Old 09-27-2013, 09:59 AM   #1
timmywill1
Member#: 368155
2003 WRX
Platinum Silver
Default Questions about P1447
My car (2003 WRX) is throwing a P1447 and I can't find much info online..
I did, however, find something online about the gas cap-
Is there a sensor to see if I filled the gas recently? I was thinking if I undo the cap, put it back on, and start the car it might clear it. The code came on after I had gotten gas ( I think I rememeber correctly..)
If not, anyone have any insight on what to check here? The car is under warranty, so the dealer is fixing it for me ...
If I can fix it by myself I see no reason to waste time at the dealer.
timmywill1 is offline   Reply With Quote
Old 09-27-2013, 05:01 PM   #2
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
IA Performance is offline   Reply With Quote
Old 09-30-2013, 03:54 AM   #3
dictoresno
Member#: 139816
2002 WRX, VF34 swap
Originally Posted by IA Performance View Post
EVAP codes can be quite time consuming to diagnose. Your only hope is that one of the small hoses came loose directly behind the P/S pump. Namely, the blue 'T' connector. This article will have images and a better explanation of how the EVAP system works.
http://forums.nasioc.com/forums/show....php?t=2485979
[email protected]
www.facebook.com/iaperformance
i was troubleshooting an evap code for 2 months and the blue t connector was the exact issue. the t part snapped and was creating the small evap leak.
dictoresno is offline   Reply With Quote
