Old 11-06-2002, 06:43 PM   #126
M///Scooby
Member#: 28117
2012 WRX
what gauges dose Vision have? what kind of pillar is that and where can one find it and the gauges? Thanx!
M///Scooby is offline   Reply With Quote
Old 11-08-2002, 07:03 AM   #127
vapore0n
Member#: 21356
2017 Toyota Corolla
Limited, LBP, ABP, TTD, I
oooohhh, I like the summit clock, just what ive been looking for. Now I can buy the whole set of gauges and mounts
vapore0n is online now   Reply With Quote
Old 11-08-2002, 07:48 AM   #128
vapore0n
Member#: 21356
2017 Toyota Corolla
ok guys, i need recomendation. Which brand sells 52mm boost gauge that reads in psi, black faced and is backlit with green (to match the wrx gauge lights). I was looking into the greddy but havent seen it in psi, only kPa. Also, this brand needs to sell tranny temp gague. Or can I use a regular temp gauge for that. I may use an EGT instead, maybe. Oh, and not need a gauge controller for those gagues.
Old 11-08-2002, 11:46 AM   #129
Rocket Wagon
Member#: 9643
'02 WRX Wagon
WR Blue
-Vapor, VDO sells boost gauge with interchangable lights
Here is the ULTIMATE clock replacement
http://www.dakotadigital.com/Detail....er=ODYR-16-1-C
Rocket Wagon is offline   Reply With Quote
Old 11-08-2002, 12:56 PM   #130
gldenchld
Member#: 19994
Very nice gauges from vdo , only if they had air/fuel
gldenchld is offline   Reply With Quote
Old 11-08-2002, 02:11 PM   #131
vapore0n
Member#: 21356
2017 Toyota Corolla
Any on you guys bought an empty dash gauge hausing? Im seeing the one in www.subaruwrxparts.com, they told me I need the faceplate. Where can I get either the faceplate for that pod or the whole set, empty gauge dash pod and faceplate?
Old 11-08-2002, 02:48 PM   #132
Rocket Wagon
Member#: 9643
'02 WRX Wagon
WR Blue
You can't get the faceplate, just the housing. You can just buy a piece of plastic, plexiglass, carbon fiber, etc. and substitute it.
Old 11-08-2002, 03:33 PM   #133
TonyWRX
Member#: 21146
vapore0n~
Derres Catalano makes a mask to fit gauges in there. PM him
TonyWRX is offline   Reply With Quote
Old 11-13-2002, 12:09 PM   #134
M///Scooby
Member#: 28117
2012 WRX
Question
So can anyone tell me what kinda guages Vision has? Thanx alot!
Old 11-13-2002, 06:30 PM   #135
WRXerist
Member#: 20235
2006 FX45
These are all cool. Gives me a lot of ideas where to put my gauges when I get them...
WRXerist is offline   Reply With Quote
Old 11-13-2002, 06:32 PM   #136
vapore0n
Member#: 21356
2017 Toyota Corolla
yep, i finally decided to use a oem pod, since i found the digital clock i wanted, but have to wait till al the peices get here, after i dish out the money, 500+, at least it will look good
Old 11-14-2002, 10:00 AM   #137
Sordid Philosopher
Member#: 16854
2003 WRX Sedan
Which clock did you use?
Sordid Philosopher is offline   Reply With Quote
Old 11-14-2002, 03:12 PM   #138
aspera
Member#: 7879
Default Omori water temp install kit
Water temp. hose joint
(green)@P-171 30 m/m(1-3/16) JPY 3,200 AE86. Civic(Sir) etc.
(orange) P-172 34 m/m(1-5/16inch) JPY 3,200 Supura. S14 etc.
(brue) P-173 36 m/m(1-3/8inch) JPY 3,200 R32. Rancer-ebo I-III etc.
(red) P-174 26 m/m(1 inch) JPY 3,200 Civic(except Sir) etc.
(yellow) P-175 38 m/m(1-1/2inch) JPY 3,200 RX7. Impressa etc.
(black)@P-176 40 m/m(1-9/16inch) JPY 3,200 Z31 etc.
(water)@P-177 28 m/m(1-1/16inch) JPY 3,200 March K-11.Prerude AB etc.
