Old 08-27-2013, 03:38 PM   #1
Paidfor
Member#: 267815
Be in awe
dont hate .)
Default Loosing learning after reading rom
Ok Gurus.....why does my learning view clear and ecu go into learning again after i simply "read" my rom with a tactrix. Its always did it....just tired of a 10 min idle learn after i read my rom. Is there any way to disable this reset?
Paidfor is offline   Reply With Quote
Old 08-27-2013, 08:02 PM   #2
Paidfor
Member#: 267815
Be in awe
dont hate .)
Someones got the annnnnnswer...da da da do do do
just waiting patiently lol
Come on tho........Scotty......Unabomber........Dux....any body???? Somebody .........................
So lonely on here lol
Old 08-27-2013, 08:38 PM   #3
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Some ecu's reset learned values after a flash or read and some dont. Nothing you can do about it.
fastblueufo is offline   Reply With Quote
Old 08-27-2013, 08:45 PM   #4
Paidfor
Member#: 267815
Be in awe
dont hate .)
Exactly who I was hopin would chime in....I didn't wanna misspell your name I was thinkin fastblueforyou...knew that wasn't right lol
Thanks for the info...really sucks tho. After every read or flash, I have to endure about 10 mins of semi ****ty return to idle ****...rev to 3000 back to 1000 over and over. Then learning view clears so I have to check it before even reading my rom or ill loose all my learning info. Wish there was a way around this
And im not buying a accessport either lol
I freakin refuse
Old 08-28-2013, 12:27 PM   #5
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Originally Posted by Paidfor View Post
...about 10 mins of semi ****ty return to idle ****...rev to 3000 back to 1000 over and over. .... Wish there was a way around this
Sounds like a good tune is your way around it. That's odd, who tuned you? (It seems like you're tuning yourself?). If self-tuned trial and error my be the only way sometimes. There are a lot of knowledgeable people on these boards so make sure you ask questions!
Oh and the support/advice you could get from Cobb (if you got one) may mean more to you then anything
wgr73 is offline   Reply With Quote
Old 08-28-2013, 03:13 PM   #6
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Why so you keep "reading" your tune? What benefit do you think its giving you?
In all the time I've been tuning, the only time I'll "read" a ROM, is if the car is stock, or I can't remember what the last map I loaded was. Which doesn't happen often due to the naming convention I use.
Black94Snake is offline   Reply With Quote
Old 08-29-2013, 10:59 AM   #7
Paidfor
Member#: 267815
Be in awe
dont hate .)
Because i was unsure if i loaded map A or map B...so i read the rom i had on it. It was the right rom (thank God) lol. But i then noticed that my idle was kinda strange. So I checked learning view, and it was cleared.Dammit!! I had forgot that it resets after a rom read. Was hopin i could tune it to NOT go into relearn after a simple rom read. Its pretty stupid for it to reset learning values is it not? Why am i the only one this bothers. Does everybody out there just drive around and relearn trims after every read ? Im waitin on some help from the awesome guys over at Romraider maybe for some new definitions or some helpful insight....hopefully. I just hate the fact that even if i replace the battery...its gotta relearn because or the ecu reset. All Subys arent like this are they?
Old 08-29-2013, 01:36 PM   #8
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
I do....doesn't bother me at all. If you tune everything (fuel trims) in as close to 0 as you can there should be no issue at all. I have no problems with my fuel trims resetting on my.
Something in your tune if off if you have to let your fuel trims learn before the car runs right.
Old 08-29-2013, 04:59 PM   #9
Paidfor
Member#: 267815
Be in awe
dont hate .)
Im inclined to believe you..cuz thats what i think too.
Learning view never shows any knock other than a occasional -.7 or so.......AF learned ranges are always between .40 and 1.0......(thats waaayyy less than the rule of thumb 5%)and o in D range.pretty damn good i think. I dunno why the hell it has to learn this way. I mean its not horrible.....just sluggish and idle wants to drop to 500ish before it catches up to the 900rpm target(Just for the first 10 mins after ecu reset(Or after reading rom lol). After 10 mins.........runs better than stock ever did lol. Idk....maybe im chasin a unicorn here. The older(2005ish) Hondas do this after a hard ecu reset. Our HDS software (Honda programming crap)even tells us on the prompt screen that idle may be irradic for the first 10 mins of idle after this reset. I just wish it wouldnt do it lol
Old 09-05-2013, 02:18 PM   #10
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
There are tables to fix the idle upon reset issues on romraider. mine was terrible. now it doesnt matter if i take the battery off.
Overrun/idle control maps will fix it.
or just wait for learning.
Bamofo is offline   Reply With Quote
Old 09-05-2013, 03:35 PM   #11
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^Interesting.............
Im lookin into that right now. Thanks Bamofo !!!
Old 09-05-2013, 10:56 PM   #12
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
You are basically waiting for the ECU to figure out that the throttle needs to be about 3% open in order to idle properly.
Use RR to find out what the idle opening really needs to be, by watching that parameter after the car has learned to idle nicely. Then you can speed that learning process a little bit by setting the idle cell in your DBW throttle table to 3% or whatever the value really needs to be.
Cobb insists that this is a bad idea, and it's better to leave that cell at 0% and tweak some other table instead. I personally can't imagine any drawbacks to putting the idle cell at the actual idle opening, and I can't imagine any advantages to having an unusable value (0%) in that cell. And this works well enough that I haven't bothered with the idle-learning tables.
Old 09-06-2013, 03:18 PM   #13
Paidfor
Member#: 267815
Be in awe
dont hate .)
Awsome info......thanks guys!!!!
Nasioc is the best sometimes lol
