Old 02-09-2006, 12:47 AM   #1276
Scott Farmer
Member#: 87799
2005 STU STi
White/Gold For Sale!
Default MadDad Clarity STi Look Gauges
Hey guys, I thought I'd post up a couple of pictures of the gauges installed. I had them installed by 2phless (board member from NC) and according to him, the installation was smooth and problem free. As you can see, the gauges look great! I'm quite happy.
Scott Farmer is offline   Reply With Quote
Old 02-09-2006, 02:19 AM   #1277
runwrxrun
Member#: 51488
Originally Posted by UpTown I-TS
How much do those 02+ OEM center guage housing (metal bracket included) cost anyways?.
They are about 70 I think. I have a brand new oem 02+ with bracket for 50 if you're interested.
runwrxrun is offline   Reply With Quote
Old 02-09-2006, 02:33 AM   #1278
ryanpietro
Member#: 101803
2005 gt35r sti
blue
those mad dads are damn nice for around 3bills. to bad i got defi's with a carbon pod ill post pics soon even tho theres one like 4 posts back.
ryanpietro is offline   Reply With Quote
Old 02-11-2006, 04:21 PM   #1279
mindchatter
Member#: 36447
Heav en for the weat
her & Hell for company
Defi triple pod w/EGT, boost, and oil temp....
Water temp mounted in vent and oil press. in Defi cup w/visor....
Not the best shot, but here's where I have the SMC LED's wired into the cluster....you can see the green (armed) and yellow (spraying) LED's lit as I hit the test button while shooting. The larger red LED to the right signals low alc/water mix.
mindchatter is offline   Reply With Quote
Old 02-12-2006, 01:16 PM   #1280
turboscooby13
Member#: 56280
2003 M3
I already have a boost gauge in a single-pod on the pillar, but was thinking about adding an oil pressure and oil temp gauge in the locations shown. Has anybody seen this or tried it?
turboscooby13 is offline   Reply With Quote
Old 02-12-2006, 01:22 PM   #1281
WR^2X
Member#: 37617
I've seen it, but haven't tried it. If I put in more gauges, they'll be in cups above the clock pod.
WR^2X is offline   Reply With Quote
Old 02-12-2006, 01:26 PM   #1282
turboscooby13
Member#: 56280
2003 M3
I thought about that, but decided that it's not really where I want to put them. I haven't seen many with the gauges right on the dash there and thought it would look pretty nice, plus they are right there in front of me.
Old 02-12-2006, 09:08 PM   #1283
scottjua
Member#: 2937
2002 WRX Wagon WRB
2006 STi Aspen White
How closely does the color match to the STi guage cluster?
scottjua is offline   Reply With Quote
Old 02-12-2006, 10:00 PM   #1284
mjd85la
Member#: 35176
1998 2.5 RS Impreza
2000 gray OBX
bump
I was wondering the same thing, Comparing these to daddy's
mjd85la is offline   Reply With Quote
Old 02-12-2006, 10:14 PM   #1285
Silverbullet555
Member#: 106913
2005 Forester XT
Maroon
Anybody know if the autometer bezel will fit an 05 FXT?
edited to add: Nevermind. Found the answer.
Silverbullet555 is offline   Reply With Quote
Old 02-13-2006, 07:18 AM   #1286
gleinz
Member#: 17541
2007 STi Ltd #320
Originally Posted by mjd85la
bump
? Those are MadDad Clarity gauges...
gleinz is offline   Reply With Quote
Old 02-13-2006, 01:02 PM   #1287
mjd85la
Member#: 35176
1998 2.5 RS Impreza
2000 gray OBX
opps, ment to say defi.
Old 02-13-2006, 03:01 PM   #1288
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Boost controller
Map based Boost gauge-very accurate especially at high altitude.
EGT
RPM
Knock
AFR's
TPS
Injector pulse-optional
All the gauges above have logging
Keep the clock
Out of site when not using
Matches the stock STI aluminum gear surround.
Wombat North is offline   Reply With Quote
Old 02-13-2006, 03:04 PM   #1289
kevlarcupid
Member#: 104306
02 Audi A4
Dolphin Grey
Wombat, that's awesome. Nicely done.
