Old 09-15-2013, 09:37 PM   #1
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
Default Normal? 04' Baja Turbo w/p&p'd td04 - Video Inside.
Open sourced tuned on 17psi and seems to pull really well, however the turbo screams at just about every rpm. The individual that sold me the turbo said that it makes an unique noise, but I'm questioning whether this is normal. The only thing I can compare it to is a diesel, but it's very high pitched. What do you think? Mods are:
GS 3 port
Ebay DP
Perrin UP
stock intake
Ported and Polished Td04 from this guy, 100% satisfaction. He's done 100s of these and no complaint apparently.
http://www.ebay.com/itm/Wrx-Forester...9077df&vxp=mtr
And my video
https://www.youtube.com/watch?v=bbrN...e_gdata_player
Mr.Chow is offline   Reply With Quote
Old 09-15-2013, 09:49 PM   #2
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Definitely doesn't sound normal. Check for boost leaks or torn inlet tube or anything funny like that.
cowboy_Rob is offline   Reply With Quote
Old 09-15-2013, 10:05 PM   #3
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
i inspected everything before re-installing and nothing was torn. I'm going to do a boost leak test tomorrow.
Old 09-16-2013, 01:24 AM   #4
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Nope not normal at all.
Brother EddieJ. is offline   Reply With Quote
Old 09-16-2013, 08:15 AM   #5
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
then who can tell me what's going on?
Old 09-16-2013, 08:17 AM   #6
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Catless downpipe and some form of metal short ram intake?
Psychoreo is offline   Reply With Quote
Old 09-16-2013, 08:39 AM   #7
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
catless dp and factory airbox.
Old 09-16-2013, 11:11 AM   #8
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
the curiously strange thing is it's still making the noise while the boost gauge is in vacuum. :-P
Old 09-16-2013, 11:44 AM   #9
Psychoreo
Member#: 79643
2015 WRX STI
It's definitely the turbo spinning that's causing the noise. Why it's so pronounced is the question.
Is the downpipe made of tin foil?
Any damage to the fins of the turbo?
Old 09-16-2013, 01:07 PM   #10
Blackfin
Member#: 361325
2010 STi
Dark Gray Metallic
I'd take the inlet pipe off and check the compressor wheel for FOD.
Blackfin is offline   Reply With Quote
Old 09-16-2013, 03:15 PM   #11
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Yeah it almost sounds like an obstruction in the compressor housing or something acting like a whistle.
or you forgot to disconnect your oscilloscope from your speakers.
mechatricity is offline   Reply With Quote
Old 09-16-2013, 04:27 PM   #12
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
it's definitely not coming out of the speakers. It's certainly mysterious.
Old 09-16-2013, 06:22 PM   #13
BraveSTi
Member#: 262030
Sounds like the cops are chasin' you!
BraveSTi is offline   Reply With Quote
Old 09-16-2013, 06:31 PM   #14
PRoJeKV6
Member#: 108315
'04 WRX
WRB, BBS, PTSD, DD's, BRB
PRoJeKV6 is offline   Reply With Quote
Old 09-16-2013, 09:13 PM   #15
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
it does sound just like that, but it's 100% coming out of the engine bay. No boost leaks found today. Someone out there must have heard something like this before...
Old 09-17-2013, 10:24 AM   #16
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
ttt still searching.
Old 09-17-2013, 10:42 AM   #17
Blackfin
Member#: 361325
2010 STi
Dark Gray Metallic
Did you pull the inlet pipe off the turbo and inspect the compressor fins?
Old 09-17-2013, 12:48 PM   #18
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Sure you have good oil flow to the turbo? Could be lack of oil check the banjo bolt filters and the oil feed lines for being clogged
Old 09-17-2013, 04:40 PM   #19
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
if it was that it would have blown a long time ago.
Old 09-17-2013, 05:24 PM   #20
kbobomber89
Member#: 231418
2006 WRX
check your inlet itself. i mean check the turbo and all too but ive replaced inlets on a legacy and an outback making the same noise. even the smallest hole or tear will make a big sound difference.
kbobomber89 is offline   Reply With Quote
Old 09-17-2013, 08:54 PM   #21
cowboy_Rob
Member#: 194062
2003 Impreza WRX
How long has it been doing it?
Old 09-18-2013, 09:34 AM   #22
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
this very well could be it. I'll try to dive into it this weekend. I was kinda thinking the same thing, but my tuner never mentioned anything. I was helping with the install, but after the exhaust and old turbo was out I had to jet and wasn't able to inspect the inlet.
Old 09-18-2013, 09:35 AM   #23
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
Since the turbo first went in.
Old 09-18-2013, 09:37 AM   #24
cowboy_Rob
Member#: 194062
2003 Impreza WRX
How long has that been? A week? a month? 1000 miles or 10,000. Lol
And what was the original reason for replacing it? Just an upgrade or did the original turbo go bad
Old 09-18-2013, 10:33 AM   #25
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
Just as an upgrade, and it's only been about a week. Maybe 150 miles on it.
