Old 10-17-2002, 01:02 PM   #51
wrixer
Member#: 22982
2002 WRX Sport Wagon
2000 Suzuki Hayabusa
Thumbs up
These are all great! More, more, more!!!!
wrixer is offline   Reply With Quote
Old 10-17-2002, 05:46 PM   #52
Syntax
Member#: 14452
What size does people normally use? 52mm or 60mm?
Syntax is offline   Reply With Quote
Old 10-17-2002, 10:44 PM   #53
romoranger
Member#: 14701
94 camaro
big cam/heads/slicks
what do you guys think if an aluminum face plate was used in a wrx to back the gauges. i am going to do it this weekend if i can find time and them i will post here.
romoranger is offline   Reply With Quote
Old 10-18-2002, 12:38 AM   #54
RIwrx
Member#: 15886
i'll be getting my 60mm's (defi BF)- personally, 60's look more fitting than the 52's. but, and respectfully, to each his own.
i put my link meter v2 in my glove compartment, running the wiring through a small hole i drilled- stealth. clean. i'm happy. what do you guys think?
to defi owners- where did you guys put your control unit?
also, to anyone w/ the greddy A/F and the defi meter hood- any fitment issues? i assume it's a nonissue, but just pooping out the question just in case.
RIwrx is offline   Reply With Quote
Old 10-18-2002, 10:13 AM   #55
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Originally posted by imprezive one
Did you make that pod yourself or did you buy it somewhere?
Yes and know... When subee-sound.com was running good (it's pretty much dead now) Kevin and I designed this for my RS, he mad it and it turned out so good that he desided to sell them. I really miss it as my MY97 is a different dash/layout and there is no where to even consider something like this.
e-mail Kevin [email protected] or [email protected] and ask him about it. he could probablly throughs something together real quick... only issue will the the lack of a storage pocket (bottom section).
omahasubaru is offline   Reply With Quote
Old 10-18-2002, 08:33 PM   #56
aspera
Member#: 7879
I'm subscribing to this thread so I'll remember to post pics when I get my gauges in.
BEHOLD!, I will have ALL of the Defi BF gauges (mwhahaha). They will be mounted in a Defi pod and a triple Lotek A-pillar pod. In addition, I will move my two 60mm Apex'i EL gauges to the space below the cigarette lighter.
So basically, It'll be a frickin' light show when I start up the car.
aspera is offline   Reply With Quote
Old 10-19-2002, 12:48 PM   #57
WayneS
Member#: 6123
WR Blue Pearl
has the problem with the lotec pillar pod pointing the gauges too far to the left been resolved?
WayneS is offline   Reply With Quote
Old 10-19-2002, 08:27 PM   #58
aspera
Member#: 7879
I was stupid enough to get an early and a later version of the Lotek pillar pods. Neither one of them was 60mm. I had to use a file to make the holes bigger. I prefer the early version of the pod. I don't think the gauges are pointing away too much. If they were pointing right at me I'd get a weird reflection off of the Defi BF gauges. I'd see three convex reflections of my tiny head.
I would like to see a pillar pod that doesn't create such a huge blindspot, though.
Old 10-19-2002, 08:42 PM   #59
ThaTaint
Guest
Member#:
i'm to lazy to be original.. **** i just bought soobies lil Turbo guage... CUZ IM LAZY!!
Old 10-19-2002, 10:48 PM   #60
bjteel
Member#: 14442
2002 WRB WRX
romoranger, I am would like to see the aluminum back plate...
I too have the column-mounted Subaru gauge, so I don't know if I will get the full blown gauge pack. I had considered getting just the housing and putting the stock clock and and an EGT or air/fuel ratio gauge in it with a Subaru decal (like the WRC car).
Thoughts...?
bjteel is offline   Reply With Quote
Old 10-19-2002, 11:07 PM   #61
romoranger
Member#: 14701
94 camaro
my gauges will be up late tomorrow - tuesday, as sourcing the t-fittings seems to be hard here in allentown.
