Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 09-10-2013, 11:05 PM   #1
LIMITED98
Member#: 355487
Default Sti side mirror covers/blinkers install
Hi guys,
I have a 2013 wrx hatch and would like to know if anyone can help me install sti mirrors/blinkers.
I am located in LI.
Thanks.
LIMITED98 is offline   Reply With Quote
Old 09-11-2013, 07:22 AM   #2
S1CkWrx
Member#: 325249
2012 wrx
dgm
doesnt seem hard to do at all. what if you went to an audio shop ?
S1CkWrx is offline   Reply With Quote
Old 09-11-2013, 07:56 AM   #3
LIMITED98
Member#: 355487
I took it to the shop where they painted my mirrors and they were going to cut wires and take the headlights out.
That doesn't sound right.
I want it to be done right.
This is why I'm reaching to you guys.
Thanks.
Old 09-11-2013, 11:18 AM   #4
yellowrxo2
Member#: 13454
02 wrx
yellow
If you're willing to come down to Yonkers.
yellowrxo2 is offline   Reply With Quote
Old 09-11-2013, 01:48 PM   #5
r31mar
Member#: 303898
2017 cwp wrx
13 wrb wrx 07 cgm wrx
Originally Posted by LIMITED98 View Post
Hi guys,
I am located in LI.
Thanks.
I'm thinking about doing the same thing. Please update once you got it installed. Thanks
r31mar is offline   Reply With Quote
Old 09-11-2013, 01:57 PM   #6
matigas_TT
Member#: 322775
2012 WRX-4Dr
Where did u buy the mirrors?
matigas_TT is offline   Reply With Quote
Old 09-11-2013, 05:36 PM   #7
LIMITED98
Member#: 355487
Will def keep you update once installed.
I got the mirrors from monkiboy. Give him a shout out. Very easy to deal with.
Pm sent....
Old 09-14-2013, 03:31 PM   #8
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
You shouldn't have to remove the headlights to tap the blinker line, it should be visible by the DS firewall when you open the door. If not it might be down in the fender which is why they would say remove headlights. They may have been right.
You don't have the side blinker in your fender/door, right? Ask caesar from lightwerkz I'm sure he knows, should be an easy install.
JavaBot is offline   Reply With Quote
Old 09-16-2013, 10:46 PM   #9
LIMITED98
Member#: 355487
Thanks javabot...I will get in touch with them to confirm.
Old 09-16-2013, 10:57 PM   #10
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
I'm pretty sure it should be visible if you open the DS door since your harness usually goes from stalk to headlamp via that firewall. Then only thing is figuring out which wire is the blinker to splice.
If you already have power mirrors then that part should be pnp.
