Old 09-20-2013, 09:53 PM   #1
R6_rider
Member#: 138768
2013 evo x
white
Default upgrading past stage 2 (plans in motion)
my 04 wrx has 120k miles on it. i did the timing belt at 110k. Im still on the stock clutch. i only granny shift haha.
so i just picked up a really good condition vf43 and would like to upgrade
my power mods:
MOTOR
invidia catless downpipe
ebay catback
Perrin uppipe
gimmick turbo inlet
gimmick after maf
topmount inlet pipes
mitsimoto radiator
Opensource tuned
SUSP/Brakes
dual adjustable coilovers
32mm front sway
27mm rear sway
Kartboy endlinks
Enkei RPF1's
Hawk pads
Goodridge SS lines
My current plan to go beyond "stage 2"
VF43
Sti topmount
Grimmspeed ewg up
Turbosmart comp 40 ewg
3 port bcs
ID1000 injectors
walbro fuel pump
new tune! (on 93)
im hoping i can get a bit more power out of the car. do you think this will be a safe setup? i really dont even romp on the car that much. just would like to give it some small balls! I track motorcycles so its not my fast fun item, im just looking for a livelier DD.
opinions? Concerns? Comments?
R6_rider is offline   Reply With Quote
Old 09-20-2013, 10:23 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
"safe" will depend on the tune, the tuner, and data logging. Little else matters. What exactly do you want people to say in this thread?
Old 09-20-2013, 11:19 PM   #3
R6_rider
Member#: 138768
2013 evo x
white
I guess its more of a part list run down. do i need anything else or change something for something better?
just looking for options on parts to make sure i havent overlooked something that might make a difference
Old 09-20-2013, 11:40 PM   #4
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
1000's are serious overkill. 650's would be just fine. had a similar setup and loved it.
jerbull88 is offline   Reply With Quote
Old 09-21-2013, 09:08 AM   #5
Member#: 301037
2004 Forester XT
Sounds like a good setup, but like Hinshaw said the tune is what makes it "safe"
art@grimmspeed is offline   Reply With Quote
Old 09-21-2013, 12:16 PM   #6
R6_rider
Member#: 138768
2013 evo x
white
My tuner said id1000, he said he wont touch any thing but id and fic. The 1ks also leave me room to go e85 if i want to.
Old 09-25-2013, 10:04 PM   #7
Phreddie33
Member#: 369292
Noice!
Phreddie33 is offline   Reply With Quote
Old 09-26-2013, 02:56 PM   #8
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
does your tuner go by "the foss"?
shamrock 05 is offline   Reply With Quote
Old 09-26-2013, 03:54 PM   #9
danger1138
Member#: 279525
04 rex luger!
U should upgrade your front brake calipers at least to the 4pots if your gonna b making more power.
danger1138 is offline   Reply With Quote
Old 09-26-2013, 04:18 PM   #10
Ihaveawagon
Member#: 366807
That makes no sense at all. The brakes on the car are designed to handle the specifications of the car. He is not adding weight, at least a significant amount of weight, or larger wheels. So he is not increasing inertia. He will not have the gas pressed down while braking (I hope). He will be going staying within the speeds the car was designed for, just moving around in the area alot quicker.
Ihaveawagon is offline   Reply With Quote
Old 09-26-2013, 06:12 PM   #11
R6_rider
Member#: 138768
2013 evo x
white
Im still really nervous about popping the motor and or trans. Motor more so than trans
Old 09-26-2013, 08:19 PM   #12
danger1138
Member#: 279525
04 rex luger!
Wouldnt u want the peace of mind knowing u can stop on a dime , quicker due to the weight argument u just threw at me.
Old 09-26-2013, 09:08 PM   #13
Ihaveawagon
Member#: 366807
How can you stop quicker? If you lock up the brakes its going to be the same no matter how big your brakes are. Its at that point the product of the friction between the tire and the road surface. Since you can lock your brakes up with either setup, its about finding the pressure point in which you can apply maximum pressure on the rotors without locking them up.
More pucks/more pad surface area just reduces the amount of pressure used to stop. Thus it also decreases the amount of pressure it takes to lock up the wheel.
Which brings me to a good point. If you do not already have quality tires, I suggest that as an upgrade. They help put the power down and all the other bull****, cornering and safety and whatnot.