Old 10-20-2002, 07:03 PM   #62
sick1.8t
Member#: 22345
2003 RSX
black
does anybody know if you can fit four 2 1/16" gauges on the a pillar? i have a '93 impreza, but i think the pillar length is about the same for some years after.
thanks
sick1.8t is offline   Reply With Quote
Old 10-20-2002, 07:12 PM   #63
sick1.8t
Member#: 22345
2003 RSX
black
and here's my consol, so far unfinished. the color is really a nice red, but the webcam i used to take the picture has booty for quality.
Installed gauges (in consol):
oil pressure
amp draw
water temp
soon enough a 5.6lcd sceen should be going in just above the gauges.
sorry, but i dont have any pics of the rest of my dash.
Old 10-20-2002, 09:31 PM   #64
Mrsir
Member#: 12720
2008 Porsche
Cayman S - Red
Exclamation !
ignore the missing gauge, work in progress
Mrsir is offline   Reply With Quote
Old 10-20-2002, 11:45 PM   #65
aspera
Member#: 7879
Stuff a trunkmonkey in the hole. That should stun people. Nobody expects a trunkmonkey.
Old 10-21-2002, 12:06 AM   #66
aspera
Member#: 7879
almost forgot...I went out and got a 60mm (2 3/8 in) hole saw today. I drilled 2 holes in the flat area below the cigarette lighter. I then had to Dremel a little bit because the edges curve up. Anyway, I remounted 2 60mm gauges there.
lessons:
*Drill s--l--o--w--l--y. When that hole saw digs into the plastic, the drill will go flying! Your hand will go with it. AMHIK.
*Use gauges smaller than 60mm is possible, unless you are a good Dremeller. I'm not. I'm lucky not to be in the hospital.
*Deep gauges like the Apex'i EL units fit. There's a lot of room under there. I did snip off the rubber nipple under the carpet, though.
*Don't expect to see the gauges very well, unless you're reeeeeal tall.
Old 10-21-2002, 12:11 AM   #67
aspera
Member#: 7879
one more thing
I removed the ash tray and routed the ash tray light over to the driver's footwell. I can see my feet! Hallelujah!
Old 10-21-2002, 03:12 PM   #68
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Old Skool
Here is my custom setup on my old skool turbo wagon
Joshua
and the normal Autometer pillar pod
yebokmj is offline   Reply With Quote
Old 10-21-2002, 04:27 PM   #69
vapore0n
Member#: 21356
2010 BMW 335i
anyone know if it exist a dual meter guauge? as in a gaugue that has 2 different dials in the small same size of the gaugue. Im planning on doing then a 2 pod pillar set. So one is boost, the other, well if it does exist, then a dual.
vapore0n is offline   Reply With Quote
Old 10-21-2002, 05:42 PM   #70
TonyWRX
Member#: 21146
do you mean 1 gauge that measures 2 different vitals signs of the car??
TonyWRX is offline   Reply With Quote
Old 10-21-2002, 10:00 PM   #71
AndyWRXWG
Member#: 23784
2005 M3
Tiag
hey how did you do the cluster area one? I want the autometer but not out yet... I really want my gauges there can you do a write up?
AndyWRXWG is offline   Reply With Quote
Old 10-21-2002, 10:09 PM   #72
Extraze
Member#: 16980
Default There ya go
DAY
NIGHT
Extraze is offline   Reply With Quote
Old 10-22-2002, 01:47 AM   #73
aspera
Member#: 7879
Default confused
Are you asking me a question? I can't figure out your post.
Old 10-22-2002, 01:48 AM   #74
aspera
Member#: 7879
Default confused
Old 10-22-2002, 07:46 AM   #75
vapore0n
Member#: 21356
2010 BMW 335i
yep
Post Pics Of Your Navigation Setup ( Eclipse , N1 ,N2 .... ) minx1225 Interior & Exterior Modification 1 09-06-2005 01:43 AM
Post pics of your FMIC setup KitchenerWRX Member's Car Gallery 2 08-30-2005 01:27 PM
Post pics of your gauges lit up... MomoWRX Electrical & Lighting 22 12-11-2004 10:21 PM
post pics of your gauge clusters/bezels 03wrx 03twrx South East Region Forum 5 11-13-2004 09:28 PM
Post Pics of your gauges and cluster shots! Leo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 02-19-2004 10:16 AM
