Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 09-01-2013, 12:58 AM   #1
Member#: 51500
1999 impreza rs-t
Default HTA-GT3076 vs GTX3076???
It is time for me to rebuild my GT3076 ar.63 and I am tinking to up-grade it at the same time!
I do not know if I should go with the Forced Preformance HTAGT3076 or the Garette GTX3076?
What are your felling about those turbo??? What turbo deliver the more HP at the same boost?? What turbo soop the fastess???
Please help me to make my choice???
P.S. Sorry for my english I am french Canadian!!!
OB2 is offline   Reply With Quote
Old 09-01-2013, 02:17 AM   #2
Member#: 291214
2011 STI Sedan
Please don't get a .63 hotside.....It is sooooo limiting....
Both are good turbos.....
jdpsearcher is offline   Reply With Quote
Old 09-01-2013, 01:44 PM   #3
Member#: 182375
08 Sti
The hta may spool a bit quicker. The gtx will make more power.
kakarot09 is offline   Reply With Quote
Old 09-01-2013, 09:04 PM   #4
Member#: 285083
2006 STi
hta3076 will spool faster and is a better matched turbo.
NA STI is offline   Reply With Quote
Old 09-02-2013, 06:01 PM   #5
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Gt3076 < Hta 3076 < Gtx3076
west_minist is offline   Reply With Quote
Old 09-03-2013, 02:28 AM   #6
Member#: 349550
Do you have a Dyno of your current build? at what PSI are you running?
95ONE is offline   Reply With Quote
Old 09-03-2013, 02:00 PM   #7
Member#: 328635
2004 STi GTX3076R
Rally Blue
I cant speak on the others, but I have the GTX3076R with a .82 hot side and am extremely happy with it. The spool is fast and hold power until 8k like it isn't trying.
But what it comes down to is what turbo fits your engine/expected results, so what can you tell us about those?
Example: my build had oversized valves and cams so I needed something that holds well on the higher rpm range making the GTX with an .82 a no brainer.
Builds with less head work can get away with smaller hot sides or less efficient wheels seeing they will start to fall off at 6k regardless of turbo (stock cams/valves).
Scuby04STi is online now   Reply With Quote
Old 09-04-2013, 12:52 AM   #8
Member#: 51500
1999 impreza rs-t
MAHA LSP 3000 4WD DYNO (verry conservative)
[email protected] CR
19PSI of Boost
99 impreza RS SOHC Head
TWE spring et Valve
Web 148e grind Cams
2.5I 2005 Intake Manifold
Block EJ257
Wiseco [email protected] compression Piston
K1 Carrillo Rod
Cosworth bearing
Cometics head gasquet
ARP stud
Lachute Hi-Flow oil pump
Cosworth belt retaner
Gates Racing Belt
Lachute 3" Turbo/Back Exhaust
Zero Sport Radiator Wind Deflector
Halley Fuel Pump (650 hp)
K&N Air Filter and Intake
Turbo XS Blow off Valve
Lachute Up-pipe
Lachute Down-pipe
Lachute Headers
Vibrant Front Mont Intercooler (26*12*3.5)
Garrett GT3076R ar.63 Turbo
Tial 44mm Wastgate
Electronic boost Selenoide (Set at 19 psi)
FAL Engine Cooler
Unorthodox Racing Full Pulley Kit
Power Entreprise 850cc Injectors
Lachute CatchCan
Custom IC water foger
V-pec EMS (tuned at Lachute Performance)
Group N motors mont
The head can't make allot more then 400 to 450whp so, I want a fast spooler to make the MAX of TQ and to have the max of air under the dyne curve!
