Old 08-27-2013, 05:45 PM   #1
IveBeenRued
Member#: 305466
2012 Sport Limited
Default Better mileage after CVTF and differential fluid changes.
I changed out my differential fluids myself four weeks ago and got my local dealer to flush the CVT and now I am getting 2.7 MPG better. For 3,500 Miles prior to the fluid changes I had been averaging 33.2 MPG and now over the past 1,700 miles I have been averaging 35.9 MPG. My commute, driving style, and environmental variables have been consistent.
This was my cars' first CTVF change(45K) but I have been doing my diffs every 15K. I am seriously thinking about starting to do CTVF changes every 30K as this increase in mileage may be an indicator of fluid breakdown.
IveBeenRued is offline   Reply With Quote
Old 08-27-2013, 06:37 PM   #2
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
Hhhhmmmm interesting
What fliud did you use?
subaru222 is offline   Reply With Quote
Old 08-27-2013, 06:40 PM   #3
IveBeenRued
Member#: 305466
2012 Sport Limited
Royal Purple 75W-90(got it for $9.70/quart after coupons) for the differentials and the dealer used the Subaru CVTF for the transmission.
Old 08-27-2013, 09:29 PM   #4
79letour
Member#: 302570
2013 XV
DGM!
I've been running 75w90 synthetic (Amsoil) in the front and rear on the XV and my previous 12 Impreza.
I know it seems to give me *slightly* better mpg's. I did the tranny (5mt) and rear diff in the first month of ownership.
79letour is offline   Reply With Quote
Old 08-28-2013, 08:23 AM   #5
fistv
Member#: 350063
2013 Impreza sport
Do the subaru manuals use sintered bearings in their trannies, that was an issue with the AX5 and AX15's in jeeps, the GL4, 5 and 6 sulfur would eat the sintered bearings pretty quick, ended up using MT90 or mobil1 10w30. It did not help that the FSM said GL5 was OK, turned out to be a misprint that they printed a supplement for 4 YEARS later.
fistv is offline   Reply With Quote
Old 08-28-2013, 08:55 AM   #6
79letour
Member#: 302570
2013 XV
DGM!
I have no idea. But afaik the most corrosive gear lube would be the "COCKTAIL".
Old 08-28-2013, 09:02 AM   #7
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
How much did the dealer charge for cvt fluid change, if you don't mind me asking?
Old 08-28-2013, 09:08 AM   #8
Angelus911
Member#: 89967
2012 Impreza Sport
Is it hard to change the front and rear diff fluids? I looked over the service manual and it didnt seem too bad, any special "gotchas" that I should be aware of?
Angelus911 is online now   Reply With Quote
Old 08-28-2013, 09:10 AM   #9
IveBeenRued
Member#: 305466
2012 Sport Limited
It cost $284 after tax. 10 quarts of CVTF at $12.50/quart and 1.5 hours of labor at $97/hr.
Old 08-28-2013, 09:14 AM   #10
79letour
Member#: 302570
2013 XV
DGM!
Ive only done my 5mt's, but the rear is very easy. A $6 pump is your friend.
Old 08-28-2013, 09:14 AM   #11
IveBeenRued
Member#: 305466
2012 Sport Limited
The rear is very straightforward and can be done in about 10-15 minutes. The front has one major gotcha to watch out for. There is a fill plug that looks like it is for the front diff on the driver's side of the differential(not sure where that plug goes to be honest) but the fill plug for the front diff is actually buried on the passenger side near the catalytic converter.
Also make sure that the car is level when raised otherwise your fluid levels will be off.
Old 08-28-2013, 09:15 AM   #12
79letour
Member#: 302570
2013 XV
DGM!
Oh- and a good breaker bar...
Old 08-28-2013, 09:16 AM   #13
IveBeenRued
Member#: 305466
2012 Sport Limited
Or use the jack method.
Old 08-28-2013, 09:40 AM   #14
79letour
Member#: 302570
2013 XV
DGM!
Still dont want a chintzy breaker bar.
Old 08-28-2013, 10:55 AM   #15
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
PUP 5W30 92,050 miles
I didn't noticed any better mpg's but it was noticable smoother after having all the fluids changed.
I paid $290-something.
CLL_OBP is offline   Reply With Quote
Old 08-28-2013, 12:05 PM   #16
IveBeenRued
Member#: 305466
2012 Sport Limited
CLL_OBP, how many miles did you have on your vehicle when you got your factory fluid changed out?
Old 08-28-2013, 04:49 PM   #17
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
It was all @ 10.5k miles. When I saw the crap that came out of the differentials, I figured the CVTF had to be just as bad, and it was. They removed the pan and cleaned the screen and magnet. I guess the difference price we paid was charging me for 9 qts instead of 10 but adding $29 for that triple bond gasket stuff to reinstall the pan.
Old 08-28-2013, 08:33 PM   #18
Angelus911
Member#: 89967
2012 Impreza Sport
Probably going to get my diffs and cvt fluid changed once I get closer to 30k
Old 08-28-2013, 09:03 PM   #19
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
Satin White Pearl
That is interesting. I did some math and it's not really worth it for the 2.7 mpg better alone though, unless you only have to do it once and it lasts well over 30k miles.
Haunty is offline   Reply With Quote
Old 08-28-2013, 09:22 PM   #20
79letour
Member#: 302570
2013 XV
DGM!
Its not just good for an extra half mpg, it also gets lots of crap out and *may* help the car live longer. Ymmv of course.
Old 08-31-2013, 01:40 AM   #21
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
That's the CVTF filler plug. Where it's located does look like it would fill the front diff. That would be one major gotcha if you put gear oil in your CVT.
Old 10-10-2013, 11:44 AM   #22
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
The rear is very straightforward and can be done in about 10-15 minutes. The front has one major gotcha to watch out for. There is a fill plug that looks like it is for the front diff on the driver's side of the differential(not sure where that plug goes to be honest) but the fill plug for the front diff is actually buried on the passenger side near the catalytic converter. Also make sure that the car is level when raised otherwise your fluid levels will be off.
So what size tools (hex, torx) did you need for the drain/fill plugs?
jsteg is offline   Reply With Quote
Old 10-10-2013, 06:29 PM   #23
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
Front fill & check plug = H8
Front drain = T70
Rear fill & drain = H10
Old 10-10-2013, 07:00 PM   #24
jsteg
Member#: 329271
Ice Silver Metallic
Originally Posted by CLL_OBP View Post
Front fill & check plug = H8 Front drain = T70 Rear fill & drain = H10
Awesome thanks man! I've never used anything bigger than a T60 before lol
Old 10-10-2013, 09:06 PM   #25
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
Your welcome. Yeah, my torx bit set only goes up to T60 and I had to buy an extra bit. The cheapest place I've seen to get all three of them is Autozone. I paid $3.99 each and it's made by Duralast. The H10& H8 are 3/8" drive and the T70 is 1/2".
