Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Old 09-15-2013, 06:18 PM   #1
2008SUBARUWRX
Member#: 366926
2008 WRX Sedan
Default 2008 WRX boost issue
Hey guys I have a 2008 WRX and it has a cat back Agency Power Exhaust, K&N Short Ram Intake, Turbo XS BOV, but still on stock tune I'm pretty sure, and I'm having an issue with boost, when I go to get on it or anything I feel like the car is holding back, and like studdering a little bit if that makes any sense? Its kind of hard to explain, but it feels like I'm loosing boost then gaining it back right away but like it's cutting in an out, if anyone knows anything along these lines please let me know because this drives me crazy!! Thanks guys!!
2008SUBARUWRX is offline   Reply With Quote
Old 09-15-2013, 06:40 PM   #2
Blackfin
Member#: 361325
2010 STi
Dark Gray Metallic
Pretty brave to put an SRI and catback without a proper tune.
You sure what you're feeling isn't misfiring?
Blackfin is offline   Reply With Quote
Old 09-15-2013, 10:23 PM   #3
Tripintaz
Member#: 245218
2013 STI Limited
Oh for the love of god....
Tripintaz is offline   Reply With Quote
Old 09-15-2013, 10:30 PM   #4
ProfessWRX
Member#: 323379
06 WRX
You need to stay off the throttle until you know and/or scan the car. You could be in the process of blowing your motor... you could also be already dealing with a blown motor.
ProfessWRX is offline   Reply With Quote
Old 09-15-2013, 11:52 PM   #5
Bleichroeder
Member#: 365470
I've been told catbacks require no tune what so ever. Also, some SRIs such as TSX don't require a tune either. There's some very conflicting info floating around this forum.
Bleichroeder is offline   Reply With Quote
Old 09-16-2013, 01:51 AM   #6
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
No ones mentioned the BOV yet????
In conjunction with the intake.....
Oh my!
Cathexis is offline   Reply With Quote
Old 09-16-2013, 09:58 AM   #7
Bleichroeder
Member#: 365470
Oh my!
Ya know that's what I was gonna say. Your BOV is probably the culprate.
Old 09-16-2013, 10:30 AM   #8
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Tune that thing.
SlimJim8804 is online now   Reply With Quote
Old 09-16-2013, 11:12 AM   #9
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
Mr.Chow is offline   Reply With Quote
Old 09-16-2013, 01:31 PM   #10
RoadKillDMD
Member#: 284792
2011 STI
Blurple
MY08+ WRXs are REQUIRED to get a tune if a different intake is being used. MAF scaling WILL be off, and COULD potentially damage the engine. Unless he has taken it to a tuner for a base line to check if everything is running 'safely', there's no way to tell. OP needs a tune with that intake.
RoadKillDMD is offline   Reply With Quote
Old 09-16-2013, 01:37 PM   #11
takeadirtnap
Member#: 344507
2010 Rex
put it back to stock. Read all of the unibomber's posts. Re-read them. Study them. Then decide where to go from there.
takeadirtnap is offline   Reply With Quote
Old 09-16-2013, 01:50 PM   #12
Bleichroeder
Member#: 365470
Aha, I was speaking in regards to an 07. Interesting!
Old 09-16-2013, 03:14 PM   #13
2008SUBARUWRX
Member#: 366926
2008 WRX Sedan
Wow thanks for all the feedback guys! Getting kind of nervous now because of everything I've just read.. I bought the car the way it sits with all of those mods about 2 weeks ago, so I'm not sure if its tuned to be completely honest, is there any way to tell? I don't have a boost gauge installed yet but I just bought one so it will be soon.
Old 09-16-2013, 03:15 PM   #14
Bleichroeder
Member#: 365470
I'm a noob here but I would say hook that gauge up immediately check to see if you're running factory boost levels. Regardless you should get to a tuner ASAP and get **** sorted out.
Old 09-16-2013, 03:17 PM   #15
acumenhokie
Member#: 271479
2010 LGT (Stg 4)
2009 FXT (Stg 1)
You can go ahead and start a WTB: Stock Intake thread
acumenhokie is offline   Reply With Quote
Old 09-16-2013, 03:22 PM   #16
2008SUBARUWRX
Member#: 366926
2008 WRX Sedan
Yes I will be doing both of those things very soon thanks guys.
Old 09-16-2013, 03:32 PM   #17
2008SUBARUWRX
Member#: 366926
2008 WRX Sedan
If I were to just get my car tuned with everything it has now will I be fine?
Old 09-16-2013, 04:34 PM   #18
Blackfin
Member#: 361325
2010 STi
Dark Gray Metallic
If it's holding back and "studdering" and the cause is mechanical damage (e.g. a broken ringland), a tune will not fix the issue though it may prevent additional damage being done elsewhere in the engine.
Old 09-16-2013, 04:49 PM   #19
2008SUBARUWRX
Member#: 366926
2008 WRX Sedan
So what should I do for starters like right away?
Old 09-16-2013, 05:14 PM   #20
nate_fisher
Member#: 270482
2011 turbotek fxt
11.85@117 4eat xt record?
Tune it rite now!!
nate_fisher is offline   Reply With Quote
Old 09-16-2013, 06:50 PM   #21
xxKnight48xx
Member#: 368492
2012 Impreza WRX
Buy an access port. I'm fairly new here but I have read several threads on here already that say. If you have an intake you need a tune right away. And also with the bov you need a tune as well. I had issues like this with my speed 3 where it would literally cut out and kick back on full boost right away. I tuned it and it never happened again.
xxKnight48xx is offline   Reply With Quote
Old 09-16-2013, 08:17 PM   #22
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
you cant tune for a vta bov. its metered air that should be left in the intake system. a good recirc bpv is the way to go over the plastic oem unit.
424wrx is offline   Reply With Quote
Old 09-16-2013, 08:23 PM   #23
xxKnight48xx
Member#: 368492
2012 Impreza WRX
I gotcha. The whole bpv/bov issue was a little confusing to me. Didn't mean to give misleading info.
Old 10-13-2013, 02:16 PM   #24
BOOstiN2008
Member#: 370849
I think you need to get a tune
BOOstiN2008 is offline   Reply With Quote
