Welcome to the North American Subaru Impreza Owners Club Thursday May 7, 2015
Old 09-05-2013, 04:50 PM   #1
jason6_WRX
Member#: 308253
2012 WRX hatch
Ice Silver Metallic
Default Flashed stage 2, some warning lights cane on in dash
Yesterday I installed my downpipe and flashed stage 2. I took the car for a little run today and I did a quick little pull in third (not to redline, only to about 4500 -5000 rpm and very soon after the check engine light, traction control light came on and the cruise control light is flashing. What could this be?
Also I bought a grim speed heat shield and it seems like there is absolutely no where to bolt it up around the turbo. Any idea what I might have done wrong?
Thanks
jason6_WRX is offline   Reply With Quote
Old 09-05-2013, 04:54 PM   #2
BroBroBroBroBro
Member#: 338211
2011 wrx
12.9 @ 107
reset your ECU, but check the codes first. prob overboost? not even going balls out but i think its that. no big deal. Anywhere nearby for a protune?
thought i was in newbie section....you posted in wrong place.
BroBroBroBroBro is offline   Reply With Quote
Old 09-05-2013, 05:12 PM   #3
CodeRed30
Member#: 350787
2013 WRX
Someone had mentioned to me that this is a symptom of too much air or some **** to the O2 sensor and that it's easily fixed with a $30 O2 fooler.
CodeRed30 is online now   Reply With Quote
Old 09-05-2013, 05:37 PM   #4
jason6_WRX
Member#: 308253
2012 WRX hatch
Ice Silver Metallic
I didn't realize this was the wrong section, my bad. But no there are no protune options available. I am on the torqued performance map with no revisions yet. What do you mean by checking the codes? Sorry for sounding like a newb
Old 09-05-2013, 05:40 PM   #5
Dyno503
Member#: 314017
2010 WRX
use an OBD2 reader, see what the codes are, and google them. Google will tell you what each code means.
Dyno503 is offline   Reply With Quote
Old 09-05-2013, 06:04 PM   #6
BroBroBroBroBro
Member#: 338211
2011 wrx
12.9 @ 107
how you flash stage 2? accessport reads codes goto troubleshoot or whatever.
torqued performance is not that great IMO. Find a tuner somehow. Drive 5 hours if you have to its worth it.
Old 09-05-2013, 06:37 PM   #7
jason6_WRX
Member#: 308253
2012 WRX hatch
Ice Silver Metallic
There isn't an option at all to go protune as I would have to go out of province which isn't an option, as I live in newfoundland. And I used a tactrix cable to reflash. I just used a code reader and the code that came up was P0031 and below it says HO2S heater control circuit low (bank 1, sensor 1).
Old 09-05-2013, 06:37 PM   #8
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
It sounds like you overboosted. Did the car suddenly loose power just before the dash lights came on?
Also for the heatshield, you need to make sure to keep the factory heat shield bracket on top of the downpipe, it will look like this when on the car.
And off the car:
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 09-05-2013, 06:39 PM   #9
RallySport Direct
Member#: 33174
We are Open Late!
That will be the front O2 sensor in your exhaust manifold. Check to make sure everything is plugged in and all of the wires are in good shape. I would clear the code and see if it comes back. The new O2 sensor for that location is a bit expensive, but if yours is bad, it will need to be replaced.
Edit: Here is a good writeup showing where the sensor is and where the plug to that sensor is as well so you can check it:
http://forums.nasioc.com/forums/show....php?t=1839895
Thanks,
Rick
Old 09-05-2013, 07:00 PM   #10
BroBroBroBroBro
Member#: 338211
2011 wrx
12.9 @ 107
sick chime in rick. he will appreciate this. Its above and beyond anything i could offer.
Old 09-05-2013, 07:30 PM   #11
jason6_WRX
Member#: 308253
2012 WRX hatch
Ice Silver Metallic
Thanks,
Rick
thanks for the link, i forgot to mention my car is a 2012, so does that how to still apply to my car?
Old 09-05-2013, 07:32 PM   #12
jason6_WRX
Member#: 308253
2012 WRX hatch
Ice Silver Metallic
And off the car:
Thanks,
Rick
thanks a lot, that really helped!
Old 09-05-2013, 09:25 PM   #13
Chaz2.5
Member#: 168181
1999 EJ205 RS coupe
If you are tuned with the Torqued Performance map e:mail Eric and tell him what happened. When he sent the map notes he left some parameters for you to datalog so you can send those to him and he can adjust the maps accordingly. Did you install the correct map for the intake you have? I know he sends base maps for like 8 different intake setups.
Kind of soon for an O2 sensor to go back. But if you need a new one, either Amazon or Rockauto.com for the best price for direct OE replacement. Don't use the universal crap ones.
Chaz2.5 is offline   Reply With Quote
Old 09-06-2013, 10:34 PM   #14
jason6_WRX
Member#: 308253
2012 WRX hatch
Ice Silver Metallic
Thanks for the help everyone. It ended up being one of the wires on the o2 sensor that was frayed a little bit and it was touching off the heat shield above the downpipe. I taped it up and reset the ecu and the lights went away. I also got the heat shield on there.
And btw. Big difference in stage 1 and 2, it pulls a lot harder now
Old 09-06-2013, 11:44 PM   #15
Ilovecugars
Member#: 299442
2005 Forester XT
Don't worry about being up in nfld and no pro tuners around if you want to go further with mods and need a good tune. There are some really good guys out there that do etunes. Phattbotti and clarktuner are two popular ones. I spent my whole life except the last 2 years in the maritime, you can always find ways to work around geographical problems.
Ilovecugars is offline   Reply With Quote
Old 09-07-2013, 12:23 AM   #16
Dat8687
Member#: 243261
2004 WRX
Java black pearl
did it died...
Great you fixed it
Dat8687 is offline   Reply With Quote
Old 09-07-2013, 05:28 PM   #17
Chaz2.5
Member#: 168181
1999 EJ205 RS coupe
Do datalogs and send them to Eric. Right now you are still running an OTS map. He'll tweak the map and the car will run even better.
