Old 01-20-2003, 03:13 PM   #201
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
Here's a question and just a "hey - have you thought about this" tip -
1. Where did you get your Omori gauges? I am DESPERATELY trying to get a 45mm boost gauge with the yellow needle, as i have 3 of the other gauges that are the same, and my vendor was unable to obtain one before Omori-NA went "belly up" or whatever happened to em.
2. Have you considered mounting the DIN panel on the OUTSIDE of the housing? That's the way I have mine mounted and I kinda like it like that. I basically used the ideas and directions from a few people on the site, but you basically screw in the chassis so it's "tight' but not "impossible to move"
Then you pull out the chassis so it is sticking out slightly (since it doesn't fit!) and attach the faceplate. Make it relatively snug. Then you can slide the whole thing in place, and tighten the allen screws on the outside - I think it looks alright, and while I was hoping to post pics with my matching Omori boost gauge, I guess that's going to have to wait.
CirrusWRX is offline   Reply With Quote
Old 01-20-2003, 03:31 PM   #202
mhbrown
Member#: 12537
'02 WRX Sportwagon
WR Blue Pearl
Cirrus, check your pm!
mhbrown is offline   Reply With Quote
Old 01-20-2003, 04:07 PM   #203
Dakken
Member#: 24570
wrx [email protected] 1/4
1.72 best 60ft
Dakken is offline   Reply With Quote
Old 01-20-2003, 04:49 PM   #204
STI4ME
Member#: 6034
It's Soo-BAH-roo
Default Re: My install (long, no pics)
Originally posted by mhbrown
For an Omori boost, you need a different T for the vacuum hose. You want Omori part P-94. For an oil temp, you need a diferent oil drain plug, P-74.
I just installed my Omori 60 mm boost gauge and I didn't need to use a different T as suggested by Omori NA. I used the T fitting between the fuel pressure regulator and intake manifold. The vacuum hose that came with the gauge goes on the nipple fitting on the manifold perfectly.
STI4ME is offline   Reply With Quote
Old 01-20-2003, 08:34 PM   #205
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
mhbrown - thanks so much - check YOUR pm!!!
Old 01-20-2003, 08:34 PM   #206
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
double post - i have suck
Old 01-27-2003, 07:25 PM   #207
Schaf100
Member#: 19647
2002 WRX Sedan
12.697 @ 108.95
My dremmeled stock pod with Plexiglass faceplate and 52mm Autometer Sport Comps. Looks good enough for now. Someday I'll get a Defi set up when I have $$$$.....
Better Pic Here:
http://www.clubwrx.net/forums/showth...0&pagenumber=4
Schaf100 is offline   Reply With Quote
Old 01-27-2003, 09:19 PM   #208
jackansi
Member#: 23894
'07 3.2L Audi A4
When you goto your dealerships for service what do they say about your guages?
jackansi is offline   Reply With Quote
Old 01-27-2003, 09:32 PM   #209
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
here are mine...defi link boost, egt and fuel pressure...waiting for pillar pod to mount oil pressure and temp and water temp gauges...
SQUAD_907 is offline   Reply With Quote
Old 02-03-2003, 11:51 AM   #210
vapore0n
Member#: 21356
2010 BMW 335i
2017 STI Limited LBP
This weekend ill post my gauge setup, a-pod at least, since im still waiting for 2 gauges.
vapore0n is offline   Reply With Quote
Old 02-03-2003, 11:51 AM   #211
vapore0n
Member#: 21356
2010 BMW 335i
Old 02-07-2003, 09:19 PM   #212
fastfood
Member#: 7202
2002 Impreza WRX
TrackWhore #09
Default It still needs some cleaning up...
The unit in the center is an MRT EBC and I haven't had the EGT probe installed yet. It'll look much nicer at the end of the weekend.
fastfood is offline   Reply With Quote
Old 02-08-2003, 10:16 AM   #213
vapore0n
Member#: 21356
2010 BMW 335i
same situation as me, have to find some profesional to install the egt probe and maybe install a O2 sensor in the uppipe. My gauges arrive on wednesday!! Ill hold the pics till I clean my car and install those gauges. We had a snowstorm, fun to drive
Old 02-08-2003, 11:14 PM   #214
JayGold
Member#: 7074
and since then have added this:
JayGold is offline   Reply With Quote
Old 02-09-2003, 12:41 AM   #215
Rosco ReX Rox
Member#: 31294
2002 Impreza WRX
Thumbs up Gauges
Please describe for me what the three gauges are in the pod where the clock goes and what the ones on the pillar pod are. Also, it looks like you have a TT in place of the ashtray? Is that what I'm looking at? If that's the case, could you tell how you installed it and if you had to do a lot of fabrication?
