Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 10-22-2002, 11:10 AM   #76
axis
Member#: 13382
06 STi
WRB/Gold
Originally posted by AndyWRXWG
hey how did you do the cluster area one? I want the autometer but not out yet... I really want my gauges there can you do a write up?
I already wrote how I made the instrument cluster bezel. I used the original bezel, cut it, bondo-ed it, fiberglassed it, and bondo-ed it again. Then paint, sand, paint, sand, paint. If you need more pics just give me holler. The ones I took of the finished piece were pretty shatty, so they don't really do it justice.
Dan
axis is offline   Reply With Quote
Old 10-22-2002, 11:21 AM   #77
TonyWRX
Member#: 21146
Default Re: There ya go
is that the lotek gauge pod?? Does it angle too much to the left like lots of people complain?
Originally posted by Extraze
DAY
NIGHT
TonyWRX is offline   Reply With Quote
Old 10-22-2002, 05:43 PM   #78
axis
Member#: 13382
06 STi
WRB/Gold
AndyWRXWG,
About Autometer, that's why I took it apon myself to make the instrument cluster bezel. It holds two 52mm gauges(60mm would be way to big and would block the factory gauges).
Making the pods took a whole lot of "Oh well, here it goes". Use a dremel to cut the factory bezel just enough to hold the aftermarket gauges in place. Then I used masking tape to hold the gauges where I wanted them so I could I could bondo up the outer sides of the bezel. ouce the outer sides were done then I used fiberglass to form the inner cups(so I no longer needed tape to hol the gauges in place). After that, I continued using bondo to round off the edges and get that nice smooth finish You expect to see in any custom work.
I know reading this isn't going to make a whole lotta sense. I wish I had more pictures of the work in progress but I didn't get a digital camera until the last couple of stages. If you live around the Portsmouth,NH area you can come and visit me at Circuit City and I can explain it in greater detail.
I'll stop ramblin' on now...
Dan
Old 10-23-2002, 05:57 PM   #79
WayneS
Member#: 6123
WR Blue Pearl
if the pic above is the lotek pod, it looks pretty good...now where can I get one at a good price???
WayneS is offline   Reply With Quote
Old 10-23-2002, 07:00 PM   #80
Extraze
Member#: 16980
Default Re: Re: There ya go
yep, that is the Lo-Tek pod...
about the angle thing, the 2 bottom ones dont face left at all... they are really centered, the top one has a little angle, but barelly noticeable ...
my only problem about that pod (I am REALLY picky) is that the weatherstriping does not cover it entirely at the top (where the pod meets the roof) and it gets anoying sometimes ... its just 1/8th of an inch or so, but it was enough to make me real pissed when i first got it, maybe its just the fact that i didnt drill the holes close enough to the roof, or whatever... ill try to fix it later this month...
but besides that, the paint is really closest match you will ever get, it serves its purpose ! for ~50$, you cant go wrong
Extraze is offline   Reply With Quote
Old 10-23-2002, 07:18 PM   #81
TanXP
Member#: 19971
2003 Impreza WRX
the best blue- WR Blue
Default Gauge in the Air Vent
I really like the look and idea of the gauge being in the air vent. One of you posted it and im too lazy to go back since my comp is slow right now. Would you have to cut off air to that vent since cold/hot air would still flow through there otherwise? How? Another cool thing I would like to have (not ever gonna happen) is a LCD pop out screen that can show where the cops are at with the Valentine radar. Kinda like jets have. I hate how cops pull an instant on me and gives me a freakin heart attack. I wonder how i could to that...
TanXP is offline   Reply With Quote
Old 10-23-2002, 10:20 PM   #82
annointed
Member#: 5960
FXT 11.6@118 93 oct
NSX 450 whp SC'd (93 oct)
Here's an old pic of my gauge set-up. I now havea knock link mounted on the switch knockouts to the right, right above the windshield wiper lever. I also have my AVC-R and Power FC mounted in the center panel and dash, each displaying gauges/info. I'm going to put 3 more gauges (oil press, oil temp, and fuel press) in the single din above my stereo, to top it all off!
Edit: BTW, the gauges, are, from left to right: Autometer EGT, Blitz DTT (boost gauge), Valentine 1 remote display, Autometer A/F.
annointed is offline   Reply With Quote
Old 10-23-2002, 10:21 PM   #83
JimmyOOOOO
Member#: 12647
2011 STi
Obsidian Black Swirl
JimmyOOOOO is offline   Reply With Quote
Old 10-24-2002, 01:52 AM   #84
aspera
Member#: 7879
Default I played with too many LEGOs when I was a kid
I am now a Defi Maniac. I have 6 BF gauges installed. There are 3 in the Defi pod, 3 in a LoTek A-pillar. The V2 Control Unit is in the glove box. I'm not sure what to do with the second V2 CU (got with second set). I mounted the warning light on the door by the mirror. It has a curved base, so it's hard to find a good place if you don't mount it on the plastic cups.
