Old 09-15-2013, 09:46 PM   #1
_mPizzle_
Member#: 351025
2003 WRX
Sonic Yellow
Default Grinding noise on start up! Not sure where to post.
Hey guys I'm pretty new at this so I don't wanna sound dumb but I've been having this issue and can't seem to find a thread with anyone actually giving an answer to what the problem might be..... I have a 2003 wrx with 138k basically stock and as I turn the key to start it, the engine turns over immediately but it sometimes makes a grinding noise as if I turned the key while the car was already on. It goes for a split second then disappears. It happens intermittently so it's hard to document on video. Happened the other day, it was about 65 degrees out. Seems like it happens more often the colder it is but has happened before when it was 90 degrees out. Any thoughts? I appreciate it.
_mPizzle_ is offline   Reply With Quote
Old 09-15-2013, 10:25 PM   #2
Francois_
Member#: 284101
2004 STI
world rally blue
I always had this happen to my 02 wrx when the weather got cold. I always assumed it was the "actuator" in the starter getting stuck for a moment when it was cold. Never caused a problem so I never took the time to actually diagnose it but it was kind of annoying.
Francois_ is offline   Reply With Quote
Old 09-15-2013, 11:05 PM   #3
_mPizzle_
Member#: 351025
2003 WRX
Sonic Yellow
Good to know for sure. Shoot I hope it stays that way and not saying you're wrong but I feel like there's gotta be a definite answer to it haha
Old 09-15-2013, 11:33 PM   #4
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
Its something with your starter most likely. Make sure the bolts that secure it are tight. The solenoid may also be going bad. While you're there check the teeth on the flywheel for wear.
jerbull88 is offline   Reply With Quote
Old 09-15-2013, 11:38 PM   #5
_mPizzle_
Member#: 351025
2003 WRX
Sonic Yellow
Okay I'll check those. But the solenoid...how do I know it's bad? What do I look for? And idk if this is dumb to say but my flywheel should be okay. I got it resurfaced when I got the clutch replaced ~10,000 miles ago. Plus I'm not that good under the hood yet so to speak.
Old 09-15-2013, 11:44 PM   #6
jam007
Member#: 174706
2008 LGT-B
It's the bendix drive on the starter catching the ring gear, mine does this as well.
jam007 is offline   Reply With Quote
Old 09-15-2013, 11:45 PM   #7
_mPizzle_
Member#: 351025
2003 WRX
Sonic Yellow
So is it a bad thing or what? Haha
Old 09-15-2013, 11:59 PM   #8
jam007
Member#: 174706
2008 LGT-B
Starter is just old mine has 160k on it if I can remember, it'll eventually become toast. Thank God they are easy to replace and don't weight a ton
Old 09-16-2013, 10:56 AM   #9
danger1138
Member#: 279525
04 rex luger!
I thought i was the only one with this issue. I get the problem too always in the winter though. Grinding like the OP described after the engine turns over. As far as i know the starter has never been replaced in my car (169k) . I was scared it had something to do with the weight of oil im using in the winter and my internals.
danger1138 is offline   Reply With Quote
Old 10-01-2013, 01:55 AM   #10
Ride Operator
Member#: 18710
02 GDA PSM
12 Impreza Sprt Lmtd MBP
My 02 has been doing this on and off for the last 6 months or so, good to know I'm not the only one... it actually did it again this morning.
Ride Operator is offline   Reply With Quote
Old 10-01-2013, 09:33 PM   #11
nshipman12
Member#: 369496
04 Subaru WRX
Green
Mine had the same thing, just got it replaced and bam, no grind
nshipman12 is offline   Reply With Quote
Old 10-02-2013, 03:27 PM   #12
Got Groceries?
Member#: 25323
2003 WRX Wagon
I have also read that low battery voltage/amperage can cause this as well, if your battery is old it could be a factor.
