098  +2.9  20 ECU.  rich 00000
2777 099  +2.5  20 ECU.  rich 00000
2934 099  +2.9  20 ECU.  rich 00000
3049 099  +3.3  20 ECU.  rich 00000
3144 099  +4.3  30 ECU.  rich 00000
3264 099  +4.9  30 ECU.  rich 00000
3422 100  +5.7  30 ECU.  rich 00000
3531 099  +7.2  40 ECU.  rich 00000
3639 098  +7.4  40 ECU.  rich 00000
3741 100 +10.2  60 ECU.  rich 00000
3894 099 +11.0  60 ECU.  rich 00000
3958 098 +14.3  80 +15.0 rich 00000
4105 099 +16.8  90 +17.0 rich 00000
4208 098 +16.6  90 +17.0 rich 00000
4351 099 +20.2 100 +19.0 rich 00000
4462 099 +19.4 100 +19.0 rich 00000
4578 098 +18.6 100 +21.0 rich 00000
4681 099 +18.0 100 +13.0 rich 00000
4701 098 +17.4  90 +15.0 rich 00000
4852 098 +20.8 100 +15.0 rich 00000
5120 098 +17.2  90 +23.0 rich 00000
5073 098 +18.0 100 +23.0 rich 00000
5224 099 +18.6 100 +23.0 rich 00000
5299 099 +19.4 100 +23.0 rich 00000
5437 097 +17.4  90 +23.0 rich 00000
5574 098 +15.7  80 +23.0 rich 00000
5668 098 +19.2 100 +23.0 rich 00000
5707 098 +17.2  90 +15.0 rich 00000
5889 098 +16.6  90 +16.0 rich 00000
6027 098 +15.5  80 +17.0 rich 00000
6127 098 +20.4 100 +25.0 rich 00000
6289 098 +15.3  80 +17.0 rich 00000
6301 098 +19.6 100 +17.0 rich 00000
6600 098 +17.8 100 +25.0 rich 00000
6561 098 +15.5  80 +25.0 rich 00000
6613 099 +14.1  80 +17.0 rich 00000
6693 098 +13.1  70 +17.0 rich 00000
6816 060 +14.9  80 +25.0 rich 00000
6361 000  -7.7  00 ECU.  12.2 00000
Old 10-04-2002, 03:29 AM   #20
DiMensionX
Member#: 23517
Code:
Dyno Run 17
      %   psi       IGN       COUNT
2472 099  +2.5  20 ECU.  rich 00000
2482 098  +2.5  20 ECU.  rich 00000
2452 098  +2.7  20 ECU.  rich 00000
2440 099  +2.7  20 ECU.  rich 00000
2452 099  +2.9  20 ECU.  rich 00000
2449 099  +2.9  20 ECU.  rich 00000
2429 100  +3.1  20 ECU.  rich 00000
2478 100  +3.1  20 ECU.  rich 00000
2461 100  +3.1  20 ECU.  rich 00000
2418 100  +2.7  20 ECU.  rich 00000
2469 100  +3.3  20 ECU.  rich 00000
2450 100  +3.1  20 ECU.  rich 00000
2440 100  +3.5  20 ECU.  rich 00000
2500 100  +3.5  20 ECU.  rich 00000
2641 100  +3.3  20 ECU.  rich 00000
2775 101  +3.3  20 ECU.  rich 00000
2923 101  +3.7  20 ECU.  rich 00000
3019 100  +4.5  30 ECU.  rich 00000
3162 100  +5.5  30 ECU.  rich 00000
3274 100  +5.7  30 ECU.  rich 00000
3429 100  +6.4  40 ECU.  rich 00000
3538 100  +8.4  50 ECU.  rich 00000
3631 100 +10.2  60 ECU.  rich 00000
3745 100 +12.1  70 +15.0 rich 00000
3889 100 +14.5  80 +15.0 rich 00000
3982 100 +15.1  80 +15.0 rich 00000
4070 099 +16.8  90 +17.0 rich 00000
4171 100 +19.2 100 +17.0 rich 00000
4306 100 +21.0 100 +19.0 rich 00000
4438 100 +20.0 100 +19.0 rich 00000
4409 100 +22.3 100 +11.0 rich 00000
4655 100 +18.8 100 +13.0 rich 00000
4688 100 +20.8 100 +13.0 rich 00000
4982 099 +19.8 100 +23.0 rich 00004
