Old 09-03-2013, 12:59 PM   #1
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Default Factory RS Spring Verification
So I'm putting the factory springs back on my 99 RS. I didn't label them when I took them off. How can I verify what springs go on the front and back? Any help is appreciated
emsmap is offline   Reply With Quote
Old 09-04-2013, 02:33 AM   #2
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Bump?
Old 09-04-2013, 01:03 PM   #3
avk
Member#: 17252
'06 WX8
59E
You'll find out after disassembling the first strut. A spring from the opposite end will not fit. Left and right are the same.
avk is offline   Reply With Quote
Old 09-04-2013, 06:50 PM   #4
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Thanks. I hope so. I dont want to mismatch the fronts and rears
Old 09-08-2013, 03:26 PM   #5
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
So I installed the so springs. Fronts are good, however, the passenger rear is 1/2 inch higher than the drivers. I know for a fact these came off of my factory rs. Anyone run into this?
Old 09-09-2013, 12:35 PM   #6
avk
Member#: 17252
'06 WX8
59E
Were the two springs the same length before compressing? Are the upper seats and mounts "clocked" the way they should be?
Old 09-09-2013, 05:14 PM   #7
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
With both spring sitting next to each other, they are the same width and length. The weird thing is, the passenger side with the higher sitting spring is the one without a lower rubber insulator. The drivers side has both rubber insulators but is still 1/2 lower than the passenger. They both sit in the spring perch the same as being clocked.
Old 09-09-2013, 05:32 PM   #8
avk
Member#: 17252
'06 WX8
59E
I meant to refer to the alignment notches at the edge of the upper spring seat.
