Old 09-02-2013, 12:28 AM   #1
sebi1990
Member#: 362910
2013 Impreza WRX
Default 2013 wrx stage 1 feedback knock?!
Hey guys I've installed Cobbs OTS map for 93 with intake and my DAM is great always 1 however for a split second my feedback knock went from 0 to -1.4. I am still to log my data and post it but I wanted to find out if it s something that required imidiate attention. Also it happens at no paricular time or in a given gear. Also it happens very rearly.
Send from my android so the spelling is crap sorry ; (
sebi1990 is offline   Reply With Quote
Old 09-02-2013, 01:48 AM   #2
Chicago AJ
Member#: 353343
'13 WRX Sedan Stg 3
'13 Prius C 86mpg!
It's probably fine. Get some logs posted so we can take a look. Find a spot and log 2500rpm to redline at full throttle.
Chicago AJ is offline   Reply With Quote
Old 09-02-2013, 01:55 AM   #3
sebi1990
Member#: 362910
2013 Impreza WRX
Since its a 5speed in 3rd gear right?
Old 09-02-2013, 02:18 AM   #4
Chicago AJ
Member#: 353343
'13 WRX Sedan Stg 3
'13 Prius C 86mpg!
Correct.
Old 09-02-2013, 02:46 AM   #5
sebi1990
Member#: 362910
2013 Impreza WRX
Awsome will post logs tomorrow if I'm able to :-)
Old 09-03-2013, 12:41 AM   #6
sebi1990
Member#: 362910
2013 Impreza WRX
Old 09-03-2013, 09:54 AM   #7
Cobb Tuning
Member#: 4803
Originally Posted by sebi1990 View Post
A little bit of fine knock learning in this log but within tolerances and based on a previous event (has started to learn back to zero). Get a few more logs to verify (if you can do so safely) but looks fine.
Bill
Old 09-03-2013, 10:16 AM   #8
sebi1990
Member#: 362910
2013 Impreza WRX
Bill
Great I will get 3 logs one after another hopefully today I don't know if it makes a difference but the logs were done after 2h of highway cruising is there any other data I should log in order to help you get better idea of what's happening with the engine? Also this is the first time the car got that sort of a beating.
Old 09-03-2013, 11:24 AM   #9
Cobb Tuning
Member#: 4803
The default logging set is fine. Your log looks fine but it is always a good idea to get multiple logs to compare. The occasional small knock correction is perfectly fine and sometimes it is just noise and not actual knock.
Bill
Old 09-03-2013, 03:49 PM   #10
sebi1990
Member#: 362910
2013 Impreza WRX
Hey I've got two more logs but they're just me coming from school a bit of spirited driving in 1st 2nd and 3rd at one point the know was above 2 here are the logs:
https://docs.google.com/file/d/0B1mT...VVJYW5vc3BPVmM
https://docs.google.com/file/d/0B1mT...3VrWEk1SDM0X28
I will post more logs hopefully today in the evening.
Old 09-03-2013, 03:49 PM   #11
sebi1990
Member#: 362910
2013 Impreza WRX
Bill
I heard a lot of people talk about the noise what is the noise exactly and how is it connected to knock and can appear to be a knock?
Old 09-03-2013, 04:12 PM   #12
Chicago AJ
Member#: 353343
'13 WRX Sedan Stg 3
'13 Prius C 86mpg!
Could something loose in the engine bay. A bolt, heatshield, etc. Driving under normal conditions the noise could be picked up by the knock sensor. Like Bill said, under hard load/full acceleration the engine is making much more noise and it could make the knock sensor not pick up the false knock.
Old 09-03-2013, 04:28 PM   #13
sebi1990
Member#: 362910
2013 Impreza WRX
Ok thanks for the clarification.
Old 09-03-2013, 06:14 PM   #14
sebi1990
Member#: 362910
2013 Impreza WRX
Also in 1st gear it seems as soon as I get off the throttle to switch gears the knock goes to 2.8
Old 09-03-2013, 07:05 PM   #15
Chicago AJ
Member#: 353343
'13 WRX Sedan Stg 3
'13 Prius C 86mpg!
Could be something loose or the driveline clunking.