4916 100 +18.2 100 +15.0 rich 00000
5073 099 +19.8 100 +15.0 12.0 00000
5241 099 +21.0 100 +15.0 rich 00000
5341 099 +17.8 100 +23.0 rich 00000
5367 099 +16.4  90 +15.0 rich 00000
5546 100 +19.6 100 +15.0 rich 00000
5621 099 +20.6 100 +17.0 rich 00000
5737 099 +15.7  80 +24.0 rich 00000
5963 099 +14.7  80 +24.0 rich 00000
5931 099 +14.1  80 +16.0 rich 00000
6138 099 +14.7  80 +17.0 rich 00000
6242 099 +16.4  90 +17.0 rich 00000
6373 100 +14.5  80 +17.0 rich 00000
6397 100 +16.1  90 +17.0 rich 00000
6397 099 +14.1  80 +25.0 rich 00000
6626 100 +14.5  80 +17.0 rich 00000
6747 099 +14.1  80 +17.0 rich 00000
6988 070 +14.7  80 +25.0 rich 00000
6761 000  -7.1  00 ECU.  12.4 00000
Old 10-04-2002, 03:31 AM   #21
DiMensionX
Member#: 23517
Code:
Dyno Run 18
      %   psi       IGN       COUNT
2476 098  +2.5  20 ECU.  rich 00000
2450 099  +2.7  20 ECU.  rich 00000
2461 099  +2.9  20 ECU.  rich 00000
2463 099  +2.7  20 ECU.  rich 00000
2463 099  +3.3  20 ECU.  rich 00000
2456 099  +2.7  20 ECU.  rich 00000
2431 099  +2.9  20 ECU.  rich 00000
2450 099  +2.9  20 ECU.  rich 00000
2440 100  +3.3  20 ECU.  rich 00000
2438 100  +3.1  20 ECU.  rich 00000
2560 100  +2.9  20 ECU.  rich 00000
2699 100  +2.5  20 ECU.  rich 00000
2841 100  +3.3  20 ECU.  rich 00000
2918 100  +3.5  20 ECU.  rich 00000
3046 100  +4.1  30 ECU.  rich 00000
3205 100  +4.9  30 ECU.  rich 00000
3336 100  +5.9  40 ECU.  rich 00000
3447 099  +7.4  40 ECU.  rich 00000
3553 100  +6.8  40 ECU.  rich 00000
3663 099 +10.4  60 ECU.  rich 00000
3741 100 +11.7  60 ECU.  rich 00000
3894 100 +12.9  70 +15.0 rich 00000
4055 099 +15.9  90 +17.0 rich 00000
4120 099 +17.0  90 +17.0 rich 00000
4214 100 +19.8 100 +17.0 rich 00000
4290 100 +19.4 100 +19.0 rich 00000
4462 100 +18.4 100 +19.0 rich 00000
4450 100 +19.8 100 +13.0 rich 00000
4655 099 +20.2 100 +13.0 rich 00000
4734 100 +19.4 100 +15.0 rich 00000
4916 099 +17.8 100 +23.0 rich 00000
4990 100 +19.2 100 +23.0 rich 00000
5136 098 +17.6  90 +15.0 rich 00000
5299 099 +18.0 100 +15.0 rich 00000
5299 099 +17.6  90 +15.0 rich 00000
5518 098 +19.4 100 +23.0 rich 00000
5500 099 +16.4  90 +15.0 rich 00000
5583 100 +19.8 100 +15.0 rich 00000
5807 098 +18.2 100 +24.0 rich 00000
5889 100 +18.6 100 +16.0 rich 00000
6060 098 +15.3  80 +17.0 rich 00000
6184 099 +14.3  80 +17.0 rich 00000
6337 098 +18.8 100 +17.0 rich 00000
6373 099 +17.6  90 +17.0 rich 00000
6472 099 +15.5  80 +17.0 rich 00000
6802 099 +17.4  90 +17.0 rich 00000
6973 098 +13.9  80 +17.0 rich 00000
6613 098 +13.7  70 +23.0 rich 00000
6816 086 +15.7  80 +25.0 rich 00000
6613 000  -5.7  00 ECU.  12.1 00000
6093 000 -10.8  00 ECU.  lean 00000
Old 10-04-2002, 03:31 AM   #22
rayder
Member#: 14535
02 Impreza WRX
dang man.. thanks for your time into posting all thsi up.
