Old 09-30-2013, 11:39 AM   #1
04wrxdan
Member#: 338240
2004 v39'd wrx
Default lean idle problem
OK, so i have been running an opensource ots map from xpt tuning for the last year or so for vf39, gm bcs, pink injectors, tbe, large tmic, k&n drop in....has been running fine for me as far as i could tell (hadn't done any logging)....I recently decided to go e85 route with an etuner, modified the pink injectors, he sent me a base map for 740cc injectors (he sd he's done modded injectors before and thats the size he used). i am having problems with high a/f correction and a/f learning at idle, not so much normal driving, and looks to be fine at wot. tuner thinks its a vac leak near the manifold somewhere, but i have been unable to find any leaks, i did fix a leak on the bpv, but problem still exhists, not as much, but is still there.......correction is about 15ish and learning is about the same....afr is between 14.5 and 15 at idle.
anyone have any suggestions?
04wrxdan is offline   Reply With Quote
Old 09-30-2013, 11:40 AM   #2
04wrxdan
Member#: 338240
2004 v39'd wrx
cant figure out how to post my logs
Old 09-30-2013, 11:41 AM   #3
insaneimpreza
Member#: 83291
1998 RSTi
IAG Stg4 Extreme S366SXE
Have you or your tuner tried to adjust either the latency or the MAF table itself to correct it?
insaneimpreza is offline   Reply With Quote
Old 09-30-2013, 11:44 AM   #4
04wrxdan
Member#: 338240
2004 v39'd wrx
no, he insists its a vac leak, and hasnt done anything else to the map. i was wondering myself if the maf was off a bit as well
Old 09-30-2013, 11:50 AM   #5
04wrxdan
Member#: 338240
2004 v39'd wrx
Old 09-30-2013, 11:54 AM   #6
04wrxdan
Member#: 338240
2004 v39'd wrx
Old 09-30-2013, 12:45 PM   #7
04wrxdan
Member#: 338240
2004 v39'd wrx
And also im not hitting target boost at wot.....doesnt seem to loose boost tho
Old 10-08-2013, 12:13 AM   #8
04wrxdan
Member#: 338240
2004 v39'd wrx
In case someone does a search problem was the maf was bad..
