Old 08-28-2013, 03:11 PM   #1
STMTuned
Member#: 227871
STM
00 Drag RSTi [email protected]
Default STM Subaru Impreza RS Drag Car (2019lbs) Dyno 631WHP/467WTQ **Low Boost**
Ever seen a fast subaru come out of a Evo/DSM shop?? Let alone a subaru making over 600whp on a mustang dyno without breaking a sweat or even getting warm. AWIC FTW!
Ton left in it. Turning the boost up soon.
This 2000 2.5rs has been a labor of love since the start. The owner (me) tried building the last 4 builds on the kitchen table. Lets just say with mixed results. After the 4th motor blew, decided to take it seriously and had STM work their magic. Street Tuned staff worked day and night to make everything perfect. Now it's up to the driver to make it go fast.
With 2000lbs and 600whp should easily see an easy mid 9 second pass. I'm sure this thing will scare the pants off me. Stay tuned
Event: dyno
Ambient Temp: 80 degrees
Elevation: 862ft
Tires: Stock
Car: 2000 2.5RSTi
Tuner: Emery @ STM
Dyno Info: Mustang Dyno
Transmission: PPG Drag 6MT
Gear: 3rd
Peak HP at RPM: 631
Peak Torque at RPM: 467
Baseline hp/tq for a stock on same dyno: ~100whp
Weight: 2019lbs
Target Boost: 32 PSI
Target AFR:
Fuel: E85
Engine/Power Modifications: Darton Sleeves, JE pistons, Manley ibeams, L19 studs, GSC S3 cams, +1 valves and full PnP
Driveline Modifications: Exedy Triple, DSS Pro Level rear axles, Stage 5 front axles, DSS CF driveshaft
Suspension Modifications: STM Drag spec coilovers, TSSFAB f/r subframes and accessories
Other Modifications:
STM 6765 Forward Facing Turbo Kit
STM built AWIC setup with ice box
STM built fuel system with 2 gallon cell up front, weldon fuel pump, FIC 2150s, Weldon regulator and pro classic lines
Brakeman drag brakes
AEM EMS V2
8.5 NHRA Cert cage
Lexan replacing all glass
-Ben @ STM
Over 100 photos on our facebook page
https://www.facebook.com/media/set/?...2433399&type=3
STMTuned is offline   Reply With Quote
Old 08-28-2013, 04:04 PM   #2
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
wow looking good!! as light as it is I know its going to run!!
stretchedk7 is offline   Reply With Quote
Old 08-28-2013, 06:29 PM   #3
reemwrb04sti
Member#: 254796
04 Sti
Wish I did a RS!! Nice #s!!
reemwrb04sti is offline   Reply With Quote
Old 08-28-2013, 08:31 PM   #4
fobiawrx
Member#: 91074
04 sti
white
dang! looking good guys. should come to mn for proving grounds the first week in sept and test it out at bir! this is one of my favorite builds i have ever seen. good work boys.
fobiawrx is offline   Reply With Quote
Old 08-29-2013, 12:24 AM   #5
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
Awesome stuff. STM is a great shop and they always go fast.
You guys should post the chart here, in the op.
Boosted Tuning is offline   Reply With Quote
Old 08-29-2013, 01:00 PM   #6
STMTuned
Member#: 227871
STM
Thanks Guys.
Will be hitting the track next weekend. We'll see how fast she can go.
Finger crossed.
[email protected]
Old 08-29-2013, 02:11 PM   #7
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Killer setup!
@ 2019 lbs and that kind of power its going to really move.
TDagen is offline   Reply With Quote
Old 08-29-2013, 09:50 PM   #8
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
Can't wait to see the video's of how this car runs.....
jdpsearcher is offline   Reply With Quote
Old 08-29-2013, 10:09 PM   #9
KpT KiM
Member#: 242422
Couldn't find it in the info. What gears/tranny are you running?
KpT KiM is offline   Reply With Quote
Old 08-29-2013, 10:15 PM   #10
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Nice setup for sure. Isn't it standard practice to do dyno pulls in 4th with the 6mt?
geronimo81 is offline   Reply With Quote
Old 08-30-2013, 01:10 AM   #11
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
Can you post of some pics of the car unless it is top secret....under hood, all around, etc....
Old 08-30-2013, 02:14 AM   #12
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Depends on what year the gearing is. The 07+ 6mt's have a longer 3rd gear, so third gear works alot better than the earlier year third gears.
Fourth gear would spool the turbo even faster
Old 08-30-2013, 02:48 AM   #13
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Gonna boogie down the 1/4 I'm sure
Tyrial is offline   Reply With Quote
Old 08-30-2013, 07:24 AM   #14
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
agreed ^ the weight on this thing is just dumb insane!
Old 08-30-2013, 12:12 PM   #15
STMTuned
Member#: 227871
STM
Using a PPG 6 speed with 1-4 drag ratio gearset.
Old 08-30-2013, 12:12 PM   #16
STMTuned
Member#: 227871
STM
Pics added to OP
Old 08-30-2013, 03:55 PM   #17
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
very very nice the car is really clean and organized underneath,just a spectacular job guys.Be safe and go FAST.
john 1badSTI is offline   Reply With Quote
Old 08-30-2013, 04:19 PM   #18
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
I agree. Well said. Everything looks perfectly placed.
Old 08-30-2013, 10:01 PM   #19
shomspeed
Member#: 166371
2007 WRX STI
Will you guys be look into making a staging brake similar to what you have done for the evo for the Subaru community? Even though the sti 6-speed drivetrain is more robust than the evo, they still break, i believe a staging brake helps tremendously preventing breaking drivetrain parts with awd cars.
shomspeed is offline   Reply With Quote
Old 08-31-2013, 01:03 AM   #20
redrex2002
Member#: 118915
2002 wrx
srp
damn i live like 20 freeking min. from you guys i gotta see this thing in person!
redrex2002 is offline   Reply With Quote
Old 08-31-2013, 01:51 PM   #21
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
If you have any questions on the weight removal, just look at the FB page.
So many things I can't do because of class
Gorgeous build!
Old 08-31-2013, 02:06 PM   #22
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
I need to get mine down to like 2400 but damn thats crazy its so light
Old 08-31-2013, 02:53 PM   #23
john 1badSTI
Member#: 77470
just look underneath the car Rob everything is wide open and all chassis pieces look to be made of small tube chrome moly or aluminum.STM did a fabulous job of planning everything out on this car to get it as light as possible.The only other car I can think of that is that tidy underneath is Roger Clarks Motorsports gobbstopper road race car.
Old 08-31-2013, 03:02 PM   #24
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
i got a long ways to go :/ lol
Old 08-31-2013, 03:21 PM   #25
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Andy F. comes to mind also.
This thing is going to move, no doubt about it.