Old 10-04-2002, 03:32 AM   #23
DiMensionX
Member#: 23517
Code:
Dyno Run 19
      %   psi       IGN       COUNT
2434 098  +2.1  10 ECU.  rich 00000
2461 100  +1.9  20 ECU.  rich 00000
2458 099  +2.1  20 ECU.  rich 00000
2467 099  +2.3  20 ECU.  rich 00000
2450 100  +1.7  10 ECU.  rich 00000
2440 100  +2.3  20 ECU.  rich 00000
2447 100  +2.5  20 ECU.  rich 00000
2440 100  +2.5  20 ECU.  rich 00000
2449 100  +2.3  20 ECU.  rich 00000
2454 100  +2.3  20 ECU.  rich 00000
2438 101  +2.3  20 ECU.  rich 00000
2469 101  +2.5  20 ECU.  rich 00000
2434 101  +2.5  20 ECU.  rich 00000
2515 101  +2.5  20 ECU.  rich 00000
2677 100  +2.5  20 ECU.  rich 00000
2803 100  +2.5  20 ECU.  rich 00000
2936 100  +3.5  20 ECU.  rich 00000
3033 101  +3.5  20 ECU.  rich 00000
3153 101  +3.7  20 ECU.  rich 00000
3297 101  +4.7  30 ECU.  rich 00000
3394 101  +4.9  30 ECU.  rich 00000
3527 101  +6.6  40 ECU.  rich 00000
3623 101  +5.9  40 ECU.  rich 00000
3757 101  +7.6  40 ECU.  rich 00000
3912 100 +10.4  60 ECU.  rich 00000
3972 100 +13.1  70 +20.0 rich 00000
4084 101 +13.9  80 +20.0 rich 00000
4182 101 +16.8  90 +20.0 rich 00000
4368 101 +18.2 100 +20.0 rich 00000
4363 100 +18.4 100 +12.0 rich 00000
4559 100 +16.4  90 +13.0 rich 00000
4655 100 +19.8 100 +13.0 rich 00000
4810 100 +18.8 100 +19.0 rich 00000
4945 100 +16.8  90 +23.0 rich 00000
4923 100 +18.4 100 +23.0 rich 00000
5144 100 +17.0  90 +23.0 rich 00000
5216 099 +19.0 100 +23.0 rich 00000
5376 100 +19.8 100 +23.0 rich 00000
5446 099 +15.5  80 +23.0 rich 00000
5583 100 +15.7  80 +23.0 rich 00000
5678 100 +18.8 100 +23.0 rich 00000
6027 100 +21.0 100 +24.0 rich 00000
5995 099 +14.5  80 +24.0 rich 00000
6027 100 +14.7  80 +24.0 rich 00000
5995 098 +17.0  90 +17.0 rich 00000
6172 100 +15.7  80 +17.0 rich 00000
6373 100 +13.5  70 +25.0 rich 00000
6373 100 +13.1  70 +25.0 rich 00000
6613 100 +13.9  80 +25.0 rich 00000
6734 100 +15.7  80 +25.0 rich 00000
6775 099 +13.7  70 +25.0 rich 00000
6747 100 +14.9  80 +25.0 rich 00000
6761 000  -3.8  00 ECU.  rich 00000
Old 10-04-2002, 03:33 AM   #24
DiMensionX
Member#: 23517
Now for the good stuff, let me stretch for a minute as this has taken 3 hours to resize and get all the data organized! Maps are comming bro:-).
