Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 02-23-2011, 04:07 AM   #1
midtnrider
Member#: 240411
2002 wrx hybrid 20g
psm
Default Feeler: 2002 20G Hybrid bugeye
im trying to decide if its work selling or just keeping it
I recently had Forged Performance replace the heads and block less then a year ago and had retuned.
02 platinum silver built wrx in Middle TN. usdm 2.5l sti block w td0620g. Feeling out the price.
oem clutch replaced at 79k and 140k
engine replaced at 88k in November 06. Roughly 120k miles now
oil changed 100, 500, 1000, 1500, partial boost at 1000, tune at 1500.
cobb accessport paired with street tuner license and hasp key. Tune by Scott Seigel of Seigelracing and Topseed in Atlanta fame. EST 370WHP
and again by Scott Seigel at Forged Performance in Atlanta in April 2010
Currently Installed:
  • usdm 2.5l block
  • ARP Studs
  • oem headgaskets permatex coated (installed with engine replacement)
  • mitsubishi td06 20g turbo from deadbolt (installed with engine replacement)
  • deatschwerks 660cc injectors (installed with engine replacement)
  • walbro 255lph fuel pump (installed with engine replacement)
  • Perrin TMIC (installed with engine replacement)
  • Prodrive silicone y-pipe (installed with engine replacement)
  • OEM Waterpump (installed with engine replacement)
  • STI timing belt (installed with engine replacement)
  • Samco Silicone tmic inlet host
  • tgv delete
  • Mishimoto race radiator
  • Perrin Electronic boost controller (installed with engine replacement)
  • hks turbo timer type-0
  • Exedy Light Weight flywheel
  • Optima Yellowtop (installed with engine replacement)
  • Grounding modification
  • solenoid hose replacement removing coupler
  • gp moto intake elbow
  • k&n high flow filter
  • aftermarket uppipe heatwrapped and silicone coated (not sure of brand was on car when purchased, catless)
  • helix turboback exhaust (catless)
  • factory exhaust manifold heatwrapped
  • goodridge stainless steel brake lines
  • EBC Green front pads
  • New Rear Rotors and pads
  • perrin 22mm rear swaybar
  • perrin front swaybar
  • perrin spherical bearing rear endlinks
  • megan racing coilovers
  • 1 step colder ngk iridium plugs (installed with engine replacement)
  • autometer black 3 guage a pillar pod (installed with engine replacement)
  • mad dadz clarity gauges: boost, egt and oil pressure (boost only one hooked up, oil sending unit hooked up but not ran to guage, have sensor for egt)(installed with engine replacement)
  • Oil filter sandwich adapter (installed with engine replacement)
  • sti group n engine and tranny mounts (installed with engine replacement)
  • kartboy polyurethan long ehaust hangers
  • perrin short throw adapter
  • momo titanium/leather shifter
  • 4 17X7.5, 48mm offset, 5x100 pattern Royal Black Rota Subzeros with 225/45R-17XL 94H BSW Nakang NS-1 Tires
  • Gorilla Lugz chrome lugnuts
  • PH 4300K Bi-Xenon HID Kit from www.xenonpros.com (low and high beam in factory housing with no retrofitted lens)
  • zerosports carbon fiber wing lift for factory spoiler
  • hella supertone horns
What do you guys think its worth?????
midtnrider is offline   Reply With Quote
Old 02-23-2011, 07:56 PM   #2
midtnrider
Member#: 240411
2002 wrx hybrid 20g
psm
bumpity bump
Old 10-06-2013, 04:03 PM   #3
MylittleWRX
Member#: 342004
2002 WRX Sedan
white
Start at $23000
MylittleWRX is offline   Reply With Quote
How many of you have a VF30, VF34, VF22, VF39, 18 or 20G hybrid? SixSick6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 70 01-15-2014 09:04 PM
IAG Built 2.5L Hybrid Bugeye FP 20g Turbo JDM 6-Spd Jorge Tuned STI_KLR Proven Power Bragging 52 01-10-2010 10:52 PM
Feeler: 2002 Bugeye WRB WRX rallypig_wrx VIC Private Classifieds 22 06-24-2008 05:45 PM
FS: Blouch VF39/20G hybrid kinger Engine/Power/Exhaust 27 05-29-2007 06:40 PM
What do 2.0L guys think of VF turbos 30, 34, 39, 22 or VF/16G, 18G, or 20G hybrids? SixSick6 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 03-12-2007 03:49 PM