Anyone with an '06 put a pod where the clock is? If so, how difficult was re-wiring or hiding the passenger side airbag light and electronics?
kevlarcupid is offline   Reply With Quote
Old 02-13-2006, 03:29 PM   #1290
LastResort
Member#: 99289
Wombat,
any chance you can post a pick of GB open and from the view of the driver?
LastResort is offline   Reply With Quote
Old 02-13-2006, 05:56 PM   #1291
chimchimm5
Member#: 88501
2006 WRX Wagon
CGM
I'm looking for the farthest from riceyness as possible as not to have disapproval from the wife... it looks like the gauge bezel is the "cleanest" option. No Apillar, triple, or vent pods for me.
chimchimm5 is offline   Reply With Quote
Old 02-13-2006, 06:05 PM   #1292
mikecoscia
Member#: 105846
2006 Impreza WRX STi
WRB w/gold rims
the 06 has the airbag light next to the clock? Anyone have pictures of this? Picking up an 06 STi next month and plan on putting in a triple gauge pod were the clock is.
mikecoscia is offline   Reply With Quote
Old 02-13-2006, 08:21 PM   #1293
subieworx
Member#: 47769
Turned off:
How closely does the silver of the din panel match the silver of the bezel?
subieworx is offline   Reply With Quote
Old 02-13-2006, 08:50 PM   #1294
mattpreet1
Member#: 73230
'03 Silver Bugeye
B*atch!
That DTEC setup is money! Super clean and no rice ... great work!
mattpreet1 is offline   Reply With Quote
Old 02-13-2006, 08:51 PM   #1295
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Originally Posted by Wombat North
Boost controller
EGT
RPM
Knock
AFR's
TPS
Keep the clock
That's great! Nicely done!
Old 02-13-2006, 08:53 PM   #1296
Wombat North
Member#: 21267
STI, EWG 8cm Green
I couldn't agree more. I tune my car with a full load of gauges then trackday my car with only EGT, Knocklite and oil/water temps. I then for daily shut the gameboy and use only knock detection and water /oil temps because of bad fuel and warmup. The rest are pretty much useless once the car is tuned IMHO but to each his own. I just prefer to drive.
Originally Posted by LastResort
Wombat,
Old 02-13-2006, 09:05 PM   #1297
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
you have to have utec to use that right? or can that be done with ecutek?
szeny is offline   Reply With Quote
Old 02-13-2006, 10:50 PM   #1298
LastResort
Member#: 99289
Wombat N.
Thanks that's great, and itt gives me some more options for how to spend my money(like I need more options). I've got a couple now, I am going to get the Autometer Bezel with boost and something (AFR? EGT?) Then either a PSI3, disassemble it and mount the display like this guy did with his TurboTimer or what you did, which may be cost effective.
Old 02-14-2006, 05:42 PM   #1299
j00ngyang
Member#: 87001
05 Impreza WRX
This thread is great! Let's keep postin those nice night time pictures!
j00ngyang is offline   Reply With Quote
Old 02-14-2006, 09:24 PM   #1300
kevlarcupid
Member#: 104306
02 Audi A4
Dolphin Grey
Here's a quick one I just took.
The yellow light on the right next to the clock is the Passenger Airbag Indicator.
Post Pics Of Your Navigation Setup ( Eclipse , N1 ,N2 .... ) minx1225 Interior & Exterior Modification 1 09-06-2005 01:43 AM
Post pics of your FMIC setup KitchenerWRX Member's Car Gallery 2 08-30-2005 01:27 PM
Post pics of your gauges lit up... MomoWRX Electrical & Lighting 22 12-11-2004 10:21 PM
post pics of your gauge clusters/bezels 03wrx 03twrx South East Region Forum 5 11-13-2004 09:28 PM
Post Pics of your gauges and cluster shots! Leo Factory 2.5L Turbo Powertrain 21 02-19-2004 10:16 AM
Message Board Statistics All times are GMT -4. The time now is 04:53 AM.
