Old 10-03-2013, 08:53 AM   #1
breakablecookie
Member#: 341787
2005 STi
Default Top 6 areas to monitor on APv3
Hey everybody I did a small amount of searching and couldn't find anything specific on this. Since my new AP v3 can show up to 6 parameters at a time, what would be the top 6 things to watch?
I'm going to list what my current 6 choices are and any input on important things to watch would be appreciated.
I currently watch:
Boost
Intake Temp
Coolant Temp
MAF
Gear Position
Wastegate Max
I also have prosport gauges for boost and oil pressure and I have an AEM UEGO Wideband.
Shouldnt matter too much but the car is on a custom stage 2 tune. 2005 sti with 07 motor.
breakablecookie is offline   Reply With Quote
Old 10-03-2013, 09:06 AM   #2
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Afr correction 1, Afr learning 1, Maf voltage, afr1, FBKC, FLKC, is a start to learning whats actually important.
rexworx is offline   Reply With Quote
Old 10-03-2013, 09:15 AM   #3
breakablecookie
Member#: 341787
2005 STi
Thanks I'll look into those!
Old 10-03-2013, 11:46 AM   #4
Drewswrx
Member#: 352498
2008 Wrx 2.5L
World Rally Blue
I would also watch DAM,MAF,TP and engine load
Drewswrx is offline   Reply With Quote
Old 10-04-2013, 01:59 AM   #5
siadyang
Member#: 329715
2012 WRX
2015 WRX
I am currently monitoring Boost, Intake Temp, A/F Learning 1, Fine Knock Learn, Feedback Knock, and DAM.
According to Cobbs Website:
Top 5 Monitors
Our top 5 monitor list consists of; A/F Learning 1, Boost, DAM, Fine Knock Learning, and Feedback Knock Correction. There are many other parameters to log though, and with experience they can be useful to help diagnose tuning and mechanical issues on the vehicle. But with a quick glance and little knowledge, these 5 monitors can give you a good idea of your vehicle's health and performance.
siadyang is offline   Reply With Quote
Old 10-04-2013, 11:55 AM   #6
heavyD
Member#: 194216
2016 MK7 Golf R
I find the Cobb defaults are good enough for the average person that just does the occasional logs but there's lots of information if you are more inclined.
heavyD is offline   Reply With Quote
Old 10-06-2013, 12:04 PM   #7
Teedub21
Member#: 333099
2013 WRX STi
ISM
I think the OP is referring to the "gauge" mode, not data logging.
Teedub21 is offline   Reply With Quote
Old 10-07-2013, 02:53 PM   #8
heavyD
Member#: 194216
2016 MK7 Golf R
My mistake. I prefer to monitor 4 items or less to keep the boost gauge a little larger seeing that's the most important gauge parameter. Some of the parameters like feedback knock are kind of useless as a gauge monitor as peak values will always be low RPM false knock.
Old 10-10-2013, 12:15 PM   #9
1wrxtra
Member#: 316364
2012 WRX
Boost, injector duty cycle, engine load, a/f learning 1, feedback knock and fine knock learning.
In cold and moderate weather, intake temps aren't as important to watch as injector duty. Especially if you are on the stock injectors at stage 2.
If you want to watch AFR, get a wideband.
1wrxtra is offline   Reply With Quote
Old 10-15-2013, 10:41 AM   #10
DeluxE36
Member#: 362323
2008 STI
Boost, A/F Ratio, Coolant Temp, Throttle Position.
Although, I'm interested to see what others are doing.
DeluxE36 is offline   Reply With Quote
Old 10-15-2013, 09:56 PM   #11
loather
Member#: 367325
2008 STi Hatchback
I currently have 6 monitors:
A/F Learning 1
A/F Correction 1
A/F Ratio 1
Fuel Economy (misnomer - should be efficiency)
Boost
Intake Temperature
I'd like Cobb to bring back the average fuel efficiency calculator in the next AP firmware but I didn't get a single bit of feedback on my other post, so I'm not holding my breath.
loather is offline   Reply With Quote
Old 10-15-2013, 09:56 PM   #12
loather
Member#: 367325
2008 STi Hatchback
(double-post)
Old 10-21-2013, 09:22 AM   #13
breakablecookie
Member#: 341787
2005 STi
Should've made it clear that I was looking for the top 6 things to monitor in real time WHILE DRIVING. Not asking what to monitor for a data log.
Old 10-21-2013, 06:03 PM   #14
Cobb Tuning
Member#: 4803
This has been brought up internally and is being discussed right now. I don't know how/when/if it'll happen yet, but you have been heard good sir.
- Chris
