Old 10-08-2002, 12:10 PM   #1
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
Question Why do Magnecor plug wires have such a high ohm rating?
I purchased some Magnecor plug wires for my '99 RS. My original wires had almost 90K miles on them. The number 3 plug wire was corroding at the coil pack so I thought I'd try some "high end" wires.
After getting all but one on I decided to check the ohm rating of the wire. The Magnecor came up at a high 12.5K ohms. I checked the same OEM wire and it came up at 6K ohms. I then checked the rest of the wires and the Subaru OEM's were much lower than the "top of the line" Magnecor. WHA?!?! I thought the better wire would have a lower ohm reading? Are these Subaru OEM wires that good? Why would a higher ohm reading be better?
I'm going to check my gas mileage for a few tanks and I am almost certain it will be worse.
Any thoughts on this?
spshultz is offline   Reply With Quote
Old 10-08-2002, 01:02 PM   #2
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default Sounds high
12500 Ohm sounds high. It should be closer to 6000 Ohm, like the originals. However, lower resistance has nothing to do with how good ignition wires are. If anything, resistance that is too low will hurt performance.
Why don't you write to Magnecore and ask them. They have excellent customer service. And keep us posted, please.
vvk is offline   Reply With Quote
Old 10-08-2002, 01:45 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I have checked the email notification box on this thread. Im very curious. If you dont email them I will.
ciper is offline   Reply With Quote
Old 10-08-2002, 03:11 PM   #4
pdximpreza
Member#: 17606
2002 Impreza 2.5RS
Do the wires have a larger diameter than stock?
If not, I dont see how these would be better wires. If the ohms is higher in the wire, then it absorbs more of the voltage.
Since voltage is what makes the spark.............. hmm maybe I am looking to much into this. I know this isnt an intelligent signal going across, but any signal degredation I would think to be bad. Then again, if the voltage is lower and still sparking, you may have a colder spark, which would be a good thing.
Just doesnt seem right to me.
pdximpreza is offline   Reply With Quote
Old 10-08-2002, 04:16 PM   #5
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
Here is what Magnecor has to say about low resistance wires:
"LOW-RESISTANCE" SPIRAL WIRES
By far the most popular conductor used in ignition wires destined for race and performance street engines are spiral conductors (a.k.a. mag, pro, super, spiral, monel, heli, energy, ferro, twin core etc.). Spiral conductors are constructed by winding fine wire around a core. Almost all manufacturers use constructions which reduce production costs in an endeavor to offer ignition component marketers and mass-merchandisers cheaper prices than those of their competitors.
In the USA in particular, most marketers of performance parts selling their products through mass-merchandisers and speed shops include a variety of very effective high-output ignition systems together with a branded not-so-effective ignition wire line using a spiral conductor. Most perpetually try to out-do their competitors by offering spiral conductor ignition wires with the lowest electrical resistance. Some publish results which show their wires are superior to a competitor's wires which use identical cable (on which another brand name is printed). The published "low" resistance (per foot) is measured with a test ohmmeter's 1 volt direct current (DC) passing through the entire length of the fine wire used for the spiral conductor.
"Low-resistance" conductors are an easy sell, as most people associate all ignition wire conductors with original equipment and replacement ignition wire carbon conductors (which progressively fail as a result of microscopic carbon granules burning away and thus reducing the spark energy to the spark plugs) and with solid wire zero-resistance conductors that were used by racers with no need for suppression. Consumers are easily led into believing that if a spiral conductor's resistance is almost zero, its performance must be similar to that of a solid metal conductor all race cars once used. HOWEVER, NOTHING IS FURTHER FROM THE TRUTH!
What is not generally understood (or is ignored) is that as a result of the laws of electricity, the potential 45,000 plus volts (with alternating current characteristics) from the ignition coil (a pulse type transformer) does not flow through the entire the length of fine wire used for a spiral conductor like the 1 volt DC voltage from a test ohmmeter, but flows in a magnetic field surrounding the outermost surface of the spiral windings (skin effect). The same skin effect applies equally to the same pulsating flow of current passing through carbon and solid metal conductors.
