Old 04-23-2003, 01:08 AM   #351
Vostok 7
Member#: 30209
Do you need to
read this in Braille?
Wow, that's cool. I was thinking about getting the Sports VSD HUD which shows RPM and speed and all that.
The HUD only costs about $250 and there's no need for the sensors. I'd still consider that one since I'm having trouble figuring out where to put gauges
Vostok 7
Vostok 7 is offline   Reply With Quote
Old 04-23-2003, 01:19 AM   #352
jackansi
Member#: 23894
'07 3.2L Audi A4
The link display comes with the wiring for the speed, the rpm signal hooks up to the defi controller and only cost $10 for the tach wiring kit. So for about 350 you can have the link display, v2 controller, and the tach line. You'll also be all set to upgrade that way.
I tapped my rpm and speed signals straight off the ECU connectors, just used an amp connector pin removal tool (a jewelers screw driver would work if you are good with your hands), pulled the right wires (as detailed on http://www.northursalia.com/m...ng/wrxpin.html) and soldered the defi wires onto the base of the OE wire. push the pin in until it stops and you're done. About a 45 minute job including cleanup.
jackansi is offline   Reply With Quote
Old 04-25-2003, 04:20 PM   #353
GiJoe
Member#: 19279
2002 Impreza WRX
Rally Blue
Finally got mine in! Custom face plate, took about 4hrs!
GiJoe is offline   Reply With Quote
Old 04-25-2003, 05:20 PM   #354
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
all i see is the newer interiorsd what about the older ones~! show show show
scoobyimpreza is offline   Reply With Quote
Old 04-25-2003, 05:31 PM   #355
Dave_MacKinnon
Member#: 10823
2007 STi
VERY Clean GIJOe, nice work. I have to do that for someone, I owe them a favour...
Dave_MacKinnon is offline   Reply With Quote
Old 04-26-2003, 01:59 AM   #356
Omis
Member#: 18459
02 WRX
Default Help! Stock gauge dilema.
I have the stock gauge pack and wanted to get new gauges, however i still need voltage and oil temp but i want a different boost gauge (one that reads in psi). I was going to sell the stock pack but realize that i still need the oem pod, unless i get that monstrous defi THING. Should I just change the boost gauge with an omori 45mm psi boost? or swap all three out? I am somewhat concerned about price but still want it to look good and be accurate. Any opinions? Also, if i want to remove the stock oem pod, do I have to remove the cupholder and undo all the screws or just pull the oem pod up with a little force? I seemed to find conflicting reports about this.
Thanks
Omis is offline   Reply With Quote
Old 04-26-2003, 02:10 AM   #357
GiJoe
Member#: 19279
2002 Impreza WRX
Rally Blue
well what gauges housing do you want?? I dont' think any thing should have to come out expect clock. Sorry me drucnk not very here now...get 52 or 60mm you be good 52 fit in stock pod, 60mm no for stock.
Ducnk guy
Old 04-26-2003, 03:31 AM   #358
Drew888
Member#: 6459
2008 LGT Spec-B stg4
Delicious Tuned 336/336
GiJoe...great job!
I would buy Derres face plate but I want my guages more set back into the pod. It looks soooo much better that way.
What supplies do I need to tackle this job myself?
Drew,
Drew888 is offline   Reply With Quote
Old 04-26-2003, 04:14 PM   #359
peepers
Member#: 31800
a dremel
a very steady hand
something you can fabricate and make a faceplate with. some people use aluminium from a hobby shop. then you can get some black paint or even keep it silver.
be very careful with the dremel when grinding the OEM gauge pod. i already trashed one. now i am on my second.
peepers is offline   Reply With Quote
Old 04-26-2003, 04:46 PM   #360
GiJoe
Member#: 19279
2002 Impreza WRX
Rally Blue
Yup thats pretty much it, I'll post pics of all the tools used to make alittle easier.
Also make a template on paper and tape it to your "face plate to be" plastic/metal.
Old 04-26-2003, 08:01 PM   #361
Eskram
Member#: 16697
2004 2.5 Hybrid 18g
Wagon + LGT 1-4 g00dness!
