Old 09-28-2013, 09:28 AM   #1
bluecrush832002
Member#: 369146
Default cooling problems and questions.
First off I like to introduce my self my names Danny. I am new to the subbie world and have done my first build and now having cooling issuses. Hear is what I drive and whats done.
03 wrx
2.0 with forged internals as whole block is done but sleaved.
Damn near stock heads.
Aem fuel pump and fpr
E85
2000cc injects
Stain braid fuel lines bye aeromotive.
Just put new radiator and fans from misho.
Also did stand alone thermal switch and fan over ride.
Greddy oil water seprator
Brand new coolant hoses.
Gt35r rotated kit on 30pld
On aem ems tune.
The problem.
Ive been threw alot blowen heads before I went with building the block, so I know the signs and car is not showing any. Vacum test and leak downs are good.
Water temp I cant seam keep it under 200 and some times gets to the 3rd line.
The temp is fine when running(185-195) but will start heat up when on it and then it will stay at 195-206.
Now my question is what coolant is best to run and is their anything to add to it to keep it cool and should I invest in the radiator shrouds?
Next question is by me buying a stand alone oil cooler will that help cooling?
Do I need re pull my motor and re torque the heads down?
Should I spend extra and get the cobb thermostat?
Motor now has 3600 on it. And please keep in mind I keep my fans on when I know I am going run. But other than that I let the switch do its job. I just want know how I can get my temp back to normal after I do a few runs. I also do let the car cool down before I drive it again. One thing I did notice is my top coolant tank seams to be empty when I check it.
I am open to any and all help and suggestions.
bluecrush832002 is offline   Reply With Quote
Old 09-28-2013, 10:09 AM   #2
rdieder
Member#: 257818
2007 STi
CGM
Looks good , wheres the problem?
rdieder is offline   Reply With Quote
Old 09-28-2013, 11:04 AM   #3
bluecrush832002
Member#: 369146
The cooling will stay at the 200 range the rest day most time..
Old 09-28-2013, 05:36 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
how old is water pump?
Old 09-28-2013, 07:20 PM   #5
Andrewxxcarlson
Member#: 316415
2006 WRX
Our cars can be a bitch to burp the coolant system. I'd make sure you have no air in the system. Back feed it through the block, pull off the line off the top resevoir that runs towards the turbo and fill coolant in there til full. Reconnect and burp the top resevoir as normal. My phone and I are retarded. We can't spell resevoir apparently hahah
Andrewxxcarlson is offline   Reply With Quote
Old 09-29-2013, 10:21 AM   #6
bluecrush832002
Member#: 369146
Water pump is new I did that with new belts and same with oil pump is new. .
And I will try that when I get a chance Thanks. .
Also what coolant is every one running
Old 09-29-2013, 11:31 AM   #7
rdieder
Member#: 257818
2007 STi
CGM
whats normal operating temp supposed to be?, ive read several threads it seems to be as high as 210 is normal
Old 09-29-2013, 11:48 AM   #8
2011WRXMT
Member#: 270426
2011 WRX Premium
Satin Pearl White
As far as coolant in my 11 its the Subaru super blue stuff and in my 02 just normal green both cars are mixed at a 50/50 ratio and are good to go in the winters here.
2011WRXMT is offline   Reply With Quote
Old 09-29-2013, 10:38 PM   #9
bluecrush832002
Member#: 369146
Normall for me is 185 under normal abd if I run and then normal d4ive about 195.
210 and thats 3rd line for me
Old 09-29-2013, 10:38 PM   #10
bluecrush832002
Member#: 369146
Thanks
Old 10-01-2013, 04:47 PM   #11
dakyn
Member#: 299512
2003 WRX
I had some overheating issues in my 03 wrx recently. It would overheat and then cool down soon after. Ended up replacing the thermometer and that fixed it.
dakyn is offline   Reply With Quote