The only thing I don't have done is installing a few sensors. Fuel, Water, EGT need to be hooked up. I crammed all the wires through the huge grommet behind the cruise control.
My Apex'i boost gauge is still hooked up, but I might change it to measure pressure somewhere else. I might try to measure pressure directly off of the turbo, that way I'll have pre and post intercooler pressures.
Defi's are beautiful. The quality is top notch.
aspera is offline   Reply With Quote
Old 10-24-2002, 08:40 AM   #85
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
2001 2.5 RS
Derres Catalano gauge mask
Stock gauge pod
Autometer boost, EGT, oil pressure
HKS Type-1 turbo timer
Old Alpine deck with rotary volume knob
wcbjr is offline   Reply With Quote
Old 10-24-2002, 09:00 AM   #86
ZoomnWRX
Member#: 11605
2002 01G WRX stg2
2007 Acura TSX
lotek pillar, autometer boost, a/f and egt, autometer shiflight on column... can't see the V1 hardwired just about my rear view though... i need to get a pic of that
ZoomnWRX is offline   Reply With Quote
Old 10-25-2002, 01:18 PM   #87
vapore0n
Member#: 21356
2010 BMW 335i
for the autometer guys, What color are the Z series gauges at night time.
Im looking for gauges that blen in with the stock looks. So it would be a black face , white letters and green lighting.
Any other sudgestions on brands? Dont want to spend 150$ on a single gauge too. Planning on doing an autometer full pillar with 2 gauges, boost and .... maybe trany temp, maybe fuel/air ratio
vapore0n is offline   Reply With Quote
Old 10-25-2002, 01:56 PM   #88
TonyWRX
Member#: 21146
greddy and omori gauges match up well with the stock colors. I think the only difference in the Greddy ones besides the numbers is also the color of the needles.
Old 10-27-2002, 03:33 PM   #89
wrixer
Member#: 22982
2002 WRX Sport Wagon
2000 Suzuki Hayabusa
Talking
I finally put my boost gauge on! Pics, soon!
wrixer is offline   Reply With Quote
Old 10-27-2002, 05:09 PM   #90
18psiWRX
Member#: 22858
Originally posted by SonicWRX
Nice!!!
18psiWRX is offline   Reply With Quote
Old 10-27-2002, 05:26 PM   #91
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
Default Re: I played with too many LEGOs when I was a kid
that's so cool...it would be nice if u could post some pics..
KIMUTAKU is offline   Reply With Quote
Old 10-27-2002, 08:49 PM   #92
Sordid Philosopher
Member#: 16854
2003 WRX Sedan
I REALLY want a pillar pod for a wagon...Does anyone know of a pillar pod for the WRX Wagon?
Sordid Philosopher is offline   Reply With Quote
Old 10-28-2002, 12:46 AM   #93
axis
Member#: 13382
06 STi
WRB/Gold
I put my control unit in my center console. That way it's out of the way and it's hidden.
Dan
Old 10-28-2002, 01:35 AM   #94
aspera
Member#: 7879
Dan
Do you mean it's inside the armrest storage box?
Old 10-28-2002, 09:22 AM   #95
wrixer
Member#: 22982
I don't think it exists. I just went with a single pod in the left corner of the dash next to the A-pillar. If you find one...let me know!
Old 10-28-2002, 02:15 PM   #96
WRXerist
Member#: 20235
2006 FX45
These pics are all helpful. Give me some ideas to where I want to install my aftermarket gauges.
WRXerist is offline   Reply With Quote
Old 10-28-2002, 08:13 PM   #97
axis
Member#: 13382
06 STi
WRB/Gold
Yup! Ca't see any wires and it's out of the way yet easy to get to.
Dan
Old 10-28-2002, 08:15 PM   #98
axis
Member#: 13382
06 STi
WRB/Gold
Yup! Can't see any wires and it's out of the way yet easy to get to.
Dan
Old 10-29-2002, 12:30 AM   #99
aspera
Member#: 7879
Dan
That's a great place for it, but I still like having it in the glovebox, my preference. How hard is it to press the buttons with it back there?
Old 10-29-2002, 01:05 AM   #100
ThaTaint
Guest
Member#:
what about a hat with guages...... like one of those plastic beer caps.. cept with guages not beer... i was gonna photoshop it.. but naaa to lazy.. maybe some day.. and yes i know i post on this thread and dont put my guage pic up here.. i dont put it cuz its to intimidating up in here
Post Pics Of Your Navigation Setup ( Eclipse , N1 ,N2 .... ) minx1225 Interior & Exterior Modification 1 09-06-2005 01:43 AM
Post pics of your FMIC setup KitchenerWRX Member's Car Gallery 2 08-30-2005 01:27 PM
Post pics of your gauges lit up... MomoWRX Electrical & Lighting 22 12-11-2004 10:21 PM
post pics of your gauge clusters/bezels 03wrx 03twrx South East Region Forum 5 11-13-2004 09:28 PM
Post Pics of your gauges and cluster shots! Leo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 02-19-2004 10:16 AM
