Old 09-25-2013, 11:29 PM   #1
Whoa!ShutItDown
Member#: 191700
04 WRX
Default WOT feels weak...let off gas...WOT feels good
I had some bogging/hesitation issues, tightened up and replaced a few hoses and lines today which seemed to fix that issue. But when I go WOT it builds boost choppy and gets anywhere from 10-15psi, sometimes full boost at 19psi. If I go WOT and it doesnt feel strong I can make it feel right by quickly letting off the gas completely and immediately punch it. But that still doesnt make it hit full boost. Nothing sounds different, I think it might be pulling boost/timing for some reason. I have an Openport 2.0 and can datalog, but not too sure what to look for.
Could that be the TPS going? I cleaned my IACV recently but dont recall if it did that previously. Possibly MAF or knock sensor? I dont think its a vacuum/boost leak, I spent hours today making sure every hose was seated good. I changed 2 lines to my EBCS (ran out of line, couldnt do all 3) but the line was slightly smaller, my local stores either dont carry it or have bad selections so its tough to find the same line from 3 years ago, Ill be looking around again tomorrow
04 WRX at 127k
Blouch 16g-XT turbo
ebay TMIC
Deatschwerks 750cc injectors
Walbro 255lph fuel pump
Tomei 4-1 UEL header w/ catless uppipe
3in catless turbo back exhaust
Cobb Short ram intake
Samco MAF tube
Gimmick turbo inlet
TGV deletes
Grimmspeed EBCS
Perrin light crank pully
Whoa!ShutItDown is offline   Reply With Quote
Old 09-26-2013, 12:31 AM   #2
scurran88
Member#: 365484
2002 wrx
rally blue
Yeah my 02 wrx does something similar. I can't get on it at all or else it stutters. This is very annoying and I have yet to figure it out.
scurran88 is offline   Reply With Quote
Old 09-26-2013, 12:43 AM   #3
pmugabi
Member#: 280926
Misfire I would think. What plugs do you have and when did you last change them?
pmugabi is offline   Reply With Quote
Old 09-26-2013, 01:25 AM   #4
Whoa!ShutItDown
Member#: 191700
04 WRX
Ngk bkr7e, just changed them last week, was tuned on bkr7e's. It kinda does feel like a misfire, if I give it gas at low rpm in 4th or 5th it feels like a slight rumble/vibrating. Coil packs don't die slowly do they? I've always heard they just go
Old 09-26-2013, 08:25 AM   #5
quazimoto
Member#: 70395
Datalog the car and post it up.
quazimoto is offline   Reply With Quote
Old 09-26-2013, 06:00 PM   #6
Whoa!ShutItDown
Member#: 191700
04 WRX
Ill be able to get some datalogs up tomorrow, what parameters should I log?
Old 09-27-2013, 07:56 AM   #7
quazimoto
Member#: 70395
RPM
PSI
DAM/IAM
Feedback knock correction
fine learning knock correction
throttle position
wgdc
MAF G/S
Old 09-27-2013, 09:09 AM   #8
Whoa!ShutItDown
Member#: 191700
04 WRX
Ok ill get those later today. But I did have a second last night to look at it, my IAM is steady at 8, it used to always be 16. I have a new knock sensor to replace the stock one, gonna do that later. I doubt its bad gas cuz I always go to the same stations. I just got the car back on the road, blew the stock 5mt and replaced it with a used one. I didnt inspect the flywheel or clutch, and re-used the throwout bearing, if the clutch was slightly damaged on the hard launch that busted the first tranny could it cause the IAM to be off? And the intake manifold was off in that time to replace a garbage Gimmick inlet, I deleted that black purge valve between inlet and purge solenoid too (2 lines on the solenoid, one goes to manifold and other goes directly to rail under the manifold)
Old 09-29-2013, 08:15 PM   #9
Whoa!ShutItDown
Member#: 191700
04 WRX
One of the wires on my Grimmspeed 3port was pulled out of the connector, I have no idea how that happened but it definitely was the issue.
Old 09-29-2013, 09:40 PM   #10
jhayesvw
Member#: 326502
2003 WRX Wagon
its nice when you find the problem. Good deal.
Oh and I'm originally from Central Square NY area. haha. Small world.
jhayesvw is offline   Reply With Quote
Old 09-30-2013, 10:09 AM   #11
Whoa!ShutItDown
Member#: 191700
04 WRX
It was by far the easiest fix Ive ever had. Ive checked lines and fittings dozens of times, it wasnt until I datalogged and noticed my boost error and wastegate duty cycle correspond with difference in power of WOT.
jhayesvw I bet AZ is way better then CNY, but no snow fun!
