Old 09-03-2013, 12:41 PM   #1
ShawDizzle
Member#: 118902
08 WRX Premium Sdn
Default Sti intercooler or no?
I have an 08 wrx. Looking to upgrade to a VF 48 or 52. I'm looking to obviously get what I can out of it. Full bolt ons with upgraded fuel. Will an Sti intercooler handle it or should I go for a better upgrade. I want to stay top mount
ShawDizzle is offline   Reply With Quote
Old 09-03-2013, 01:01 PM   #2
RoadKillDMD
Member#: 284792
2011 STI
Blurple
If you want a STI TMIC, you're going to need a different intake manifold as yours is not compatible. You will also need to run the vf48. IMO, more work than it's worth.
If I were you, I would go with the vf52 and find a solid aftermarket TMIC that will work with your manifold, such as the Process West TMIC for MY08+ WRXs.
RoadKillDMD is offline   Reply With Quote
Old 09-03-2013, 01:38 PM   #3
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
08+'s CANNOT use an STI intercooler because of the different design of the intake tract.
Old 09-03-2013, 01:58 PM   #4
Dmochowski
Member#: 306478
2012 WRX limited
305whp/360tq TSM tuned
If you are not looking to spend $1000 for a tmic just get a used 09+ tmic from someone that has upgraded. Probably find one for cheap and will do just fine at what your power levels will be.
Dmochowski is online now   Reply With Quote
Old 09-03-2013, 02:05 PM   #5
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Ya know that MY08 WRX TMIC is the same as MY09+ WRX TMICs don't ya? That wouldn't be an upgrade at all!
Old 09-03-2013, 02:12 PM   #6
Dmochowski
Member#: 306478
2012 WRX limited
Haha figured they would have diff ways of bolting up. If the compressor housings on the 08 and 09+ are all the same then just keep that. You don't "need" an upgraded tmic if just sticking with the factory turbo.
Old 09-03-2013, 02:15 PM   #7
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
They are the same. No difference on the WRX's except the turbo, but they keep the same intake tract.
Old 09-03-2013, 02:20 PM   #8
Dmochowski
Member#: 306478
2012 WRX limited
Well there you go, if it were me and I was on a budget I would stick to the factory intercooler and just get a turbo blanket and maybe add another heat shield over the existing one and call it a day unless you're chasing numbers or live in the Deep South and heat soak up all the time. I live in TN and don't feel like my factory tmic is holding me back. I will upgrade one day but it will most likely be after a ringland failure and I will bolt up a dom 1.5
Old 09-03-2013, 02:24 PM   #9
RoadKillDMD
Member#: 284792
2011 STI
Blurple
The ishty design is KNOWN to fail, even at stage 2 power levels. Crappy plastic end tanks are crimped onto a weak little core. These crimps are known to split wide open. This same thing happened to my buddies WRX before switching to the PW TMIC.
Old 09-03-2013, 02:25 PM   #10
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
PS OP, "Full bolt on" means nothing.
Old 09-03-2013, 02:52 PM   #11
Dmochowski
Member#: 306478
2012 WRX limited
True, which is why I am nervous when winter rolls around. I got my pro tune done in the spring and have not driven yet in the cold temperatures. When I flashed the stage 2 map from Cobb last winter I blew the socks off the intercooler pipes so I will be watching my intercooler this winter to see if it fails
Old 09-03-2013, 03:02 PM   #12
ShawDizzle
Member#: 118902
08 WRX Premium Sdn
Ya. I was being lazy n shoulda just made a list.
But thanks for all the info guys. Ill just get an after market. Sure I can find one on here. I'm not under a huge budget any way but don't want to be digging into the wallet
Old 09-03-2013, 03:04 PM   #13
Dmochowski
Member#: 306478
2012 WRX limited
Just to put a bug in your ear... Grimmspeed is a good American company I am sure you are aware of, they will be rolling out an 08+ tmic upgrade around Jan Feb timframe.
Old 09-03-2013, 03:37 PM   #14
ShawDizzle
Member#: 118902
08 WRX Premium Sdn
Nice. Ill use the stock for the winter. I'm in jersey so ill be fine
Old 09-03-2013, 03:37 PM   #15
xEJ20x
Member#: 49362
2013 DGM STI
Cobb Stg 2
If you dont want to drop the cash on a new intercooler, keep an eye out in the classified forums for part outs.
xEJ20x is offline   Reply With Quote
Old 09-03-2013, 06:54 PM   #16
ShawDizzle
Member#: 118902
08 WRX Premium Sdn
Ya. It don't matter but I always go to the classifieds first.
Old 09-15-2013, 02:55 AM   #17
uv_blue
Member#: 282723
Look to the lgt guys that have fixed this problem. it goes by the name bullet proof intercooler.
uv_blue is online now   Reply With Quote
Old 09-20-2013, 08:31 AM   #18
Chicago77
Member#: 214488
2013 Impreza WRX
Dark Gray Metallic
Not to highjack this thread too much, but this is the third time in my recent batch of reading where I have seen this come up, and it is not something I have seen before. I'm looking to do a stage 1 AP with my rex soon and I am hearing about something in the intercooler blowing off and needing to be put back on with clamps...
Could someone quickly tell me what is happening here and what the part is/what this problem is called so I can look it up?
Chicago77 is offline   Reply With Quote
Old 09-20-2013, 10:15 AM   #19
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
Search for 08+ intercooler to throttle body hose end caps...
Hoon Goon is offline   Reply With Quote
Old 09-20-2013, 10:23 AM   #20
some dude
Member#: 100300
06 WRX
CGM
And search 'bullet proof TMIC'
some dude is offline   Reply With Quote