Old 09-03-2013, 07:53 PM   #16
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
on a side note, boost seems to be a little off in the first log you posted. looks like you're running almost 2psi short until the upper rpm's. if you're comfortable tuning you could try and adjust the wgdc tables a bit.
bluemax189 is online now   Reply With Quote
Old 09-03-2013, 10:08 PM   #17
sebi1990
Member#: 362910
2013 Impreza WRX
It seems like every time I step on it harder and then release the throttle to switch gears that happens. It hit -2.8 at times and it starts to worry me.
Old 09-04-2013, 08:29 AM   #18
Cobb Tuning
Member#: 4803
I wouldn't worry about feedback knock that occurs on hard shifts or when mashing the throttle or lifting abruptly off the throttle and long as it is not worse than -2.8. This is almost always noise. The -2.8 fine knock learning in the logs you are seeing is just based on a past event at lower load which is being re-applied over and over again (not current knock) as you pass through the load/rpm range which you were briefly hitting multiple times in these particular data logs.
The best logs to get to see how things are doing is like the first log you did - an extended 3rd gear WOT run, if you can do so safely.
Bill
Old 09-04-2013, 12:51 PM   #19
SouthernWRX
Member#: 321571
2012 WRX Base
Ice Silver
My '12 WRX has never, NEVER been knock/knock learning free. It always has some here and there. Like Bill said, get another 3rd gear pull and see what its doing. Your going to drive yourself crazy cruising around always looking at the knock, I know I did. Trust me, if something is truly wrong you will know it. I got a tank of bad gas about a month ago and holy hell did it pull some crazy stuff on my car. Knock all the time, DAM down to .35. Once I finished that tank, everything has been back to normal. Get a 3rd gear WOT run and post it back up. That first log looked good, the other two are random driving and look about like mine at times.
Just so you know I went stage one at about 5K miles, then stage two at about 15K and I currently have 26K on her with no issues.
SouthernWRX is offline   Reply With Quote
Old 09-04-2013, 12:58 PM   #20
sebi1990
Member#: 362910
2013 Impreza WRX
Yeah I've been doing that thanks for the reassurance guys I'll get the two pulls as soon as I can
Old 09-06-2013, 08:21 PM   #21
sebi1990
Member#: 362910
2013 Impreza WRX
Hey guys I'm back with more data the
1st one was done on a bit bumpy road/ costco gas /traction control on:
https://docs.google.com/file/d/0B1mT...it?usp=sharing
2nd one was done on a smoother road / shell v-power / traction control off:
The knock is definitely lower in the 2nd one not sure if because of the gas or maybe the road condition.
Old 09-06-2013, 09:13 PM   #22
Chicago AJ
Member#: 353343
'13 WRX Sedan Stg 3
'13 Prius C 86mpg!
I'll check them when I get home in a couple hours. I always use Costco gas and have never seen any knock. Bill said my logs were good if you want to compare, check my newest thread with the A/B/C/D logs.
Old 09-06-2013, 09:21 PM   #23
sebi1990
Member#: 362910
2013 Impreza WRX
You are running stage 1 with or without intake?
Old 09-06-2013, 09:39 PM   #24
Chicago AJ
Member#: 353343
'13 WRX Sedan Stg 3
'13 Prius C 86mpg!
Without. The only thing that should change is boost.
Old 09-07-2013, 09:15 AM   #25
Cobb Tuning
Member#: 4803
The logs look good. There is a single count (-1.4) of fine knock learning in the first log that is ramping back to zero in that log and the next. Fine knock learning is a little tricky to analyze as it can happen from a prior event and is re-applied over and over in a load/rpm range surrounding event, so it is hard to tell when it was learned (sometimes you can get this correction at WOT when lifting off the throttle abruptly at the end of a WOT run which is just noise). I would get a few more of the same type of logs just to see additional data, if you can do so safely, but a single count of occasional fine knock learning is not a big deal.
We usually recommend the so-called "top tier" gas, which usually has more consistent results. We've seen issues with Costco gas before, but that is hard to apply universally as likely Costco gets gas from a wide variety of suppliers at different Costco throughout the country, so results may vary.
Bill
