Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Old 09-15-2013, 10:44 PM   #1
konman146
Member#: 344553
2002 Impreza Wrx
Default Crawford AOS installed wrong?
I didnt know wether to post this in the modifications section or the newb section so i went with the newb section. I installed a crawford aos on my 02 wrx about 7 months ago. the crank case T tube that crawford gives you wouldn't work for my generation of wrx so i used the stock one. as you know, the stock tube has two arms for the lines. one arm is higher than the other. well my mistake was that i installed the hose that dumps the oil from the aos to the crank case on the higher arm and the vent hose on the lower one. my question is; is it possible for the hose on the lower arm to suck up the oil coming through the hose thats hooked to the upper arm?
i've recently switched the hoses so that they are the way they're supposed to be. i'll attach two pictures of how it is now (the right way). i had it backwards before.
i've been seeing white smoke from my exhaust at idle recently which is why i'm curious about this. i haven't done a comp test or pulled my dp or turbo inlet to check for turbo seals gone bad. those will be my next steps if this doesnt help. it starts to smoke when its warmed up and sits at idle for a good 30 to 60 seconds. ive looked up these systems and I'm thinking either turbo seals or ringlands. but i wanted to see what you guys thought about this first. thanks
konman146 is offline   Reply With Quote
Old 09-15-2013, 11:13 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
White smoke is water/coolant, blue smoke is oil. DP to turbo gasket would produce blue smoke.
Old 09-15-2013, 11:32 PM   #3
konman146
Member#: 344553
2002 Impreza Wrx
It's not coolant. It smells like oil and my coolant levels have stayed the same. It's oil for sure. Unless this new coolant doesn't smell like coolant and smells more like dog sh&t. That wasn't my question but thank you
