Old 09-29-2013, 03:47 PM   #1
JawzSti
Member#: 350219
Default Need to log again after updating from old map version to new?
I have been using the LWG map which works great, and i noticed there was an updated LWG map on the Cobb website, so i wanted to know if it is necessary to log and review if i am only updating to the new version of the map, no other modifications were made. Any help would be appreciated. Thanks.
JawzSti is offline   Reply With Quote
Old 09-29-2013, 05:42 PM   #2
Frank_Zuccarini
Member#: 88939
2011 WRX STi Hatch
World Rally Blue
It would be prudent to log, at least a couple of times, to make sure that the new tune does not bring you into dangerous (higher boost) territory. The boosting parameters are one of the main areas of change in new maps. Of course, since I do not know what you drive, I am making some assumptions here. Still, new tune = more logging.
Frank
Frank_Zuccarini is offline   Reply With Quote
Old 09-30-2013, 09:59 AM   #3
Cobb Tuning
Member#: 4803
If you can post up the old version # you are running and the new version # you want to run (and your car/year), we can tell you if there are any significant differences. In some cases, there are changes in the past just to add new features (such as launch control/flat-foot shift) and not necessarily tuning changes, so it just depends on the old vs. new version.
Bill
Old 10-04-2013, 08:38 PM   #4
JawzSti
Member#: 350219
Thanks guys. I have a 2011 Sti hatchback, i am running the stage1 + sf 93 v330 boost select lwg map, i had upgraded from the stage1 + sf 93 v300 map, with no other changes to the car, just wanted to be current and get rid of the 2nd gear stumble. Any info would be appreciated. Thanks.
Old 10-05-2013, 07:29 AM   #5
JawzSti
Member#: 350219
Just to be clear, i am using the lwg map of the v330 now, i didnt want you to think i had changed from a lwg to a notmal map. Thanks.
Old 10-08-2013, 09:15 PM   #6
JawzSti
Member#: 350219
Bill, any thoughts?
