Old 10-01-2013, 07:25 AM   #1
ElSpa
Member#: 196674
Default VF37 Twinscroll - billet compressor wheel upgrade - 11 blades vs Dual 6 blades
I'm thinking of upgrading my twinscroll VF37 with a billet compressor wheel (30% lighter, 49.6 mm / 61.98 mm (Inducer / Exducer)).
I have two options: 11 blade design or dual 6 blade design.
What would be the pros / cons for each one (spool, top end, middle torque)?
ElSpa is offline   Reply With Quote
Old 10-02-2013, 02:07 PM   #2
ElSpa
Member#: 196674
nobody ?
Old 09-04-2014, 04:02 AM   #3
binny
Member#: 198108
MY98 WRX
I've done it on mine - not sure where the 30% lighter comes from I think it was more like 4 - 6 grams
I went for the GTX style 11 blade version
cons have to get the cover machined as its a bit bigger than stock + you then need to balance the CHRA
pros pulls hard to redline
binny is offline   Reply With Quote
Old 02-26-2015, 02:22 AM   #4
jellenberg
Member#: 336991
2006 WRX STI
Steel Gray Metallic
Bringing this back from the dead here, but what exactly has to be machined? I'm about to purchase a vf37 and the guy is including an 11 blade billet complete chra. He says it's just a drop in package. So any info would be great.
jellenberg is offline   Reply With Quote
Old 03-01-2015, 10:14 PM   #5
binny
Member#: 198108
MY98 WRX
The compressor cover and the CHRA need machining (unless the new wheel is the same size as the stock wheel)
The inducer is about 4mm bigger and the exducer maybe 2mm bigger on the Kinugawa GTX style wheel
If the seller is saying drop in its possibly a smaller / stock size wheel or it's already been machined
It's worth noting when I purchased the kinugawa compressor it was sold as just an upgraded VF37 wheel no mention that you need to machine anything to fit it ~
Old 03-01-2015, 10:16 PM   #6
jellenberg
Member#: 336991
2006 WRX STI
Steel Gray Metallic
Hmm alright, well it's a 6star speed complete chra and he claims that all I need to do is basically bolt the compressor and turbine on
Sent from my SCH-I545 using NASIOC mobile app
Old 01-01-2016, 08:53 PM   #7
PrinceVegeta
Member#: 428946
2008 JDM WRX
Bump
Anyone else did this before?
Any details pics, write up, before and after performance results?
PrinceVegeta is offline   Reply With Quote
Old 01-06-2016, 11:19 PM   #8
jardamuth
Member#: 100137
2000 Impreza RS
Billet wheels are available in a large range of inducer/exducer size so in regard to the fitment, it all depends of what wheel you have.
I use 5 blade billet wheels for our builds. Much quicker spools and broader powerband. The 11 blade GTX design sole advantage is that It can push a bit more CFM in the top end.
jardamuth is offline   Reply With Quote