I would think that being as the ECU is so close to the ashtray, it was easier to install the TT where the astray goes? Very interesting.
Great pics. Nice job, very clean and pro looking.
Rosco ReX Rox is offline   Reply With Quote
Old 02-09-2003, 06:02 AM   #216
JayGold
Member#: 7074
Default Re: Gauges
Dash pod has a Water Temp. Oil Temp and Oil Pressure.
Pillar Pod has Boost on top and EGT below.
TT was much easier to install in ash tray, wiring is all run behind the dash to the unit. The only thing I can point out about the install was I used velcro on the top of the TT to mount it, this makes for easy removal if necessary.
Thanks for the compliments.
Jay
Old 02-09-2003, 12:22 PM   #217
Derres Catalano
Member#: 3244
2000 2.5 RS
Silverthorn
Default DC Customs Gauge Mask kit
Derres Catalano is offline   Reply With Quote
Old 02-09-2003, 07:41 PM   #218
vapore0n
Member#: 21356
2010 BMW 335i
here are some pics
Old 02-09-2003, 08:22 PM   #219
wieger54
Member#: 5137
Talking
Looks like there's a defect with your car. They should cover it though since they are the ones that put your steering wheel upside down.
mike...
wieger54 is offline   Reply With Quote
Old 02-09-2003, 08:36 PM   #220
SilverJA
Member#: 11544
93 Legacy L
01 RS; 02 WRX; 08 STi
Question
Does anyone have a steering column mounted gauge, other than the stock boost gauge?
Thanks
SilverJA is offline   Reply With Quote
Old 02-09-2003, 08:47 PM   #221
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Here's my 52mm Omori set up in the stock gauge housing (slightly fabricated so the gauges would sit flush against the aluminum face plate I made). I'm not sure if I like the look of the plate and may end up changing it (making a new one without the hex bolts or....):
Kean is offline   Reply With Quote
Old 02-10-2003, 01:15 AM   #222
aspera
Member#: 7879
Default some more reasons why Defis rock...
Have any of you Defi users figured out the "pressure differential" function? I didn't know that I had this function until just the other day. Its a pretty cool function.
Here's what it does: If you have a boost gauge and fuel pressure gauge you can press the "up" and "down" arrows at the same time and the fuel gauge will then start showing the difference in pressure instead of the actual fuel pressure. Its kind of like a poor mans air/fuel gauge.
I also found out how to adjust the brightness. I can have the gauges on full bright at night if I want to. Both of these functions stay set even when you turn off the car.
aspera is offline   Reply With Quote
Old 02-10-2003, 07:59 AM   #223
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
Default Re: some more reasons why Defis rock...
how? and which defi gauge set do u have?
Old 02-10-2003, 10:18 AM   #224
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
Differential Pressure Mode Operation
i have defi bf boost, bf fuel pressure should be in soon .. differential pressure mode seems interesting.
ronaldwrx is offline   Reply With Quote
Old 02-11-2003, 11:33 PM   #225
aspera
Member#: 7879
Default Re: Re: some more reasons why Defis rock...
BF's with the version 2 contoller
With the controller set to differential pressure mode, you can see the (relative) pressure drop when you blip the throttle and the (relative) pressure rise when you let off the throttle. Most of the time the needle stays in the same place, just above the 3, or about 320kPa (I think).
The brightness is adjusted using the up and down arrow buttons.
Post Pics Of Your Navigation Setup ( Eclipse , N1 ,N2 .... ) minx1225 Interior & Exterior Modification 1 09-06-2005 01:43 AM
Post pics of your FMIC setup KitchenerWRX Member's Car Gallery 2 08-30-2005 01:27 PM
Post pics of your gauges lit up... MomoWRX Electrical & Lighting 22 12-11-2004 10:21 PM
post pics of your gauge clusters/bezels 03wrx 03twrx South East Region Forum 5 11-13-2004 09:28 PM
Post Pics of your gauges and cluster shots! Leo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 02-19-2004 10:16 AM