Shawn
Old 10-04-2002, 03:40 AM   #25
DiMensionX
Member#: 23517
This is the VF30STG4TMI Stock UTEC Map in a readable format:
Code:
VF30 STI TMI 17PSI
    VF30STG4TMI         FUEL (%)           TURBOXS UTEC (Version 2.2)  (c) 2002
 RPM  0%    10%   20%   30%   40%   50%   60%   70%   80%   90%   100%
  500 -9.5  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8
  750 -9.5  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8
 1000 -9.5  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8
 1250 -9.5  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8
 1500 -5.5  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8
 1750 -5.5  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8  -6.8
 2000 -5.5  -6.1  -6.1  -6.1  -6.1  -6.1  -6.1  -6.1  -6.1  -6.1  -6.1
 2250 -5.5  -6.1  -6.1  -6.1  -6.1  -6.1  -6.1  -6.1  -6.1  -6.1  -6.1
 2500 -5.5  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9
 2750 -5.5  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9
 3000 -5.5  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9
 3250 -5.5  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9
 3500 -5.5  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9
 3750 -5.5  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9
 4000 -5.5  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9  -5.9
 4250 -5.5  -5.4  -5.4  -5.4  -5.4  -5.4  -5.4  -5.4  -5.4  -5.4  -5.4
 4500 -5.5  -5.6  -5.6  -5.6  -5.6  -5.6  -5.6  -5.6  -5.6  -5.6  -5.6
 4750 -5.5  -5.3  -5.3  -5.3  -5.3  -5.3  -5.3  -5.3  -5.3  -5.3  -5.3
 5000 -5.5  -5.3  -5.3  -5.3  -5.3  -5.3  -5.3  -5.3  -5.3  -5.3  -5.3
 5250 -5.5  -5.2  -5.2  -5.2  -5.2  -5.2  -5.2  -5.2  -5.2  -5.2  -5.2
 5500 -5.5  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1
 5750 -5.5  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1
 6000 -5.5  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1
 6250 -5.5  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1  -5.1
 6500 -5.5  -5    -5    -5    -5    -5    -5    -5    -5    -5    -5
 6750 -5.5  -5    -5    -5    -5    -5    -5    -5    -5    -5    -5
 7000 -5.5  -5    -5    -5    -5    -5    -5    -5    -5    -5    -5
    VF30STG4TMI         TIMING (Deg.)      TURBOXS UTEC (Version 2.2)  (c) 2002
  500 ECU   ECU   ECU   ECU   ECU   ECU   ECU   30    30    30    30
  750 ECU   ECU   ECU   ECU   ECU   ECU   ECU   30    30    30    30
 1000 ECU   ECU   ECU   ECU   ECU   ECU   ECU   30    30    30    30
 1250 ECU   ECU   ECU   ECU   ECU   ECU   ECU   30    30    30    30
 1500 ECU   ECU   ECU   ECU   ECU   ECU   ECU   30    30    30    30
 1750 ECU   ECU   ECU   ECU   ECU   ECU   ECU   30    30    30    30
 2000 ECU   ECU   ECU   ECU   ECU   ECU   ECU   30    30    30    30
 2250 ECU   ECU   ECU   ECU   ECU   ECU   ECU   30    30    30    30
 2500 ECU   ECU   ECU   ECU   ECU   ECU   ECU   27    27    27    27
 2750 ECU   ECU   ECU   ECU   ECU   ECU   ECU   24    24    24    24
 3000 ECU   ECU   ECU   ECU   ECU   ECU   ECU   22    22    22    22
 3250 ECU   ECU   ECU   ECU   ECU   ECU   ECU   18    18    18    18
 3500 ECU   ECU   ECU   ECU   ECU   ECU   ECU   15    15    15    15
 3750 ECU   ECU   ECU   ECU   ECU   ECU   ECU   15    15    15    15
 4000 ECU   ECU   ECU   ECU   ECU   ECU   ECU   17    17    17    17
 4250 ECU   ECU   ECU   ECU   ECU   ECU   ECU   19    19    19    19
