Old 09-11-2013, 06:16 PM   #1
RickyD
Member#: 307098
Default Need help fitting 18x9 +25 on 08 WRX
So, I have a 2008 WRX on Stance coilovers and I can't seem to fit the rears that well. They don't have adjustable camber like on the fronts and I'm scared to drive on them in case I hit a bump and the wheel smashes my quarters. I have 18x9 +25 with 215/40 Federal SS595. What is the best and cheapest way to fit them? I need about 5mm-10mm of clearance. Some people told me an alignment shop can max them out more, but others told me its not possible. Also, fenders are rolled. Any help is appreciated.
RickyD is offline   Reply With Quote
Old 09-11-2013, 06:27 PM   #2
jason.az1
Member#: 348492
2013 WRX
Camber kit + alignment
Or
Roll/pull the fenders
jason.az1 is offline   Reply With Quote
Old 09-11-2013, 06:41 PM   #3
RickyD
Member#: 307098
any idea how much labor would be for the whiteline camber kit?
Old 09-11-2013, 08:21 PM   #4
sc00by4life
Member#: 97135
lol.
bought not built.
call a shop and find out .
Old 09-11-2013, 08:56 PM   #5
RickyD
Member#: 307098
your bought not built statement makes absolutely no sense.
clearly was just asking if anyone knows on her, if not obviously im going to call a shop.
if i had experience with this i wouldn't be asking on the forum...
Old 09-11-2013, 08:56 PM   #6
RickyD
Member#: 307098
clearly was just asking if anyone knows on here, if not obviously im going to call a shop.
Old 09-12-2013, 12:53 AM   #7
sc00by4life
Member#: 97135
Old 09-12-2013, 03:03 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
i think ya gonna end up with a ****ed up car and a look on yer face
Old 09-12-2013, 01:39 PM   #9
RickyD
Member#: 307098
lol...
Old 09-12-2013, 04:29 PM   #10
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
Whiteline camber kit won't give you enough camber.
You need the Cusco arms most likely. Or the GTSpec arms. I think cusco is a better product though.
You should also get your fenders pulled in addition to being rolled.
gsrcrxsi is offline   Reply With Quote
Old 09-12-2013, 04:32 PM   #11
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Roll, cut, pull the fenders until they fit.
Psychoreo is offline   Reply With Quote
Old 09-12-2013, 10:42 PM   #12
RickyD
Member#: 307098
anyone run the godspeed LCAs? theyre $200 with a 5 year warranty.
Old 09-12-2013, 10:44 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
cupcake.....yew gonna TOTALLY screw the p00ch whatever you buy
wont matter a bit what ya do
Old 09-13-2013, 08:32 PM   #14
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
Stance isn't for you, it's too damn hard. Go back to your 17x7's.
colin1234567 is offline   Reply With Quote
Old 09-15-2013, 12:25 PM   #15
RickyD
Member#: 307098
nah d00d
Old 09-15-2013, 12:26 PM   #16
RickyD
Member#: 307098
bump for any other info
Old 09-15-2013, 01:54 PM   #17
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
You need camber plates which i hope you got for your fronts. The rears dont need them but you can get them.
Hope you dont rub and have those fenders roll or your juat going to do more damage.
Get them set the way you want your car to sit. Make sure they clear your struts or your going to need spacers
Get an alignment and figure out what you want to do from there.
Rrsearch please before the natives shred you to pieces.
JAMM0N is offline   Reply With Quote
Old 09-16-2013, 01:02 AM   #18
RickyD
Member#: 307098
yeah i have camber plates in front,
nothing in rear. i just want them
to fit the safest way. i was reading that getting aftermarket LCA's puts stress on your diff. idk if thats true or not. i just want to achieve the camber i need which should
be around -2-2.5 degrees. if not i guess ill just pull the fenders.
Old 09-16-2013, 02:16 PM   #19
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
I havent heard anything about that either. But i have bushings everywhere so its tough to know.
You should be able to achieve that camber and not rub cause the well its negative camber your tire tucking.
I couldnt live w that camber hence the LCA to pull the lower control arm back and support it a little.
I am at -1.8 and -1.6 from -2.5 ish on both sides.
How stretched are the tires?
Old 09-16-2013, 05:47 PM   #20
RickyD
Member#: 307098
Tires have a mild stretch they run as a 223 but theyre 215 on a 9 inch wheel.
Old 09-16-2013, 06:50 PM   #21
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
245 on a 9" wheel is a "mild" stretch.
215 is A LOT of stretch...
Old 09-16-2013, 06:56 PM   #22
Zulu-
Member#: 232213
Makes perfect sense. .
Never heard of that. GTspec rear arms, alignment, never think about it again. And, just roll the fenders, what the **** are you scared of? Trying to stance this car without doing any of the prep work. .
Zulu- is offline   Reply With Quote
Old 09-16-2013, 07:58 PM   #23
RickyD
Member#: 307098
like i said the tires are 215 but run as a 223 and simple math shows that 9 inches is 228.6 mm which is a 5.6mm stretch.
and like i also said the fenders ARE rolled just not pulled.
just not sure of what to do next. either say f jt and pull the fenders or get suspension components to camber them more.
Old 09-16-2013, 07:59 PM   #24
RickyD
Member#: 307098
everyone is trying to ***** on me when theyre not even reading the post clearly or trying to help out. my car my choices just seeking help.
Old 09-16-2013, 08:03 PM   #25
sc00by4life
Member#: 97135
this is how aggressive wheel fitments work. We can post all sorts of solutions, but YOU need to just pull the trigger and figure out what it will take with YOUR SETUP to make it work.
