#1 |
Member#: 7958
Vehicle:09 GH B+ |
I purchased an Omori 52mm boost gauge w/ one of their pods. Had to hack up the pod but got the results I wanted. Black face, yellow needle, green backlit and in psi, all mounted on the steering column.
Install details here: http://www.clubwrx.net/forums/showth...6960#post96960 Big Sky |
#2 |
Member#: 24818
Vehicle:2002 WRX World Rally Blue |
Looks good ... nice selection!
-Chris |
#3 |
Member#: 17439
Vehicle:2002 x2 Silver WRX Sedan, White WRX Wagon |
Looks terrific! Where'd you get the gauge from? (esp. with the yellow needle?)
#4 |
Member#: 7958
Vehicle:09 GH B+ |
I got it here:
http://www.kastleskorner.com/store/ He's the same guy that helped setup scoobymods.com. Excellent service, everything in stock, tracking #'s and followup emails. |
#5 |
Member#: 4374
Vehicle:06 Titan,99,94 SM 06 nasa spec miata champ |
very very nice.
although, is it ever a problem (or just annoying) that you cant see your tach under 2k? |
#6 | |
Member#: 7958
Vehicle:09 GH B+ |
#7 |
Member#: 24140
Vehicle:02 Impreza WRX http://www.logmapper.com |
How close of a match is the needle in color to the stock needles? The stock ones aren't quite yellow, but have an orange tint to them; I was wondering if the Omori needles matched this.
jason |
#8 |
Member#: 7958
Vehicle:09 GH B+ |
Pretty close- probably not exact, but very close.
#9 |
Member#: 9941
Vehicle:- --------------- www.djforums.com |
I bought the Omori 45mm gauge and replaced the column mounted OEM one.
I just shoved the Omori one into the rubber cup. Its about 100000 times better. |
#10 |
Member#: 17439
SoloOne - I had the intention of doing the EXACT same thing -- did it fit??
Did it require running new lines/wires for it, or could you just use the existing ones?? |
#11 | |
Member#: 15959
Vehicle:2005 WRX STi White |
#12 |
Member#: 4550
Vehicle:2002 WRX Wagon Silver |
bitchtastic!
does the mount stick onto the column with double stick tape or am i missin sompin? |
#13 |
Member#: 12454
Vehicle:02 ImprezaaWrxxxxx 08 SV650SF |
That looks awesome.. nice job. Does the 45mm guage show mroe of the tach.? Thats the only thing i dislike..
#14 |
Member#: 21847
Vehicle:2002 WRX Sedan World Rally Blue STX#555 |
the OEM one fits perfectly between teh 2 and 9K on the TACH. I think ill be adding a EGT using exactly what BIGSKY did on the opposite side of the column.
-c |
#15 | |
Member#: 9941
All you have to do is splice the wires on the Omori gauge to the OEM ones (for the backlight). You use the same rubber hose. I'll try to get pics of it. |
#16 | |
Member#: 15959
thanks for any info would the wiring and hose work for just about any gauge? |
#17 |
Member#: 17439
Thanks Solo - You have me sold too!
I was conisdering Greddy gauges, but I really liked the look of the Omori's - and a buddy of mine who has an S4 says that's all those guys use, and they have a good track record, so I was going to go with the add'l 3 gauges in the gauge pod up top. I'd love to see pics, but the fact that it's 2 less wires and 1 less hose to run make it seem much more worthwhile - that stock gauge is CRAP! |
#18 |
Member#: 16615
Vehicle:I ♥ my TE51 2009 Nissan 370z |
Nice install!
Matt |
#19 |
Member#: 7958
Vehicle:09 GH B+ |
I bugged and bugged Omori about a 45mm pod w/ no luck. I bugged SOA about just getting the dash mount pod w/ no luck either. I definitely wasn't going to spend a bunch of $ just to get the hood. Finally I said the heck w/ it and got this from Omori:
I ended hacking the bottom portion off (the arm part) and ended up w/ basically a tube just like the oe one. |
#20 | |
Member#: 22412
SWIC
Vehicle:2002 WRX Sport Wagon Platinum Silver Metallic |
Wiring-wise, with a mechanical gauge the only power needed is for the backlight (so you probably only have two wires - the variable/dimmed +12v and ground) so you should be fine. (as an aside, if you are doing the install from scratch, there is a two wire connector off of the radio harness which has the aforementioned leads, too) |
#21 |
Member#: 7958
Vehicle:09 GH B+ |
kastles's come w/ the yellow needle (even though his web site shows white needles). The one advantage of the mechanical one is it can dim- the electronic one comes w/ a seperate lead for lighting (as well as a lead for power and ground) thus no way to dim it (unless somone has some ideas).
#22 | |
Member#: 22412
SWIC
#23 |
Member#: 7958
Vehicle:09 GH B+ |
I found a post (needed to help me wire it) that said it wouldn't work as it had a seperate light wire. The instructions showed a red wire that need to be hooked to a 12v ignition, a black (actually two) to a ground, and a white for the light, brown don't use. I went to the clock and put red-> yellow w/ stripe white to pink w/ stripe and black to black.
If you get it it do dim, would you please post here. Thanks Big Sky |
#24 | |
Member#: 22412
SWIC
There is a set of two leads which are on the backside of the radio harness which you can use - see the attached pic from the Subaru mechanical gauge install instructions (so these leads would only be used for the light) - I would connect one of the black wires and the white wire to that and see how it goes. Did you set the warning light? I was thinking I would set mine for 14psi, so that I know when I am at full boost! |
#25 |
Member#: 23526
Vehicle:2002 WRX Sedan 2000 Yamaha YZF-R6 |
Other than the dimming issue (and the price), what is the real difference between the mechanical and electrical gauges?
Thanks __ Josh |
