Old 10-07-2002, 11:21 AM   #1
k2snow
Member#: 10449
03 Legacy BH
Question Need opinions of swap or Turbo setup???
I have a 2.2L OBS wagon and I am debating whether or not to swap a JDM legacy EJ20T into it and spend the money for the standalone ecu or just turboing my N/A EJ22 and running it at low boost. I'm sure some i-clubbers have undertaken this project. Just trying to weigh my options before I spend the money. Both projects look like they start at around $1500 and up. Any suggestions or help would be greatly appreciated.
I was also looking at putting an USDM legacy exhaust manifold onto my 2.2L OBS engine as a route to make the custom turbo setup. Will this work?? I have a 99 Phase II motor w/ an MAP sensor so I understand that I have to get the Zener Diode piece. I'm curious if the manifold will bolt up to my single ports on my block??
Thanks i-club,
PJ
k2snow is offline   Reply With Quote
Old 10-07-2002, 01:10 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
first of all i think your budget is too low
at least doubble it maybe triple it
you need to remmebr to add things like gages, fuel pumps, clutches, cross memebrs, custom exaust work, etc...
i will probblay spend 1500 on the ecu part alone
ps i have know a guy in bosie that has a LT manafold that he want to get rid of
Old 10-07-2002, 01:50 PM   #3
smacksube
Member#: 4067
01 2.5 rs
I put my turbo kit together for roughly $1680...that included a J&S, gauges, fuel pump, intercooler, BOV, turbo, up and down pipes, oil lines, coolant lines, and a rrfpr. Basically everything you need plus some.
smacksube is offline   Reply With Quote
Old 10-08-2002, 10:58 AM   #4
k2snow
Member#: 10449
03 Legacy BH
Default Jaxx
Can I use that Legacy turbo manifold on my 2.2L w/ single ports? I was planning on building a turbo from the bottom end up but I can't get any info on doing this?? Any help? Did you recieve your engine yet?? I'm trying to find some guys locally who could help w/ an EJ20 T swap, but one other problem, I don't have another car to drive...
Thanks for the info.
PJ
Old 10-08-2002, 11:38 AM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
I.... have no idea ...no no engine yet ..
Old 10-09-2002, 01:41 AM   #6
hayscoob
Member#: 4544
2004 STi Aspen White
Bone Stock for now
I wish!.
OK, no foolin here. Your budget is WAY too low. You may find a motor for that, but it will not be that cheap to have the work done. That also may not include the cost of electronics for fuel and timing, ie JDM ECU or some sort of PEMS. If you are planning to turbo your NA motor, you may find that a JDM turbo motor may be the cheaper and less expensive way to go. But remember, the Beast "22B" had that kick but 2.2 liter JDM motor behind it. Also, you can get a 2.0 WRX motor too. Now that the WRXs are winding up in the juck yards from all ot the accidents happening out there. You may want to consider that as an option.
Paul...
hayscoob is offline   Reply With Quote
Old 10-10-2002, 06:21 PM   #7
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
The 22B started out as a Ver. IV 2.0 liter. I guess it was bored and stroked to 2.2.
garface is offline   Reply With Quote
Need opinions on a pilar gauge setup dtfdanyo Interior & Exterior Modification 4 03-08-2009 09:58 PM
Need opinions/advice - Upgrade or Swap? Polaren Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-17-2007 01:38 PM
post pics of your swap or turbo set up spoonfedb18a1 Member's Car Gallery 5 02-11-2006 08:37 PM
Opinions of my dash/gauge setup 99RSTurbo Member's Car Gallery 1 03-08-2004 07:58 PM
need opinions of my future audio setup deks Car Audio, Video & Security 4 08-02-2002 03:55 PM
