Old 09-30-2013, 11:36 PM   #1
elijah.botez
Member#: 365711
2003 Impreza WRX
Black Wagon
Default 2003 WRX blown motor:( please help
Hi everyone, I got a 2003 Wrx with a fully stock ej205, with full 3'' turbo-back on stock tune.
So I was driving about 115mph and heard some click and pop after my engine died and a lot of oil smoke came out of the back. I knew it was the turbo so I replaced it. After starting it with a good turbo I hear slapping noises in my engine still smoking oil (but not as much), backfires every 5-10sec, smoke is coming out of the dipstick and dipstick actually flies out once I give it some gas. Runs really rough (sounds like only 3cyl are working). Huge loss of power. No leaks or anything from the head-gaskets or anywhere in the engine except exhaust. Turbo sounds fine but gauge shows 10psi of vacuum. Will do a compression test sometime soon. I know it will need an engine rebuild. Where can I get good parts? Is it possible to do a rebuild under $1k? I have access to a shop and capable of doing it myself but I'm in college so I am really broke. I thought of buying a used engine but can't find one cheaper than 1,500$. Help me out please! Thanks guys
elijah.botez is offline   Reply With Quote
Old 09-30-2013, 11:59 PM   #2
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You cannot rebuild for under $1000. No chance in hell. Even I couldn't do it for that little and I can suck a mile of dick for free parts.
Old 10-01-2013, 12:01 AM   #3
CBRken
Member#: 343049
1998 Impreza WRX STi
Steel Blue
Where do I get in line?
CBRken is offline   Reply With Quote
Old 10-01-2013, 12:25 AM   #4
jam007
Member#: 174706
2008 LGT-B
Meat it's what's for dinner
jam007 is offline   Reply With Quote
Old 10-01-2013, 12:28 AM   #5
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
I can suck a mile of dick...
Gotta be my new sig.
jerbull88 is offline   Reply With Quote
Old 10-01-2013, 01:11 AM   #6
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Uh maybe that was the problem
Sorry about your car
Dat8687 is offline   Reply With Quote
Old 10-01-2013, 01:45 AM   #7
subaru_gc8
Member#: 29292
2004 WRX wagon
I just priced out my parts and it came out to 1300 for the rotating assembly, so getting a rebuild for under 1500 is not going to happen. also I dont think you wanna go through the trouble of putting an a junk engine to do it again like in a few months. do the right way once and that way you wont have to do again for a while .
subaru_gc8 is online now   Reply With Quote
Old 10-01-2013, 09:48 AM   #8
ShinjiML
Member#: 257231
2011 STI
Oh man if only you were closer, I have a longblock that I can sell you for MUCH MUCH MUCH less than $1000.
ShinjiML is offline   Reply With Quote
Old 10-01-2013, 04:55 PM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Sell your car as is for a Honda and enjoy going 115 in that beast to impress the high school freshmen.
Old 10-02-2013, 01:54 PM   #10
elijah.botez
Member#: 365711
2003 Impreza WRX
Black Wagon
115mph is not a problem for a subaru, I used to go 125 on curved roads with good boost and without any problems/noises or smoke.
Old 10-02-2013, 04:51 PM   #11
flash02
Member#: 78916
Curious about doing the machine work, does this machine shop you speak of have experience in rebuilding Subaru Boxer engines? Subaru sells STI short blocks brand new for $1700.00. Sorry but any engine that is going to reliably put down good HP is going to cost a few bucks. My old simple Toyota 22RE in my 86 4Runner cost me $1500.00 to rebuild.
flash02 is offline   Reply With Quote
Old 10-02-2013, 05:25 PM   #12
sultanofsubguns
Member#: 351404
02 WRX Wagon
ProbablySomethingMundane
Not going to happen around here since subaru parts and labor fetch a premium in the NW. The average labor charge for shops in the Portland area is $95 an hour and most of the base package rebuilds from them start at 3k+. You should probably just get a honda if you want a car to abuse since owning and maintaining subarus isn't cheap.
sultanofsubguns is offline   Reply With Quote
Old 10-02-2013, 06:07 PM   #13
Fir3Fighter
Member#: 316780
2003 Impreza WRX
Fir3Fighter is offline   Reply With Quote
Old 10-02-2013, 09:41 PM   #14
elijah.botez
Member#: 365711
2003 Impreza WRX
Black Wagon
Originally Posted by sultanofsubguns View Post
... You should probably just get a honda if you want a car to abuse since owning and maintaining subarus isn't cheap.
The point is I am looking for a good daily 4wd wagon that's reliable and fun to drive. The most I would do to it is an up-pipe and inlet house maybe cold air intake and then get a good stage 2 tune. Not looking for anything fancy or fast.
Thanks to everyone for advice!
I will be pulling the motor out soon so I'll see if I can get away with only replacing what must be replaced besides new water pump, gaskets, belts etc.
Old 10-04-2013, 10:39 PM   #15
vf22Bugeye11
Member#: 272096
2002 6Speed swap wrx
Function Warrior!!
There will be metal shredds all over the place from the bearings. If you only replace the bearings and affected rod your asking for trouble
vf22Bugeye11 is offline   Reply With Quote
Old 10-05-2013, 06:42 PM   #16
capehoorn
Member#: 191396
2005 92x
Machining and parts will run a minimum of $2000 to $2500.
capehoorn is offline   Reply With Quote
Old 10-05-2013, 07:08 PM   #17
Nikryj
Member#: 346659
2003 WRX
it doesn't sound like a rod bearing at all. He blew a ring.
Nikryj is offline   Reply With Quote
Old 10-06-2013, 01:13 PM   #18
boostfanatic
Member#: 324805
2002 Impreza WRX
Gray/Black
If he blew a ring then he is definitely going to need machine work at the best or a new block at the worst. Broken rings are no joke.
My suggestion would be to get a new short block at least, it will be the most cost effective over the long run and more reliable then machining the block and most likely having to go with oversized pistons and rings.
He wont be asking for trouble if he tears down the engine and cleans everything and then rebuilds it with fresh bearings and a new rod. The main problem is going to be cylinder damage due to the broken rings.
boostfanatic is offline   Reply With Quote
Old 10-06-2013, 01:25 PM   #19
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
Buy a used wrx shortblock I'm sure you could get one and resurface your heads for around 1k bit with gaskets you'll be at least at 1k I sold my ej205shortblock with 20k for 500
alexandern05 is offline   Reply With Quote
Old 10-07-2013, 11:24 AM   #20
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
This thread is full of fail.
Unabomber is right.
340Duster is offline   Reply With Quote
Old 10-07-2013, 04:57 PM   #21
swifto
Member#: 370333
2003 WRX
try and sell it... lol
swifto is offline   Reply With Quote
Old 10-07-2013, 05:05 PM   #22
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
