Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 03-19-2003, 10:32 PM   #276
SoLiDbReAkZ
Member#: 13736
I bought another rubber cup that's part of the Subaru/LaMco gauge kit. It cost $100 @ Exeter Subaru in NH....but Exeter was the ONLY dealership that I called that would just sel me the cup. It sure cost a lot for a chunk of rubber..but it looks pretty OEM
SoLiDbReAkZ is offline   Reply With Quote
Old 03-19-2003, 10:34 PM   #277
chobits
Member#: 22489
wow ....... great price but u get what u want
congrats!
those are omori gauges?
chobits is offline   Reply With Quote
Old 03-19-2003, 10:35 PM   #278
SoLiDbReAkZ
Member#: 13736
yes indeed!
Old 03-20-2003, 12:28 AM   #279
Vostok 7
Member#: 30209
Do you need to
read this in Braille?
How'd you get your omori's in?
When I put my boost gauge in my rubber cup it was like trying to get Chris Farley in a speedo.
Vostok 7
Vostok 7 is online now   Reply With Quote
Old 03-20-2003, 02:45 AM   #280
SoLiDbReAkZ
Member#: 13736
Vostok 7
damn dude...that line almost made me wet my pants
WD40 is your best friend...
spray some on your fingers, and wipe on inside of the mounting cup and then on the outside rim of the gauge. Align carefully (once it's in there...its IN there!) and push the gauge into the cup...back and forth...little by little..until it slides all the way in
anyway..with a little carefulness, deliberation and lubricant it should slide in NO PROBLEM
(this sounds gross )
Old 03-20-2003, 02:48 AM   #281
chobits
Member#: 22489
i'm wondering ......... does anyone have the picture of the Autometer Carbon Fiber Look Gauges at night
I wanna see it !!!!!!! no one seems to know or has the picture of these gauges
now i'm going berserk
Old 03-20-2003, 08:10 AM   #282
no_rex_yet
Member#: 7351
04 330cic
FYI, the $30 HKS 48mm cup works great with the 45mm Omori gauges. I have one on my column just like the pic above. Ordered it from www.hksusa.com
hey SoLiDbReAkZ, very nice
what kind of mounting you use?
it looks perfect
can you tell me where to get that?
thanks
no_rex_yet is offline   Reply With Quote
Old 03-20-2003, 01:19 PM   #283
Derres Catalano
Member#: 3244
2000 2.5 RS
Silverthorn
If you like cups I think the Auto Meter carbon fiber cups are the best looking.
You can buy them at summitracing.com for $37.95. Pricey, but they look soooo good.
-D
Derres Catalano is offline   Reply With Quote
Old 03-20-2003, 01:31 PM   #284
SoLiDbReAkZ
Member#: 13736
wow..they look nifty
at $40..I could have bought 3 of these for the price of that stupid rubber cup I'm dumb
Old 03-20-2003, 02:16 PM   #285
Verdugo
Member#: 15341
2012 Borderline Pro
Photographer of the Year
Verdugo is offline   Reply With Quote
Old 03-20-2003, 02:47 PM   #286
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
My one lonely gauge.
Cosworth is offline   Reply With Quote
Old 03-20-2003, 04:05 PM   #287
Vostok 7
Member#: 30209
Do you need to
Ahahaha, that's almost exactly what I ended up doing. First I relieved the "shelf" a bit and tried shoving it in and it didn't go very well so I got it about 3/4 of the way in and then started spraying WD40 in there It worked but now it's crooked slightly Although my stock one was a touch crooked too.
But I'm real happy with it. I'll have to get some picts of my current gauge setup.
Vostok 7
Old 03-21-2003, 12:19 AM   #288
SoLiDbReAkZ
Member#: 13736
get two long and thin flat head screw drivers..then open up the cup a little and spray a lil' WD. do that left, right, top, bottom. Then reinsert the screwdrivers on opposing sides and push/pry both at opposing angle AWAY from the gauge itself. ONce it start to get loose a bit, just use the screw drivers and your fingers to shimmy it out of the cup. I was in the same boat as you...the EGT on the left came out really crooked..I used this method and I re-aligned it pretty nicely!
WD40 dries in a matter of minutes, so you need to be 'with da' quickness!
Old 03-21-2003, 10:15 AM   #289
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
Default Have to break up the WRX party...
Here ya go...
DanzBorin is offline   Reply With Quote
Old 03-21-2003, 10:34 AM   #290
vapore0n
Member#: 21356
2010 BMW 335i
try routing the radar cable with one of those cables that go to the fuse box, easy to do and a lot cleaner.
vapore0n is offline   Reply With Quote
Old 03-22-2003, 11:55 AM   #291
jcme262
Member#: 13694
Originally posted by Verdugo
about Armin j/k how you like em, looks great, couple more weeks and I should be ready post mine.
jcme262 is offline   Reply With Quote
Old 03-22-2003, 11:57 AM   #292
UU AR EX
Member#: 5543
2002 LNR WRX Wagon
Aspen White with CF stuff
Hey, for a second there I thought your car was parked in my garage, with all those boxes.
Nice set up!
UU AR EX is offline   Reply With Quote
Old 03-22-2003, 11:59 AM   #293
Verdugo
Member#: 15341
2012 Borderline Pro
Heh now that they're working properly, they totally own
Old 03-23-2003, 07:08 PM   #294
Vostok 7
Member#: 30209
Do you need to
Time to pwn3 Armin.
Vostok 7
Old 03-24-2003, 12:47 AM   #295
Murray
Member#: 11312
2009 Gray
Legacy 2.5i
nothing special here..
Nordskog RED digital vac/boost(got from a friend with a WRX...still gotta trade for a vac. only gauge)
and oil PSI.
i also changed my dash bulbs all to red, so everythign matches nice an purdy at night.
i will try for a night shot when i get a decent camera.
i also have a out-side temp gauge to go with these..but have no where to put it.
Murray
1997 2.5RS-L
Murray is offline   Reply With Quote
Old 03-24-2003, 10:30 AM   #296
Turk
Member#: 1888
Originally posted by Newbie Subie
My Defi BF's with custom pod.
What size gauges are those?
Turk is offline   Reply With Quote
Old 03-24-2003, 10:37 AM   #297
DanzBorin
Member#: 7131
2015 Outback - Croc
Is fisheye a size...
Old 03-24-2003, 12:21 PM   #298
silverbetty
Member#: 23851
2013 Legacy
Gray
Time to pwn3 Armin.
Vostok 7
Vostok 7-
What brand, style, etc gauge is your boost? It look sweet, they way it matches the OEM backlighting.
Thanks,
Tom
silverbetty is offline   Reply With Quote
Old 03-24-2003, 12:43 PM   #299
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Originally posted by TheNewGuy
Vostok 7-
Thanks,
Tom
That's amore' ......I mean Omori.
(that's why I bought them as well)
Kean is offline   Reply With Quote
Old 03-24-2003, 01:00 PM   #300
silverbetty
Member#: 23851
2013 Legacy
Gray
Very Nice!
Thanks,
Tom
Post Pics Of Your Navigation Setup ( Eclipse , N1 ,N2 .... ) minx1225 Interior & Exterior Modification 1 09-06-2005 01:43 AM
Post pics of your FMIC setup KitchenerWRX Member's Car Gallery 2 08-30-2005 01:27 PM
Post pics of your gauges lit up... MomoWRX Electrical & Lighting 22 12-11-2004 10:21 PM
post pics of your gauge clusters/bezels 03wrx 03twrx South East Region Forum 5 11-13-2004 09:28 PM
Post Pics of your gauges and cluster shots! Leo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 02-19-2004 10:16 AM