 4500 ECU   ECU   ECU   ECU   ECU   ECU   ECU   21    21    21    21
 4750 ECU   ECU   ECU   ECU   ECU   ECU   ECU   23    23    23    23
 5000 ECU   ECU   ECU   ECU   ECU   ECU   ECU   23    23    23    23
 5250 ECU   ECU   ECU   ECU   ECU   ECU   ECU   23    23    23    23
 5500 ECU   ECU   ECU   ECU   ECU   ECU   ECU   23    23    23    23
 5750 ECU   ECU   ECU   ECU   ECU   ECU   ECU   24    24    24    24
 6000 ECU   ECU   ECU   ECU   ECU   ECU   ECU   25    25    25    25
 6250 ECU   ECU   ECU   ECU   ECU   ECU   ECU   25    25    25    25
 6500 ECU   ECU   ECU   ECU   ECU   ECU   ECU   25    25    25    25
 6750 ECU   ECU   ECU   ECU   ECU   ECU   ECU   25    25    25    25
 7000 ECU   ECU   ECU   ECU   ECU   ECU   ECU   25    25    25    25
    VF30STG4TMI         BOOST              TURBOXS UTEC (Version 2.2)  (c) 2002
  500 ECU   ECU   ECU   ECU   ECU   ECU   ECU   100   100   100   100
  750 ECU   ECU   ECU   ECU   ECU   ECU   ECU   100   100   100   100
 1000 ECU   ECU   ECU   ECU   ECU   ECU   ECU   100   100   100   100
 1250 ECU   ECU   ECU   ECU   ECU   ECU   ECU   100   100   100   100
 1500 ECU   ECU   ECU   ECU   ECU   ECU   ECU   100   100   100   100
 1750 ECU   ECU   ECU   ECU   ECU   ECU   ECU   100   100   100   100
 2000 ECU   ECU   ECU   ECU   ECU   ECU   ECU   100   100   100   100
 2250 ECU   ECU   ECU   ECU   ECU   ECU   ECU   95    95    95    95
 2500 ECU   ECU   ECU   ECU   ECU   ECU   ECU   95    95    95    95
 2750 ECU   ECU   ECU   ECU   ECU   ECU   ECU   95    95    95    95
 3000 ECU   ECU   ECU   ECU   ECU   ECU   ECU   50    50    50    50
 3250 ECU   ECU   ECU   ECU   ECU   ECU   ECU   46.8  46.8  46.8  46.8
 3500 ECU   ECU   ECU   ECU   ECU   ECU   ECU   43.5  43.5  43.5  43.5
 3750 ECU   ECU   ECU   ECU   ECU   ECU   ECU   43.5  43.5  43.5  43.5
 4000 ECU   ECU   ECU   ECU   ECU   ECU   ECU   44.5  44.5  44.5  44.5
 4250 ECU   ECU   ECU   ECU   ECU   ECU   ECU   45.9  45.9  45.9  45.9
 4500 ECU   ECU   ECU   ECU   ECU   ECU   ECU   48.6  48.6  48.6  48.6
 4750 ECU   ECU   ECU   ECU   ECU   ECU   ECU   48    48    48    48
 5000 ECU   ECU   ECU   ECU   ECU   ECU   ECU   46    46    46    46
 5250 ECU   ECU   ECU   ECU   ECU   ECU   ECU   43.5  43.5  43.5  43.5
 5500 ECU   ECU   ECU   ECU   ECU   ECU   ECU   42.5  42.5  42.5  42.5
 5750 ECU   ECU   ECU   ECU   ECU   ECU   ECU   42.5  42.5  42.5  42.5
 6000 ECU   ECU   ECU   ECU   ECU   ECU   ECU   42.5  42.5  42.5  42.5
 6250 ECU   ECU   ECU   ECU   ECU   ECU   ECU   42.5  42.5  42.5  42.5
 6500 ECU   ECU   ECU   ECU   ECU   ECU   ECU   42.5  42.5  42.5  42.5
 6750 ECU   ECU   ECU   ECU   ECU   ECU   ECU   42.5  42.5  42.5  42.5
 7000 ECU   ECU   ECU   ECU   ECU   ECU   ECU   42.5  42.5  42.5  42.5
FS: PA utec with 4 tuned maps and map selector switch whitesti04 Engine/Power/Exhaust 5 04-27-2007 08:53 AM
FS: UTEC with Map Selector, Exhaust and Others WRX11 MAIC Private Classifieds 67 03-06-2007 01:19 PM
NJ:TXS Rev.7 STi 04-06 Utec-w/rem. map selector and custom tuned maps Cuztom15 Engine/Power/Exhaust 2 12-04-2006 04:27 PM
Which maps are safer to run between PDX and Cobb maps? gopsu AccessPort 59 03-06-2006 04:27 PM
FS: MIAMI Utec rev6b with Remote Map changer W/ or Wo Laptop!+other Zdsquared Private 'For Sale' Classifieds 3 11-01-2005 11:26 AM
