Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Old 01-04-2015, 01:04 PM   #1
KaB_bugeye
Member#: 369753
2002 6 Spd WRX
Default Spun bearing ej20
Well recently spun a bearing in my 2002 wrx. How reliable are 2.1 stroker motors. I see steamspeed sells a whole kit with mahle pistons, manley rods, and ACL Race Bearings. Anybody have an experience with this setup. I'm not looking for crazy Hp just looking for a stronger motor for the future if I go 20g.
Sent from my SM-G900V using NASIOC mobile app
KaB_bugeye is offline   Reply With Quote
Old 01-05-2015, 05:09 AM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
I wouldn't think that they are any less reliable than any other forged engine. I think the reliability comes when you start to run like 24 or more psi of boost. and the machining of your block.
Old 01-05-2015, 09:58 AM   #3
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
it would be just as reliable as the build, tune and maintenance like any other engine.
Plenty of built motors with expensive quality parts on this board have blown up/had problems with less than 3000 miles due to some part of the build not being just right.
fastnoypi is online now   Reply With Quote
Old 01-06-2015, 11:33 PM   #4
cgbirchWRX
Member#: 410324
2002 Impreza WRX
Deep Red w/Black roof
I think i may have spun a bearing in my turbo but am not quite sure. what is the best way of knowing without diving in?
cgbirchWRX is offline   Reply With Quote
Old 01-07-2015, 11:21 AM   #5
Bahaa425
Member#: 384641
Do an oil change. If there is metallic flake in the oil coming from the filter, then you've most likely spun a bearing. I recently spun one a few days ago and the oil change is what made me know for sure. It looked like paint you'd see on a car, tons of copper flake floating around.
Sent from my iPhone using NASIOC
Bahaa425 is offline   Reply With Quote
Old 01-07-2015, 01:42 PM   #6
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
you "spun a bearing" in your turbo? I'm fairly sure that's not something you can do. You can have trashed bearings, but they aren't like rod bearings. They're either journal bearings or ball bearings in a housing.
tebriel is offline   Reply With Quote
Old 01-07-2015, 06:25 PM   #7
cgbirchWRX
Member#: 410324
2002 Impreza WRX
so if i do find flakes in the oil then the motor is scarp. right? which would suck really bad seeing as i have had the car a week and a day when this happend. I never really even pushed the car that much. I had asked a friend of mine that owns a shop and his mechanics said that what i described sounded like a spun turbo bearing. said that it probably slung chunks of metal into the enigine. Now I am new to turbo cars and am learning the do's and don'ts. Am extremly sad that my first snail powered car died after a week. And without even being mistreated. The WRX drove amazing. Had a little vibration 60+ mph. had all tires balanced, and then was nice and smooth. That was the only issue up until the horrible sound of chains being thrown into a woodchipper. I had stoped by a friends for a few hours and when I got in to leave it started....ran for all of one second...... bad bad sound...... and died. i turned it over one time softly.......... bad sound. left it. had my wife bump it with my head under hood to pinpoint the location of said bad bad sound. And it was right where the turbo was. Then i hit the web for answers. so if not the turbo taking a nice big **** into my engine.... what could it be and how much is it likely to cost me? i have priced a complete engine. and am thing of just doing a swap until i can have it tore down. but hopefully I won't have to. any ideas or advice would be great thanks to all that reply
Old 01-07-2015, 06:47 PM   #8
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
If you have metal flakes in the oil, it probably also passed all those little metal pieces through your turbo as well. Pull the motor and have a look at what has been damaged.
An EJ207 v8-9 is a good swap option.
Fierysun is offline   Reply With Quote
Old 01-07-2015, 10:51 PM   #9
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
you can certainly destroy turbo bearings, it probably doesn't result in a whole lot of metal. So options are replace turbo, see if it's happy times, or pull motor and and see if rod/main bearings are trashed.
Old 01-07-2015, 11:18 PM   #10
cgbirchWRX
Member#: 410324
2002 Impreza WRX
But a car should still run with a bad turbo right? Rough no doubt but should still fire and run. I get nothing but a sound that makes my stomach hurt.
Old 01-08-2015, 01:02 AM   #11
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
yeah it should still start at least. It would run pretty poorly and it should be putting smoke out the exhaust. Of course the problem is that lots of metal particles will be moving around the engine causing wear to parts. maybe make a recording of it and put it on youtube to link to us?
Old 01-08-2015, 02:29 AM   #12
cgbirchWRX
Member#: 410324
2002 Impreza WRX
I will do just that. The car is still at my friends house so it will be sometime tomorrow before I am able. The video will be fairly short though. I don't want to do any more damage than there already is just in case there is a chance it can be saved. Thanks for the great idea and keep a look out.
Old 01-12-2015, 03:28 PM   #13
cgbirchWRX
Member#: 410324
2002 Impreza WRX
Sorry it took so long but here is the link to the video. Thanks guys.
https://m.youtube.com/watch?v=28388yFccEQ
Old 01-12-2015, 07:16 PM   #14
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Drop the the downpipe and see if your turbo is dead. Try checking for shaft play. You can also pull your turbo inlet pipe and see if the blades exist or scraping against the housing.
Old 01-13-2015, 11:55 PM   #15
Daytonatrix955i
Member#: 377569
03 wrx
black
It sound's like you have no compression or a starter to flywheel issue,.. if you can turn the motor over w a 22mm socket at the crank and it starts look into the starter or flywheel, otherwise pull a timing case cover and start suspecting your belt~ GL
Daytonatrix955i is offline   Reply With Quote