Got Groceries? is offline   Reply With Quote
Old 10-02-2013, 08:24 PM   #13
_mPizzle_
Member#: 351025
2003 WRX
Sonic Yellow
You got your starter replaced?
Old 11-08-2013, 11:56 AM   #14
_mPizzle_
Member#: 351025
2003 WRX
Sonic Yellow
I feel like this grinding noise has been getting worse lately, does anyone else have input or should I just go ahead and try replacing the starter?
Old 11-08-2013, 01:11 PM   #15
bugeyesubie117
Member#: 293656
Mine got worse and I replaced the starter. Now it starts like a brand new engine. I recommend doing this.
bugeyesubie117 is offline   Reply With Quote
Old 11-08-2013, 09:03 PM   #16
misfitsfreak81
Member#: 346751
Mine does this as well. Just replace the starter and all will be good. I'll get around to doing mine when I find a good free unit haha. Don't always have to buy stuff.
misfitsfreak81 is offline   Reply With Quote
Old 11-10-2013, 10:49 PM   #17
Wrxstage2yukon
Member#: 371966
I have a 02 and 03 wrx and both do it on cold weather start ups, I've been told it's the release bearing, does goes away if you put load on it.
Don't need to worry about it
Wrxstage2yukon is offline   Reply With Quote
Old 01-06-2016, 01:26 AM   #18
drewbag
Member#: 409296
2004 WRX Wagon
Red
I know this is an old post....
Here's a crappy video of my car starting up. I held my phone outside the drivers door towards the ground. The sound is actually louder inside the car (coming from the location of the starter).
https://youtu.be/hUKkrnRQb_4
The noise only happens every now and then and it's usually cold outside (20 degrees) and my car is not warmed up.
My WRX has 150,000 miles and I'm pretty sure it's the OEM starter. Seems like the best place to start is to replace the starter?
drewbag is offline   Reply With Quote
Old 01-06-2016, 02:00 AM   #19
aaron97
Member#: 295562
'03 STI (JDM)
'12 Shelby GT500
Seems to be a regular thing, my '04 sounds just like your video, but only on cold days after I have let the car set for a days. I'd say its only done that about 3 times this whole summer. If it gets worse, i'll probably try replacing the starter as recommended above.
aaron97 is offline   Reply With Quote
Old 01-06-2016, 09:33 AM   #20
drewbag
Member#: 409296
2004 WRX Wagon
Red
Thanks aaron97 ! Glad to hear it isn't just me. I'll keep monitoring it.
Old 01-06-2016, 12:49 PM   #21
350TPI
Member#: 393653
My 02 also does this.It has a weird delay when i turn the key and then after i have let go of the key it keeps trying to start even though the engine is now running.Its embarrassing when it happens at work on cold days.
350TPI is offline   Reply With Quote
Old 01-06-2016, 12:57 PM   #22
danger1138
Member#: 279525
04 rex luger!
To confirm it is starter related. I replaced my starter and the noise is non existent at all now.
I would get that noise routinely for the last 3 years when temps started to drop around 50* F or lower. The starter never left me stranded so i doubt it was a case of the starter completely taking a crap but, it was the starter non-theless.
Old 01-06-2016, 01:09 PM   #23
drewbag
Member#: 409296
2004 WRX Wagon
Red
Thanks for all the awesome feedback everyone! I am planning on replacing my starter with a new one soon. I live in western NC and it's pretty cold this time of the year, so I'll let everyone know if replacing the starter solved the problem on my vehicle.
Cheers!
Old 01-06-2016, 11:58 PM   #24
aaron97
Member#: 295562
'03 STI (JDM)
'12 Shelby GT500
Funny thing is, my car hasn't done this for weeks, then coincidentally after posting in this thread about, it did it again this morning. It was about 53 this morning.
Good to know just replacing the starter will fix this.
Old 01-07-2016, 01:20 PM   #25
Trudd84
Member#: 250706
2004 Impreza WRX
Wow...this was awesome to find!
Trudd84 is offline   Reply With Quote