A spiral conductor with a low electrical resistance measured by an ohmmeter indicates, in reality, nothing other than less of the expensive fine wire is used for the conductor windings ó a construction which cannot achieve a clean and efficient current flow through the magnetic field surrounding the windings, resulting in poor suppression for RFI and EMI.
Of course, ignition wire manufacturers save a considerable amount in manufacturing costs by using less fine wire, less exotic winding machinery and less expertise to make low-resistance spiral conductors. As an incentive, they find a lucrative market amongst performance parts marketers who advertise their branded ignition wires as having "low-resistance" conductors, despite the fact that such "low-resistance" contributes nothing to make spiral ignition wires perform better, and RFI and EMI suppression is compromised.
In recent years, most ignition wire manufacturers, to temporarily improve their spiral conductor's suppression, have resorted to coating excessively spaced spiral windings, most of which are crudely wound around strands of fiberglass or Kevlar, with a heavy layer of high-resistance carbon impregnated conductive latex or silicone compound. This type of construction hides the conductive coating's high resistance when the overall conductor is measured with a test ohmmeter, which only measures the lower resistance of the sparse spirally wound wire (the path of least resistance) under the conductive coating and ignores the high resistance of the outermost conductive coating in which the spark energy actually travels. The conductive coating is rarely shown or mentioned in advertisement illustrations.
The suppression achieved by this practice of coating the windings is only temporary, as the spark current is forced to travel through the outermost high-resistance conductive coating in the same manner the spark current travels through the outermost high-resistance conductive coating of a carbon conductor used in most original equipment and stock replacement wires.
In effect, (when new) a coated "low-resistance" spiral conductor's true performance is identical to that of a high-resistance carbon conductor.
Unfortunately, and particularly with the use of high-output ignitions, the outermost high-resistance conductive coating over spiral windings acting as the conductor will fail from burn out in the same manner as carbon conductors, and although in most cases, the spiral conductor will not cease to conduct like a high-resistance carbon conductor, any RFI or EMI suppression will be lost as a consequence of the coating burning out. The worst interference will come from the so-called "super conductors" that are wound with copper (alloy) wire.
However, despite the shortcomings of "low-resistance" spiral conductor ignition wires, these wires work satisfactorily on older production vehicles and race vehicles that do not rely on electronic engine management systems, or use on-board electronics effected by EMI ó although with the lowest-resistance conductor wires, don't expect much RFI suppression on the AM band in poor reception areas.
Some European and Japanese original equipment and replacement ignition wires including Bougicord and NGK do have spiral conductors that provide good suppression ó usually none of these wires are promoted as having low- resistance conductors ó however, none are ideal for competition use, as their conductors and pin-type terminations are fragile and are known to rarely last as long as good carbon conductor ignition wires.
To be effective in carrying the full output from the ignition system and suppressing RFI and EMI in particular, spiral conductors need windings that are microscopically close to one another and precisely spaced and free from conductive coatings. To be more effective, the windings need to be wound over a core of magnetic material ó a method too costly for wires sold through mass-merchandisers and most speed shops who purchase only the cheapest (to them) and most heavily promoted products.
Old 10-08-2002, 06:23 PM   #6
moogooob
Member#: 15764
00RS -Dumb all over
A little ugly on the side
so how much HP do they add?
ok ok ok... just kidding there.
Are there any benifits from running expensive wires as compared to subaru OEM?
moogooob is offline   Reply With Quote
Old 10-08-2002, 07:04 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
Yeah, they are not consumable like the normal wires you buy from subaru or the parts store.
You do realize that slowly the performance of the standard wires degrades. Where these continue at the same level for basically the life of the car.
Why are The Tanabe GF210 Have Such A High Front Spring Rate? 2005_sti Brakes, Steering & Suspension 6 07-12-2006 06:13 PM
FS: Used Magnecor Plug Wires SOHC Robmat Private 'For Sale' Classifieds 2 05-17-2005 11:57 PM
Magnecor Plug Wires cartel Private 'For Sale' Classifieds 2 11-28-2004 05:34 PM
Brand new 8.5mm magnecor plug wires on ebay with no reserve flvimpreza Private 'For Sale' Classifieds 0 06-17-2004 12:25 AM
Why does the STi need such a high octane rating? Corn-Picker Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 12-01-2003 09:23 PM
