Old 09-05-2013, 07:42 AM   #1
WRBoxer11
Member#: 278033
2011 WRX Stage 2
Default Constant rubbing sound with vibration
2011 WRX Sedan, 50k miles
Getting a consistent rubbing noise at all speeds that doesn't seem to get louder with more speed. Low speed is coupled with a low tone clunking type noise. I also have a minor vibration in the car. I'm not the best at diagnosis and really would like to avoid getting worked at a repair facility.
WRBoxer11 is offline   Reply With Quote
Old 09-05-2013, 07:44 AM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
does it change when the brakes are applied?
Old 09-05-2013, 10:28 AM   #3
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
Any kind of work done on it, or all stock?
darkstarmoto is offline   Reply With Quote
Old 09-05-2013, 10:28 AM   #4
WRBoxer11
Member#: 278033
2011 WRX Stage 2
Yes slightly.
Old 09-05-2013, 10:52 AM   #5
WRBoxer11
Member#: 278033
2011 WRX Stage 2
Stage2, sway bars, short shifter. Cars not tracked or beaten.
Old 09-05-2013, 11:51 AM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
a clunk and/or high speed vibration could be cv joints.
does the clunk change when making tight low speed turns, ie, parking lot?
Old 09-05-2013, 11:52 AM   #7
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
Possible the sway bars shifted, loosened up?
Ninja edit...the bushings or end links could cause a clunking sound if they are loose.
Old 09-05-2013, 01:42 PM   #8
WRBoxer11
Member#: 278033
2011 WRX Stage 2
I noticed the sound is louder as a take turns, esp. On/off ramps. Is it possible the tires are out of round or bad rotor(s)?
Old 09-05-2013, 02:40 PM   #9
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
Sounds kind of wheel bearingish to me.
A-man07 is offline   Reply With Quote
Old 09-05-2013, 05:59 PM   #10
WRBoxer11
Member#: 278033
2011 WRX Stage 2
That was my first guess. Expensive to fix?
Old 09-05-2013, 07:32 PM   #11
A-man07
Member#: 271525
07 STi
Not a decent shop. Dealership yes.
Old 09-06-2013, 02:24 PM   #12
Teddy7
Member#: 218358
step 1. buy the bearings yourself, take the hubs and knuckles off yourself.
step 2. take the hubs/knuckles and bearings to a decent machine shop and have them press the old out and the new in.
step 3. put everything back on your car.
step 4. profit.(from not spending as much money as you could have spent if you just dropped your car off at subaru or something.)
(if it's wheel bearings)
Also check your endlinks, since you have upgrade sways, and look around your wheel wells, I've heard similar sounds from the fender liner things that are popped loose.
If it's the CV joints you'll probably hear something when you hit bumps as well, closer almost to a clicking, (that's what mine sounded like).
Aside from that the most valuable thing you could tell us?: Is it coming from the front or the rear?
Teddy7 is offline   Reply With Quote
Old 09-06-2013, 02:53 PM   #13
WRBoxer11
Member#: 278033
2011 WRX Stage 2
Thank you for the bearing advice. Appreciate that.
I'll check the links and liners, and as far as the location, that is driving me nuts because I can't tell.
Old 09-06-2013, 03:33 PM   #14
Teddy7
Member#: 218358
have a friend ride with you in the front first then in the back, You're pretty isolated to one position in the car, since you're driving it an all. Also having someone stand outside while you drive past them can help to determine if you can hear it outside the vehicle (unless you already know) Some issues are really only audible to the people in the car
Old 09-06-2013, 03:43 PM   #15
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
2011 are bolt in wheel bearing assembly...even easier if that's the issue.
Honestly before spending a bunch of $, go back over what has been modified and make sure it's all correct. Then you can start the process of eliminating issues like wheel bearings, ect...
Another idea to check: If the wheels came off during installation of sway bars, check lugs are torqued properly.
Old 09-06-2013, 06:33 PM   #16
WRBoxer11
Member#: 278033
2011 WRX Stage 2
After discussion and focused listening/driving scenarios, I believe I'm dealing with a bad rotor.
Old 09-10-2013, 12:25 PM   #17
giraff
Member#: 258189
2011 WRX, 5-door
SSM
I'm also dealing with similar issues and I'm 90% sure it's a bad front passenger side wheel hub/bearing assembly. My car has eaten through my stock rotors and upgraded rotors (i.e. developed symptoms of a warped rotor).
I'll keep you posted on my repair process. Search up trueno92's posts on this forum, as he has been more than helpful in diagnosing my car's symptoms.
giraff is offline   Reply With Quote
Old 09-11-2013, 01:52 PM   #18
WRBoxer11
Member#: 278033
2011 WRX Stage 2
O man. I haven't replaced the rotors yet, but I wouldnt be all that shocked if its a bad bearing/hub. Keep it posted
Old 09-11-2013, 03:08 PM   #19
giraff
Member#: 258189
2011 WRX, 5-door
SSM
Here's where I've been posting updates on my issue:
http://forums.nasioc.com/forums/show....php?t=2547489
Old 01-02-2014, 09:56 AM   #20
WRBoxer11
Member#: 278033
2011 WRX Stage 2
Well the sound is back and I noticed the insides of the front tires were worn down and have cupping. I had an alignment done and the same thing happened again with the new rubber. Anyone know what gives?
Old 01-02-2014, 10:39 AM   #21
A-man07
Member#: 271525
07 STi
Have you replaced the bearing because that's what it sounds like.
Old 01-07-2014, 04:03 PM   #22
WRBoxer11
Member#: 278033
2011 WRX Stage 2
If the uneven wear is the same on both front tires, could I possibly have two bad bearings?
Old 01-07-2014, 04:05 PM   #23
WRBoxer11
Member#: 278033
2011 WRX Stage 2
Also too, it has a front swaybar that was professionally installed, could that be a culprit?
Old 01-16-2014, 09:21 PM   #24
WRBoxer11
Member#: 278033
2011 WRX Stage 2
We'll too the car to my mechanic today and went over the suspension and driveline. Everything is in place, nothing is broken or worn out. My tires, after the second alignment in a month have chopped/ cupped in the front again. Has anyone had this issue?