Old 09-27-2013, 07:27 AM   #14
BoboTheMonkey
Member#: 224615
2004 WRX
San Remo Red
I wouldn't be too worried. That turbo is a fairly modest upgrade. Have it leak down tested before installation. I've had my VF series turbo on for about 20k and about 15k of stage 2 prior. More worried about the clutch now at 80k. The engagement is getting a little sketchy and I think I'm getting some slop in the throw out. You can also alway go a little conservative with the tune. Tell the tuner what you are looking for.
BoboTheMonkey is offline   Reply With Quote
Old 09-27-2013, 09:55 AM   #15
dfyjghkmgvhwen
Member#: 369440
dfyjghkmgvhwen is offline   Reply With Quote
Old 09-28-2013, 11:37 PM   #16
conklin_02
Member#: 324190
2005 wrx STi
Don't do it. Leave it stage 2. With that mileage, you will run into issue.
conklin_02 is offline   Reply With Quote
Old 09-28-2013, 11:40 PM   #17
conklin_02
Member#: 324190
2005 wrx STi
How can you stop quicker? If you lock up the brakes its going to be the same no matter how big your brakes are. Its at that point the product of the friction between the tire and the road surface. Since you can lock your brakes up with either setup, its about finding the pressure point in which you can apply maximum pressure on the rotors without locking them up. More pucks/more pad surface area just reduces the amount of pressure used to stop. Thus it also decreases the amount of pressure it takes to lock up the wheel. Which brings me to a good point. If you do not already have quality tires, I suggest that as an upgrade. They help put the power down and all the other bull****, cornering and safety and whatnot.
This is great. Go home, your not a physics major, you don't know what your talking about. Research before you speak
Old 09-29-2013, 12:09 AM   #18
R6_rider
Member#: 138768
2013 evo x
white
really think ill have an issue? i mean i take good care of the car and dont romp on it all the time
Old 09-29-2013, 12:13 AM   #19
ko843030
Member#: 310482
2013 G37x
Sell it. Use all that cash in upgrades to buy a decent mileage sti. Poof.
ko843030 is offline   Reply With Quote
Old 09-29-2013, 08:34 AM   #20
conklin_02
Member#: 324190
2005 wrx STi
Doesn't matter how well you take care of it. It's like anything, the more it's used, the more likely it is to break. Honestly, if you really want more power, but a sti, or make yourself a project and do a hybrid build. Or get a completely new motor. There are a hundred different route you can go. But I opt to say, do not go last stage 2
Old 09-29-2013, 10:48 AM   #21
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Compression test first. If the numbers check out, go for it. It will give you peace of mind knowing the motor is healthy.
Brother EddieJ. is offline   Reply With Quote
Old 09-29-2013, 10:55 AM   #22
conklin_02
Member#: 324190
2005 wrx STi
It's too much of a risk. Call any reputable tuning shop. They would not recommend what he wants at this mileage. If you have money for a rebuild, go for it. To me, you should call some tuners, get their input, and go from there. It's too risky
Old 09-29-2013, 02:20 PM   #23
Ihaveawagon
Member#: 366807
Actually I am posting from home. Mechanical engineering actually. Please explain how I'm wrong.
Old 09-29-2013, 02:44 PM   #24
rexblake
Member#: 178426
2010 S4
Gray
Your over simplifying the problem. Yes, stock brakes allow one panic stop. Of course, with a significantly more powerful car, higher speeds will be achieved faster and more consistently than with a less powerful car. Which means you need to think of fade.
Also, feel comes into play. Bigger brakes have a better feel to it (of course, fluid, stainless lines help as well), particularly with the Subaru 4 pot and H6 upgrade in the rear vs stock 02/03. Stock brakes on the early WRX's are absolutely terrible. I understand he has the 4 pots already, but maybe he would like the feel of larger brakes, which inspires more confidence, later braking, and faster times.
Telling people that they should increase power and never upgrade their braking system is simply illogical, not to mention dangerous. You want a balanced car, not one that can go 150 but the brakes fade while trying to stop once. What level you upgrade to can be debated, but fluids, lines, pads should always be mandatory. Track days may require big brake kits, certainly on the WRX's they would.
rexblake is offline   Reply With Quote
Old 09-29-2013, 02:54 PM   #25
Ihaveawagon
Member#: 366807
livelier daily driver.
