Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 10-06-2002, 09:03 PM   #1
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
Question Is there supposed to be a hole through the cat material in the stock uppipe?
Just had my uppipe and downpipe installed today (w00t, it's a whole new beast now ) and noticed something strange with the stock uppipe. About 2 months ago my turbo died and was replaced under warranty, but my dealer never told me what the cause was. I suspect the uppipe broke up and killed the turbo, because when I checked out the stock uppipe today there was a hole clean through the center of the catalyst, and the EGT probe was clean broken off (no CEL though). Any ideas??
-Anthony
atf78 is offline   Reply With Quote
Old 10-06-2002, 09:24 PM   #2
hotrod
Member#: 14141
2002 Impreza WRX
Default No holes are not normal
The stock uppipe cat completely fills the uppipe. with a fine honecomb of cat material. In stock form it has no holes in it.
I have seen an uppipe cat core come loose and break a sensor before, probably due to the person running high boost and very rich so it was after burning in the pre-cat and overheating it.
Sounds like you've discoverd the cause of your blown turbo, and something about the service department at the dealership you went to.
So you have been running with no EGT probe for how long with no CEL ??
You might want to give the old down pipe a good shake and see if a probe tip falls out. When you had the down pipe off, did anyone visually check your new turbine to see if it passed that EGT probe tip at low rpm and survived?
Larry
hotrod is offline   Reply With Quote
Old 10-06-2002, 10:08 PM   #3
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
Angry
Thanks hotrod. Well, we checked the turbine and everything looked just fine so I don't think the probe passed thru it. Also, when they replaced my turbo, they replaced the downpipe (don't know why), so the probe was probably stuck in there/fell out when they removed it at the dealership. Idiot dealership, last time I ever go there for anything
It's been almost 2 months since they replaced the turbo and I still haven't gotten a CEL
-Anthony
Old 10-07-2002, 04:53 PM   #4
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
Here's some pics of the broken cat. :monkey:
-Anthony
Old 10-07-2002, 04:59 PM   #5
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
Holy Cow! Good thing your turbo is OK
Matt
mattjk is offline   Reply With Quote
Old 10-07-2002, 05:03 PM   #6
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
wholy sizt Batman...
I have an uppipe sitting wating to get gutted...
sorry to here the tech is so dumb... the CEL related to the EGT sensor is always optional, If the base of the sensor is in good shape & only the tip is gone it is a posbility it has enough restance to still read(don't ask how)... just not reading correctly
GLwagon is offline   Reply With Quote
Old 10-07-2002, 05:09 PM   #7
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Wow, poked a hole clean through the honeycomb material! I'm convinced i need an catless upipe now, it's going on my "to do" list. Scary
PaulRex is offline   Reply With Quote
Old 10-07-2002, 05:28 PM   #8
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
That is TRULY a scary sight. Cats are evil
bemani is offline   Reply With Quote
is there supposed to be play in the power steering pump pulley? japspecjohn Brakes, Steering & Suspension 7 12-02-2009 01:47 PM
what is the Test mode connector for and is it supposed to be plugged in together? CCTXRS Electrical & Lighting 2 10-24-2007 05:11 AM
Can the cat material inside the stock be removed BD72055 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-30-2002 10:44 AM
Is there supposed to be a washer w/ Drain plug? STi-Nismo Dood Newbies & FAQs 10 10-01-2001 01:43 PM
Is there supposed to be an underpan????? samurai General Forum Archive 1 05-19-2000 11:30 AM
