Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 09-23-2013, 06:53 PM   #1
16gsuby
Member#: 150696
2005 WRX
white
Default very hard start
So I have a very hard start every time...so when the car turns off the pressure drops very fast in the gauge from 55psi to 0 in matter of seconds,i had a previous problem of the car lugging when i would give it gas and found out the fpr was bad.so i got it replaced and it worked great.Now i have this hard start but no driveability problems at all,once the car starts it drives fine.Haven't been able to find a thread on this problem,please help Nasioc...btw i have a 255 Walbro and might think this is the culprit,let me know what u guys think
16gsuby is offline   Reply With Quote
Old 09-23-2013, 07:52 PM   #2
Francois_
Member#: 284101
2004 STI
world rally blue
What does your fuel pressure do when you prime it, before you actually start it?
Francois_ is offline   Reply With Quote
Old 09-23-2013, 09:11 PM   #3
16gsuby
Member#: 150696
2005 WRX
white
It shoots up to 60psi then looses pressure in the matter of seconds
Old 09-24-2013, 06:22 PM   #4
16gsuby
Member#: 150696
2005 WRX
white
Anyone that could help me?
Old 09-24-2013, 08:26 PM   #5
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
I believe your fuel pressure is low. Mine primes 80psi(same pump). Maybe a restriction or bad pump?
jerbull88 is offline   Reply With Quote
Old 09-24-2013, 10:03 PM   #6
16gsuby
Member#: 150696
2005 WRX
white
I think its the pump too, but how come out drives fine when it gets started?
Old 09-24-2013, 10:17 PM   #7
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
Classic symptoms of a failing pump. Ever heard of people tapping the gas tank to get a start?
Old 09-24-2013, 11:23 PM   #8
16gsuby
Member#: 150696
2005 WRX
white
Yeah i have,i just wanna make sure before i buy a new pump..any easy way to test it?
Old 09-25-2013, 07:38 AM   #9
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
Switch it for your stock one.
Old 09-25-2013, 08:04 AM   #10
16gsuby
Member#: 150696
2005 WRX
white
I have no stock one, changing the pump isn't that bad...guess I'll to get a new pump
Old 10-01-2013, 05:13 PM   #11
bg5guy
Member#: 286728
Is your problem anything like this ? There is video towards the end of the thread.
let me know if fuel pump helps.
http://www.westernsubaruclub.com/smf...?topic=35882.0
bg5guy is offline   Reply With Quote