(grey)@ P-178 32 m/m(1-5/16inch) JPY 3,200 Prerude BA-1 etc.
aspera is offline   Reply With Quote
Old 11-14-2002, 03:14 PM   #139
aspera
Member#: 7879
Default P-175 is the one
Water Temperature Install Kits
Part Number
Size MSRP
P-171
30mm (1 3/16" diameter) $37.50
P-172 34mm (1 11/32" diameter) $37.50
P-173 36mm (1 13/32" diameter) $37.50
P-174 26mm (1 1/32" diameter) $37.50
P-175 38mm (1 1/2" diameter) $37.50
P-176 40mm (1 9/16" diameter) $37.50
P-177 28mm (1 3/32" diameter) $37.50
P-178 32mm (1 1/4" diameter) $37.50
All kits include hose fitting to accept water temperature sender, and stainless steel clamps.
Old 11-14-2002, 03:18 PM   #140
aspera
Member#: 7879
Default Greddy 38mm for $28
Old 11-14-2002, 03:19 PM   #141
aspera
Member#: 7879
Default $25 at Alamo
url]http://www.alamomotorsports.com/grd_gauge_extras.html[/url]
EDIT: I just ordered from here. The website is kind of scary. EVERYTHING SEEMS TO BE IN CAPITAL LETTERS!!!! They must get ripped-off and scammed a lot. Anyway, the last question on the checkout page is "When was your last Elvis sighting?".
Well, when was your last Elvis sighting?
Old 11-15-2002, 12:32 AM   #142
B-Kerr
Member#: 14841
2002 Impreza WRX
WRB, VF22, Cusco, Unichip
Talking Aspera...
Nobody expects the Spanish Inquisition... or a trunk monkey!
BTW, have you seen the sticker you can get at Hot Topic that says, "Ask me about my monkey"?
Just FYI
B-Kerr
B-Kerr is offline   Reply With Quote
Old 11-15-2002, 01:28 AM   #143
whiterabbit
Member#: 16755
whiterabbit is offline   Reply With Quote
Old 11-15-2002, 01:31 AM   #144
idealrides
Member#: 10314
03 WRX 325hp SOLD!
06 Jeep SRT8 - 450hp
I installed this Omori 45mm last week. Getting the vent out wasn't too hard, basically just ripped the sucker out, did my dremel work, ran the wires behind the IC, and popped it back in.
idealrides is offline   Reply With Quote
Old 11-15-2002, 03:59 AM   #145
DanMan
Member#: 5009
Dan
DanMan is offline   Reply With Quote
Old 11-15-2002, 08:07 AM   #146
joostin420
Member#: 1046
2016 WRX Limited
crystal white pearl
you can make a faceplate, i spent a lot of time on the gauge setup in my MY00 RS coupe when i did it. came out excellent and i had a plexiglass faceplate i made.
joostin420 is offline   Reply With Quote
Old 11-15-2002, 09:35 AM   #147
silverbetty
Member#: 23851
2013 Legacy
Gray
Default pm-ed you
Hey joostin420-
I pm-ed you.
Thanks.
silverbetty is offline   Reply With Quote
Old 11-15-2002, 01:18 PM   #148
joostin420
Member#: 1046
2016 WRX Limited
crystal white pearl
Thumbs up
the instrument panel came with white faced gauges on MY00 and MY01 RS's. the gauges are Autometer 2-1/16" Phantom gauges.
all the lighting including HVAC is an aquamarine (kinda indiglowish). when i first started on the i-club about 3 years ago someone put together a little kit to change the lighting color of the instrument panel (Bankheist -- i dont know if he is still around). for the gauges and HVAC i just used Blue Autometer bulb caps and it matched perfectly.
justin
Old 11-18-2002, 08:52 AM   #149
silverbetty
Member#: 23851
2013 Legacy
Gray
Default THanks
justin
Justin-
Thanks for the info.
Tom
Old 11-18-2002, 10:08 AM   #150
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
My temporary dash solution...
And my standard issue dual a-pillar pod...
And can't forget the make-shift AFC location (with trash and dust everywhere)...
-Brad
ChicksDigWagons is offline   Reply With Quote
Post Pics Of Your Navigation Setup ( Eclipse , N1 ,N2 .... ) minx1225 Interior & Exterior Modification 1 09-06-2005 01:43 AM
Post pics of your FMIC setup KitchenerWRX Member's Car Gallery 2 08-30-2005 01:27 PM
Post pics of your gauges lit up... MomoWRX Electrical & Lighting 22 12-11-2004 10:21 PM
post pics of your gauge clusters/bezels 03wrx 03twrx South East Region Forum 5 11-13-2004 09:28 PM
Post Pics of your gauges and cluster shots! Leo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 02-19-2004 10:16 AM
