Old 09-15-2013, 09:27 PM   #1
carrie05
Member#: 368441
2013 WRX Premium
Plasma blue (purple)
Cool Newb: can DR lights be altered?
Bought a Subaru WRX 2013 in August. Manufacturers must have DRLs in the 2013 cars (California only??). The running light is a small LED bulb with two filaments, one for HB and one for the DRL, as near as I can figure from the book and from looking at it. Are there single filament HB lamps in use in the earlier model WRX's--before the DRLs were required--that can be substituted for these in the 2013? I don't want the DRLs at all.
I'm not aware of any law that says the driver of a 2013 car must have the DRLs on all the time -- only that manufacturers are required to install them in new cars.
Any advice would be sincerely appreciated!
--carrie
carrie05 is offline   Reply With Quote
Old 09-15-2013, 09:37 PM   #2
Teedub21
Member#: 333099
2013 WRX STi
ISM
Search first, there I said it.
First off they aren't LED, they're just your high beam halogens running at reduced power. Couple ways, pull the front bumper off and the DRL plug is on the passenger side below the air box resonator. Unplug and no more DRL's but high beams still work fine. Or remove air box assembly and go at it from the top. Or pull lower splash shield away following the directions to replace fog light bulbs and you could probably get at it that way but you'd be working blind and have to know what you're feeling around for.
Teedub21 is offline   Reply With Quote
Old 09-15-2013, 11:45 PM   #3
09rexrunner
Member#: 293955
2011 WRX
Pull the passenger side vent off the bumper. The plug is right there behind it. Unplug it. Takes literally 2 minutes.
09rexrunner is offline   Reply With Quote
