Old 09-08-2013, 09:19 PM   #1
Kamikaze531
Member#: 96347
2003 WRX Sedan
Default Could this be anything other than a bad wheel bearing?
Getting a sound from my front right wheel area when turning hard left. It basically sounds like a dragging brake pad. My thinking is the bearing is starting to go bad, which is letting the brake rotor move against one of the pads. Is there anything else I should check before I start pulling off the upright? All brake and suspension hardware in the area is tight, and it only does it on left turns.
Kamikaze531 is offline   Reply With Quote
Old 09-09-2013, 12:00 AM   #2
Bikelok
Member#: 254851
2002 WRX wagon 5mt
It could be something else, but probably not.
Not all bad wheel bearings show movement when the wheel is lifted and pushed/pulled, but give that a try.
Most likely it's the bearing.
Bikelok is offline   Reply With Quote
Old 09-09-2013, 03:24 PM   #3
Kamikaze531
Member#: 96347
2003 WRX Sedan
Not showing any movement, but there is a slight metallic clink when I push on the top of the wheel.