Nothing spectacular, but they work..
Eskram is offline   Reply With Quote
Old 04-26-2003, 09:19 PM   #362
Imprezive2002
Member#: 18872
2002 Impreza
where can i find a 2 piller pod for my drivers door in Gray everywhere i look has them in black only im a little disappointed if someone could let me know id appreciate it thanks `Nick
Imprezive2002 is offline   Reply With Quote
Old 04-26-2003, 11:09 PM   #363
Omis
Member#: 18459
02 WRX
Eskram,
I like your "moto motto"
Old 04-27-2003, 11:42 AM   #364
imprezive one
Member#: 16906
2k3 wrx wagon
hahaha, what is that little taped on "think" note for? So you think twice before you go that much over the speed limit? That's funny.
imprezive one is offline   Reply With Quote
Old 04-27-2003, 01:17 PM   #365
peepers
Member#: 31800
www.autometer.com ????
Old 04-27-2003, 03:55 PM   #366
Imprezive2002
Member#: 18872
2002 Impreza
so you have to get the pods painted or some come factory gray?
Old 04-28-2003, 09:59 AM   #367
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Might as well throw mine in here too.
Gauges (car not on)
Gauges (car on)
and finally the control unit:
Hope you like. The display shows oil and exhaust temp with peak record on boost, oil, exhaust, and speed!
mbiker97 is offline   Reply With Quote
Old 04-28-2003, 11:36 AM   #368
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Greddy gauges with lo-tek pillar pod. Painted the pod myself
Hank3 is offline   Reply With Quote
Old 04-28-2003, 12:07 PM   #369
vapore0n
Member#: 21356
2017 STI Limited L!
Blue, the prettier one
Ive got the same type of pillar. Have to work on it because it hanging by some mounting tape. Ill post some more pics of mine this weekend after I fix the pods, so you can see how the digital clock looks at night
vapore0n is offline   Reply With Quote
Old 04-28-2003, 02:39 PM   #370
silverbetty
Member#: 23851
2013 Legacy
Gray
Nevermind...
silverbetty is offline   Reply With Quote
Old 04-28-2003, 03:13 PM   #371
STi Boy
Member#: 3401
2013 BRZ
WORLD RALLY BLUE
what companies gauges come in blue backlight and does all gauges have the "sweeping" feature when u start up the car?
STi Boy is offline   Reply With Quote
Old 04-28-2003, 08:52 PM   #372
GiJoe
Member#: 19279
2002 Impreza WRX
Rally Blue
Gauges (car not on)
Your from the states yet you have a Canadian $20 in your car?! You must like our money better!
Old 04-28-2003, 10:12 PM   #373
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
STiBoy: Those are the Blitz gauges I believe. All the Defi unit have the start up sweep as well.
GiJoe: I actually found that money when I was figuring out where to mount my gauges. $40 cdn in the ashtray. I live near Detroit so we head over to Windsor every once in a while to go visit the uh ballet.
Old 04-29-2003, 02:00 AM   #374
Imprezive2002
Member#: 18872
2002 Impreza
hank3
you had to paint your pod it didn't come painted the color of your car cause all the newer subarus have gray on the inside yours came black and if it did what kinda paint did you paint it with?
Old 04-29-2003, 08:52 AM   #375
vapore0n
Member#: 21356
2017 STI Limited L!
the pod is like the autometer, comes unpainted black. I was suggested warm grey, but in reality is more darker than that shade. Primer grey seems to be more of a match. You could take the hanger from the rear holding bars and go to a hardware store and find a match
Post Pics Of Your Navigation Setup ( Eclipse , N1 ,N2 .... ) minx1225 Interior & Exterior Modification 1 09-06-2005 01:43 AM
Post pics of your FMIC setup KitchenerWRX Member's Car Gallery 2 08-30-2005 01:27 PM
Post pics of your gauges lit up... MomoWRX Electrical & Lighting 22 12-11-2004 10:21 PM
post pics of your gauge clusters/bezels 03wrx 03twrx South East Region Forum 5 11-13-2004 09:28 PM
Post Pics of your gauges and cluster shots! Leo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 02-19-2004 10:16 AM
